12-12-2021, 04:59 PM | #1 |
873
Rep 345
22x10.5 front and back
Hey, looking to put 10.5 front and back, 10.5 is as wide as this rim comes….
Any off set suggestions as they will do any offset, front and rear, I want. What is max diameter tire you can run without rubbing? Also what size tires front max to not rub, back suggestions as well? I don’t mind running two different sizes as the offsets will make it not square set up |
12-15-2021, 10:27 AM | #3 |
Trust me....I'm an engineer
111
Rep 164
Stock 469M wheels are 20x10 +40 front and 20x11 +37 rear. You can't go any farther inboard in the front with the 469M wheels, as there is only 4mm of clearance to the inboard upper control arm. Keeping the same inboard clearance, you would be looking at a 20x10.5 +27 wheel (or less offset). So a +22 or a +25 wheel would work as well.
I suggest getting a square set of wheels, and then run spacers in the rear. This will allow you to rotate tires front to back and get more life out of your tires. Stock tire diameter is about 28.5", and I suggest not going much bigger. I find this site helpful in understand overall diameter: https://www.tacomaworld.com/tirecalc |
12-15-2021, 09:23 PM | #4 |
Rep 51
I have 22x10.5 and an offset of +28 on my front wheels. With this offset my wheels are perfectly flush with the fender. You would need a greater offset in the rear to make sure those rear wheels are also flush with the fender, otherwise it will look weird, or you will need spacers in the back.
