      04-28-2014, 08:07 PM   #1
abmwdummy
Drives: 2014 X5 xDrive35i (USA)
Question Premium gas necessary?
We just got a 2014 X5. Is it really necessary to use premium gas? Would 89 do? What harm would 87 cause? Thanks!
      04-28-2014, 08:15 PM   #2
jadnashuanh
Drives: 535iGT x-drive; i3 BEV
The computer will adjust the timing and operating parameters to adjust the engine operation to the conditions and the quality of the fuel. But, there are limits. When the octane is below the range it can handle, it could cause engine damage. You are only guaranteed the design performance if it has the desired octane. When the computer detunes the engine, you will get less MPG and performance, so in the end, it may end up costing about the same or even more to use the lower octane since you'll use more of it. Driving very conservatively, you may not notice the performance differences, but most people do notice.
      04-28-2014, 08:17 PM   #3
barcelona
barcelona's Avatar
Drives: X
I use 91 the recommended grade. You may not have seen this recent thread, from 87 to 91, varied thoughts that you may ponder. Posted are some very good analysis.
http://f15.bimmerpost.com/forums/sho...ght=gas&page=2
      04-29-2014, 07:43 AM   #4
Shaw
Shaw's Avatar
Drives: 2016 X5 35d | 2016 X1 28i
I've parked the F30 in the garage for now (due to sharp increase in Gasoline prices here in Canada)... In contrary, Diesel price which was almost as high as Premium during winter has dropped significantly...right now, it is even lower than 87!!!
I'm currently enjoying the "Diesel experience!"...
      04-29-2014, 07:46 AM   #5
Shaw
Shaw's Avatar
+1...I wouldn't use anything lower than what is indicated as "minimum"...
On my previous X3 it was 91 as minimum...
On my F30 it is 89 as minimum...
      04-29-2014, 11:22 AM   #6
jeffhoff
Drives: 2012 Alpine White X5 5.0
In general premium fuel runs about $0.10/gallon more than the mid grade. Assuming approximately 15 gallons/fill up you're talking a difference of $1.50 every time you fill up.
Given your driving a $60k+ vehicle it shouldn't be an issue spending an extra $1.50
      04-29-2014, 11:55 AM   #7
Zipforia
Zipforia's Avatar
80
Drives: 2016 BMW i8
+1
Z.
      04-29-2014, 12:56 PM   #8
GoSooners
Drives: 2014 X5d
+2
Or should have gotten a diesel if you were looking for savings. Diesel is $0.20 less than Premium right now in my area.
      04-29-2014, 02:55 PM   #9
Jenya B
Russia
115
Drives: Z4 , X5 F15d Msport
i'm using Mac's gas station on MajMackenzie and Jane , they always 10cents lower than others . Diesel last week was 1.29$
      04-29-2014, 07:39 PM   #10
abmwdummy
Thank you everyone for the quick reply!
      04-30-2014, 09:07 AM   #11
Shaw
Shaw's Avatar
funny you should mention that...I did fuel up there couple of weeks ago...very interesting prices!!!
Sadly, I'm not near that station to make it a regular visit...
the ones close to us are offering $1.33...
I will always keep in mind when passing major mack!
      05-03-2014, 07:51 AM   #12
barcelona
barcelona's Avatar
Drives: X
20130508080132890.pdf
Definitely not 87, unsure why someone would.
Source: Roundel 4/13, Mike Miller. Sounds good except his philosophical comments at the end.
Search this Thread:
Advanced Search
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
