05-26-2022, 08:21 PM | #67 |
Rep 1,038
05-26-2022, 10:43 PM | #69 |
Rep 64
It was the flimsy edging that looked cheap. I went up .125 and it was tight. You cant see the honeycomb standing or at ride height that pic is straight ahead down low, prototype.
05-27-2022, 04:35 PM | #71 |
Rep 1,252
Just did the blacked out crash bar.
daytonaviolet1254.50 |
05-30-2022, 06:49 PM | #74 |
Rep 1,252
Stock fog lights, just had them wrapped in yellow tinted film.
Longboarder3437.00 |
05-30-2022, 07:00 PM | #75 |
Rep 1,252
Installed some new plugs. I noticed at startup, since tuning to stage 2, the idle was a bit rough. Added the NGK 97506 2step colder, gapped them and installed them myself. First time on this X5M. Pretty easy with the right tools. I will add that you should unplug the battery to avoid the scare I put myself through. On the driver side furthest back plug, my ratchet spun and hit the positive battery post. It arc'd on my arm and burnt me a bit, so I pulled my arm away instinctively. The ratchet then sat on the terminal and heated up so much my mechanix gloves melted to the ratchet. I had to get a screwdriver to pull it off, but it melted some wire harness and left bare wires smoking. Also, it was on the spark plug so I thought that might be damaged as well. The ratchet and socket, extensions etc were too hot to handle even with gloves on. Was a crazy embarrassing experience that I'm only sharing because I hope it helps someone else. I spent the afternoon repairing the wires with heat shrink tubing etc. I dodged a bullet as once I got everything back together, the car started right up and ran perfect. I drove around for a bit and put it through the motions, no issues so far!
islandman21.00 |
05-31-2022, 10:03 AM | #76 |
Rep 1,041
Drives: BMW X5M, M3 ZCP, MB E63 AMG
Well, I've finally been able to get my X5M fully detailed inside and out. And it looks outstanding. I should have taken some pics.
05-31-2022, 02:12 PM | #77 |
Rep 94
15/15mm spacers on the OEM wheels/ tires at factory height. Puts them pretty flush with the fender.
upload image Last edited by OhThatGuyJax; 06-01-2022 at 07:57 AM.. |
05-31-2022, 06:42 PM | #79 |
Rep 1,252
05-31-2022, 08:34 PM | #80 |
OEM CSL Whore
1255
Rep 1,476
4
06-01-2022, 01:58 PM | #81 |
Rep 94
Michelin pilot sport cup 2
upload pic Both are Michelin 325/30/21 sized tires. The super sports are 13” wide overall and the Pilot Sport Cup 2’s are 14” wide unmounted (13.8” mounted on the OEM width wheel according to tire rack). Last edited by OhThatGuyJax; 06-01-2022 at 04:35 PM.. |
daytonaviolet1254.50 Surgx572.50 |
06-01-2022, 07:17 PM | #83 |
Rep 94
No, they’re the same size as the OEM tires for the 612 wheels: 325/30/21. They just run 1” wider for whatever reason. I’m going to trade a set of 20” BC Forged wheels toward a second set of OEM 612 wheels then send those off to get widened to 11” front and 12.75” rear. Then put these giant cup 2’s on that set and see if they’ll lay out over 14.25” on the wider wheels. Should look mean.
9vapors653.50 daytonaviolet1254.50 |
06-01-2022, 10:00 PM | #85 | |
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
06-02-2022, 03:33 AM | #86 | |
Rep 94
06-02-2022, 04:30 AM | #87 | ||
OEM CSL Whore
1255
Rep 1,476
06-02-2022, 06:11 AM | #88 | |
Rep 1,234
Fronts?
