06-14-2016, 10:01 AM | #1 |
Rep 275
TPMS Swap Errors
I swapped a set of wheels off a 2016 X6M to my 2016 F15. I have tried to reset the TPMS through iDrive and it gets to 49% and stops and gives me the error message. I called 2 BMW Dealer and got two different answers about whether these sensors can be reprogrammed or not. Can anyone shed some light on this?
06-14-2016, 10:44 AM | #2 |
Rep 11,857
Drives: MY24 G01 AW Msport
how about if you go for a drive, see if tpms calibrates itself then try going thru idrive check for psi.
06-14-2016, 12:35 PM | #3 |
Rep 18,796
@imtheant that is weird.
Is that 2016 X6M wheels brand new? The F86 X6M use the same TPMS as the F15/F16 X5/X6. After reset, you need to keep on driving until it got detected.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com Memorial Day SALE!! 05/24 - 06/03 • Coupon Code: "MEMORIAL" MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
06-14-2016, 06:41 PM | #4 | |
Rep 275
Then I hit the reset button and it sits at 0%: And after 30 min of driving and the % not moving from 0%, it gives me this: THOUGHTS?? |
06-14-2016, 08:23 PM | #5 |
Rep 18,796
Can you share e picture if the wheels? Especially the valve stem area.
06-14-2016, 09:28 PM | #7 | ||
Rep 18,796
The only possible cause is, there is no sensor installed. Just using the valve stem.
06-15-2016, 12:27 AM | #8 |
Rep 1,181
^^^ That's my guess. I've had plenty of times where it took a few tries to reset the TPMS, but that's when it gets stuck at some percentage. To not even make it past zero makes me believe there are no sensors installed or incorrect ones are present.
07-19-2016, 09:41 PM | #10 |
Rep 62
I am getting the exact same problem from the exact same process. I bought some flea bay wheels and the vendor insists that they used factory TPMS. They requested my VIN and photos of my valve stems and then ordered the "correct factory sensors" causing a delay in delivery. My stems look the same as these photos and I get all the same warnings and failed measurements. Any more ideas from the crowd?
EDIT: In previous attempts I never got past 0% on the reset but this morning I got to 49% before I got the error message. Thanks, Patrick Last edited by newtlicious; 07-20-2016 at 07:13 AM.. |
07-20-2016, 07:18 AM | #11 |
Rep 275
OP here. The seller (a member on here) sold me "new take off wheels" when in fact they had been swapped with 2 faulty sensors. I ordered 4 new sensors from RGSPORT and all is perfect.
07-20-2016, 11:19 AM | #12 |
Rep 1,547
So happy we don't have to mess around with TPMS on BMW's in Canada. On the Canadian market vehicles, we use the ABS/wheel speed sensors to show an under-inflated tire.
07-21-2016, 06:50 PM | #13 |
Rep 62
UPDATE: An independent tire shop scanned my sensors and couldn't detect them at all. The vendor in CA insists that they are the correct model. I'm going to have to have the tires removed and new sensors installed (at my own expense) then mail the crappy ones back to Cali and wait to be refunded for the crappy sensors and an "industry standard" $120 in labor. All in all I will be out about $140 for the difference in cost for the sensors as well as an afternoon at the dealership which is a 4 hour round-trip from my house and a day off of work. I'm a little miffed about this...
- Patrick |
