      08-11-2017, 08:58 PM   #3609
Almaretto
Almaretto's Avatar
2373
Drives: Test Vehicles
Originally Posted by ramsal View Post
I think I found the answer to #2 above:
I thought I read everything but somehow I missed this one. Will try it now.
UPDATE: the above change enabled trunk lid close the key fob button but after a delay. Now I need to make the following change to close the trunk lid with just one press of the key fob button without a delay:
UPDATE 2: as it turns out the LONGPRESS_CLOSE was already at 00. I believe that to close the trunk with a single press, without delay, the "HKL_REMOTECONTROLLIFTGATEBUTTON_DELAY_CLOSE" needs to be changed. Will play with that later
If you update your Launcher Cheat codes, you will have my additions with these changes.
      08-14-2017, 10:50 AM   #3610
ramsal
Drives: 2017 X5 & 2018 M3
can someone ELI5 what the deal is with the CAFD files?
Is there a way to get newer versions (F025-17-03-510)? Where would I go to obtain/check for newer versions?
I'm trying to clear the trailer electrical system warning message and apparently I need to match my vehicles i-step version. Unfortunately the CAFD files that are available with E-sys are older thank what I need: F-25-15-XX-XXX (see post on pervious page).
2018 M3
2017 X5 35d xdrive Msport
Sold: 2014 X5 35i xdrive Msport
      08-14-2017, 02:30 PM   #3611
Almaretto
Almaretto's Avatar
2373
How to check I-Step.
  • F025-17-07-503
  • F025-17-07-502
  • F025-17-03-508
  • F025-17-03-505
      08-14-2017, 03:24 PM   #3612
ramsal
hey Almaretto,
Just realized that the way i worded my last post makes it look like i'm looking for F025-15-XXX files.
I'm actually after F025-17-03-510, do you have those?
2018 M3
      08-14-2017, 07:36 PM   #3613
anon1000
Drives: bmw
Originally Posted by atomic80 View Post
Yes...it now looks awesome at night! Barely visible during the day though.
BMW X5 interior at night by Jason Tang, on Flickr
hold on, those gauges. Is that a euro spec car, or how is that done???
      08-14-2017, 08:07 PM   #3614
ramsal
the gauges are a digital display that changes between comfort to sport, my 2017 came with them. The photo is showing the sport gauges.
2018 M3
      08-15-2017, 09:36 AM   #3615
Almaretto
Almaretto's Avatar
2373
hey Almaretto,
Never heard of that version.
      08-15-2017, 10:30 AM   #3616
ramsal
That's the version i get when I check the I-Step using E-sys
2018 M3
      08-15-2017, 03:33 PM   #3617
Almaretto
Almaretto's Avatar
2373
F025-17-03-510 – ISTA 4 4.05.3x
F025-17-03-508 – ISTA/P 3.61.5
      08-17-2017, 04:33 PM   #3618
bms5
Drives: 2010 335d, 2018 540d
Can someone send me a link for the latest files for Coding a June 2017 build X5 35d, please?
I currently have 3.62.1 psdzdata files on 3.28 e-sys. Are these new enough to use?
Thanks!
      08-17-2017, 04:35 PM   #3619
shawnsheridan
shawnsheridan's Avatar
Thanks!
PM sent.
      08-18-2017, 05:33 AM   #3620
sbyun07
South Korea
17
Drives: '17 X5 40d M Sport
any solution to fix this
this is my HU_NBT2 folder
only getting dots instead of the actual name
      08-18-2017, 06:52 AM   #3621
shawnsheridan
You have Trimmed PSdZData, which means either you do not use E-Sys Launcher to open E-Sys, or E-Sys Launcher has Incorrect Car Series, or E-Sys has Incorrect Target Connections.
      08-18-2017, 07:44 AM   #3622
sbyun07
South Korea
17
Wow, let me try to understand^^ sorry a newbie here.
I'm using
E-Sys 3.28.1
PsdzData v61.5 lite
E-Sys Launcher prem 2.7.1
and I'm opening
E-Sys launcher prem to run the program,
Selecting F15 as my car, and
Selecting F025 for targeting.
I did code others like lighting colors in BDC_Body, but
just this HU_NBT2 folder is .'s
      08-18-2017, 09:41 AM   #3623
shawnsheridan
I'm using
E-Sys 3.28.1
PsdzData v61.5 lite
and I'm opening
That all sounds correct and it should be working.
Are you using Connect via VIN and not Gateway?
What do you have under "Vehicle Specific Parameters?
      08-18-2017, 11:08 AM   #3624
sbyun07
South Korea
17
This is what I have and I just connect from here.
      08-18-2017, 11:14 AM   #3625
shawnsheridan
Ok, I have no idea. Maybe TokenMaster has not mapped the specific CAFD being used by your NBT2.
      08-18-2017, 11:16 AM   #3626
Almaretto
Almaretto's Avatar
2373
What is CAFD_ID?
      08-18-2017, 02:36 PM   #3627
bms5
The E-sys installation instructions indicate that Launcher Premium can only be used on one model type.
Since I have used it on my own F15, does that mean I could use it on another F15 VIN?
      08-18-2017, 02:40 PM   #3628
shawnsheridan
You can use on another F15 without waiting. You can use on a different chassis after waiting 3 days since selecting F15.
      08-18-2017, 04:55 PM   #3629
bms5
I connected to my neighbour's new 2017 X5 35d VIN 0Y16724 (build date June 2017).
I tried to code 'Close trunk via Keyfob/Inside button but my Function Values looked completely different than on the Cheat Sheet.
His X5 has an HKFM2 with CAFD file 00002098_010_002_004.
When I open 3010 I don't see any of SCH_FBD, SCH_TOEHKI or TASTER_FBD Function Values.
He also wants to have the mirrors fold in when locking but I am only seeing 'Side Mirror closing time delay' on the Cheat Sheet.
Any solutions?
      08-18-2017, 06:23 PM   #3630
sbyun07
South Korea
17
Originally Posted by Almaretto View Post
What is CAFD_ID?
I believe it's
CAFD_00001EF6
Search this Thread:
Advanced Search
