01-27-2024, 07:43 PM | #353 |
Rep 4
01-27-2024, 08:59 PM | #354 |
Rep 41,190
It is ENTRNAV2.
01-28-2024, 08:17 AM | #355 |
Rep 4
So I just need the ESYS, and Enet cable, doing the steps, and after flashing, the carplay will appear and be active? If there is more additional steps required, please help me, I never coded anything, I just want to make sure I am not making any damage on my ECU. If you have link where can I download the esys, I would be greateful. I also see ,,FSC code must be generated’’, what’s that, how can I add this to the car? This is totally new for me, trying to understand it. The car has no wifi antenna, I should install it also.
01-28-2024, 09:08 AM | #356 |
Rep 12
So my unit was already updated to version Y.
I used BimmerCode to change the UI to ID6_light… worked like a charm! Question, option for ID6 was in the menu??? Anyone know the difference light vs standard? Are older units that were ID5 plus plus capable of straight ID6? Andrew |
01-28-2024, 10:26 AM | #357 | |
Rep 41,190
01-28-2024, 11:06 AM | #358 | |
Rep 41,190
Android6044.50 |
02-09-2024, 04:56 AM | #359 | |
Rep 1
I have the same question. I've a mini cooper S 2019 with full 8.8" touch screen with apple carplay actived. I want the new id6 interface. What's the step to update the Head Unit ? I've e-sys ans psdzdata 4.45.30 full... Can you help me please ? https://ibb.co/xstKkBn Last edited by stephcel26; 02-09-2024 at 05:01 AM.. Reason: image |
02-11-2024, 08:55 PM | #360 |
Rep 102
Successfully updated the NBTEVO software. Now I need to figure out how to code fullscreen to active. I've struggled to find a guide how to do it. Any advice?
02-11-2024, 09:03 PM | #361 |
Rep 41,190
FDL Code carplay_fullscreen = aktiv
02-12-2024, 11:37 AM | #363 |
Rep 5
Need help ZGW-02 to flash on bench (Runtime-errror)
Hello everyone,
I would like to do a NBT Evo retrofit to my E91. I want ZGW-02 high to ZGW-02 8sk on bench to flash and VIN change with esys 22.10 but I get an error (Runtime_error) . I tried with Enet cable and with ICOM and I have the same error. Could someone help me? Thanks in advance Last edited by emaflo78; 02-18-2024 at 07:36 AM.. |
02-22-2024, 07:26 PM | #364 |
Rep 7
About to do this to get carplay fullscreen , couple questions first.
1. My HU_NBT depends on FEM_GW and FEM_BODY. Ive read that typically you start by only updating the ECU of interest and worry about the flashing the dependent ECU's if it failed. Is this the right approach? 2. Will i need to reload any FSC codes after? My head unit is factory and shipped with carplay. Thanks |
02-22-2024, 08:11 PM | #365 | |
Rep 41,190
2) No, not unless flashing from ID4 to ID5/6.
a_dev1.50 |
02-25-2024, 05:08 PM | #367 |
Rep 41,190
03-31-2024, 09:25 PM | #368 |
Rep 5
Hello! I would like to do this to my 2018 G30 540i.
I am currently showing NBTevo_S. Bimmercode says I need Version X or Y Is is possible with my system? If so, Where can I obtain ESYS program and files? Thank you! |
03-31-2024, 09:31 PM | #369 |
Rep 41,190
PM sent.
04-14-2024, 06:45 PM | #371 | |
Rep 15
05-12-2024, 09:09 AM | #372 | |
Rep 3
Need help with F30 2014 model. I want to flash my Fu_Entry as it is stuck on BMW logo
Will this method work for my F30? Any modifications required in the above steps? Please help as I am a newbie > I have E-sys 3.29 installed. The launcher is not working. |
05-12-2024, 09:52 AM | #373 |
Rep 41,190
PM sent.
