12-23-2021, 05:42 PM | #1 |
The General
57
Rep 124
F15 X5 Alignment specs
Looking to do my own alignment on the x5 but can't seem to find any factory alignment specifications for the X5 listed anywhere on the Internet*. Does any one know or can post picture copy of alignment sheet from your last alignment? That would be would be awesome Thank you in advance for the help.
12-27-2021, 12:48 PM | #2 |
Trust me....I'm an engineer
111
Rep 164
I do my own alignments on all of my cars. The X5 isn't really anything special compared to any other MacPherson front suspension cars. These are the numbers that I shoot for on any car:
Rear Camber: As little as the factory adjusters allow, usually between -1.5 and -2.0 degrees Front Camber: Match rear camber as close as possible Rear toe: Tiny amount of toe in, usually 1-2mm measured using toe plates Front toe: Small amount of toe in, usually 1-2mm measured using toe plates Thrust Angle: Get as close to zero as possible with available tools. I have a digital level that I use for my camber gauge, and it has a built it laser. I use the camber gauge and laser to measure thrust angle. |
12-27-2021, 04:15 PM | #3 | |
The General
57
Rep 124
12-31-2021, 10:24 AM | #4 | |
111
Rep 164
OEMs design the car to handle for the lowest common denominator driver, and OEMs think understeer is safer than oversteer. |
12-31-2021, 11:17 AM | #5 | ||
The General
57
Rep 124
12-31-2021, 09:30 PM | #6 | |
Rep 44
2011 335D sport
2014 X5 35D m-sport 2014 X5 35I luxline |
12-31-2021, 09:40 PM | #7 | ||
The General
57
Rep 124
04-29-2022, 05:13 PM | #8 |
Rep 73
So I have a similar set up (20 inch run flats on Beyern rims) as well but seems like my specs are still off after alignment. I went to a goodyear dealer who said these cars are always a PITA to align and that this was the best he could do.
Should I try a BMW dealer to get better specs? Im about to replace my tires so want to make sure everything is properly aligned. As you can see, my specs are quite different... |
04-29-2022, 09:38 PM | #9 | |
Rep 1,038
04-06-2024, 10:14 AM | #11 | |
Rep 108
I have 20" Staggered wheels. I didn't have any uneven tire wear issues, just that the steering was cocked slightly to the right and that's been corrected. Is there any concern leaving it as it is? |
