10-10-2018, 09:01 AM | #1 |
Rep 3,161
Audio systems
Has anyone done some audio system
Beyond the replacing stock location speakers? Subs in back? Box, false floor or anything else like that? I mean, is there seriously no bass heads in here?
2015 M3 BPM Tuned, Eibach, Magnaflow and more www.tmrmzine.com/m3/f80
SOLD E92 Slēk Carbon Fiber Widebody M3 www.tmrmzine.com/m3/slek/ SOLD E92 335i Stage 3+ with all the toys www.tmrmzine.com/335/ SOLD E39 M5 Modded, What a great car! www.tmrmzine.com/m5/ |
10-10-2018, 09:22 AM | #2 | |
Rep 703
Next is adding a sub in trunk. These is what I add: Sub: https://www.amazon.com/dp/B00JFHQ1NY...v_ov_lig_dp_it Amp: https://www.amazon.com/dp/B003RW3YUG...v_ov_lig_dp_it Bass control: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Harness: https://technicpnp.com/product/logic...cy+adjustments |
Twin Peaks94.00 |
10-10-2018, 09:34 AM | #3 | ||
Rep 277
Audison bit dmi Zapco DSP IV II ZUKI 4x175 (2x) ZUKI 1x2500 Audible Physics RG50 tweeters Audible Physics RG100 4" Audio Development w800 neo 8" Fi Audio 12" Q Neo sub I have all new wire running to the front stage. With the hurricane I haven't had a chance to finish my sub box in the driver's cubby. So it's just in a sealed box for now. Also the amp are temps until my Boland Amps come in. |
4
10-10-2018, 09:48 AM | #4 | |
Rep 703
10-10-2018, 09:50 AM | #5 | ||
Rep 277
10-10-2018, 10:10 AM | #7 |
Rep 277
10-10-2018, 10:46 AM | #9 |
Rep 30
If you want to keep it simple and build off the HK system, add a mono sub amp in the rear storage cavity near the factory amp, an Audio Control LC2i controller and a remote bass control knob in the blank panel near the fog light button with a 10" sub in the floor hidden underneath the back storage space. You can do all of this or have it done for decent price depending on the components you choose.
I have the third row option and space is limited but after you take out all of the plastic around the rear battery compartment, there is more than enough room. Personally I am using a JL audio 500 watt mono amp and Focal 10" sub in a sealed box. Once install is complete next week, I can load up the pics. |
10-10-2018, 01:00 PM | #10 |
Rep 277
The HK system is a little hard the tap into. I don't think there is a plug and play harness. You will need what he said. If you don't have third row or spare tire to worry about. There is about 9" of depth to use for a sub under the floor. I would say get a 12" sub to give you a little bit more of the low end.
10-10-2018, 04:26 PM | #11 | |
Rep 703
bmwx1sq145.00 |
10-10-2018, 05:14 PM | #12 | ||
Rep 277
10-10-2018, 10:53 PM | #13 |
Rep 413
What is the other $50 technic harness on their website? Not sure which one of the 2 I will need. I also have a factory HK and just want to add a trunk sub for now
10-11-2018, 06:10 AM | #14 | |
Rep 703
AudioControl LC2i 2 Channel Line Out Converter Wwith AccuBASS and Subwoofer Control https://www.amazon.com/dp/B00IIL0LW0..._59YVBbYCNTKCE |
duercos201.00 |
10-11-2018, 09:12 AM | #16 |
Feelin Nauti
104
Rep 116
I am currently adding 2 12" JL Audio subs in a ported enclosure, custom built box in the rear floor. Adding a JL audio mono sub amp where the factory amp is as well as a Audio Control LCQ-1 LOC with EQ. Replacing stock front speakers with all Focal speakers on the stock amp for now. For now the EQ can only be used on the bass to smooth it up a bit.
I looked into installing the bass knob in the spot where the blank is by lights switch but it physical will not fit there. Its a full electronic switch housing and even when I took it apart it wont fit there. So I am installing the base knob inside the storage door below the light switch. Hopefully I will have it mostly done this weekend and will post pics.
2014 650i M Sport Frozen White Matte Metallic
2015 X5 M Sport 50i Mineral White 2012 650I Conv Sapphire Black 2013 Harley Softail, Road King, Road Glide show bikes 2010 40' Express Cruisers Yacht |
10-11-2018, 12:22 PM | #17 | |
Rep 277
10-11-2018, 02:53 PM | #18 | ||
Rep 413
10-11-2018, 03:06 PM | #19 | |
Rep 703
This means from "factory amp" the signal can come up to 400 watt per channel. Then from LOC it goes to your Alpine amp that will power your sub to whatever it can. The reason you need that LOC is because the signal you get from the car sound system is already amplified and your Alpine would not accept 400 watt input signal (most amps will not, they would get damaged) so it's music source/headunit > "factory amp" > harness > LOC > Alpine amp > subwoofer makes sense? if not check this or https://www.audiocontrol.com/car-aud...-upgrade/lc2i/ |
10-11-2018, 05:59 PM | #20 | ||
Rep 413
10-15-2018, 09:33 AM | #21 |
Feelin Nauti
104
Rep 116
My weekend project.. I installed 2 JL Audio 12w1v3 subs in a sealed enclosure
(did not have air space for ported) in the trunk area in storage area. I still need to do my grill with perforated metal flush with the floor to cover the subs to keep them safe. I also installed a JL 600/1 sub amp and a LOC/EQ. I had this left over from previous car. I may add amps in the future for the mids and highs. I installed the remote sub level control in the panel under the CD player.
5
10-15-2018, 10:24 AM | #22 |
Rep 178
Just curious if anyone has ran a separate amp to the front underseat woofers? I was thinking of doing the BavSound underseat replacements with an additional amp powering those. I have the spare tire option so very limited room in the trunk underhatch.
I see there is a Stealth Box for the E70, but not sure it would fit the F15. http://www.jlaudio.com/product/54216...29_%2707-%2713 |
