04-12-2022, 06:05 PM | #617 | |
Rep 24,950
The light phenomenon came from 2 big sensors under HAM's car . The sensors stored porpoising data and the distance from the floor to the asphalt . Mercedes stored the porpoising correlation between speed and the ride hight to the asphalt . HAM got one sensor under the front wing , and one sensor on the side of the floor .
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
4
04-12-2022, 06:15 PM | #618 | |
Rep 7,542
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242 |
irunalot1518.00 |
04-12-2022, 06:36 PM | #619 |
Rep 24,950
That is correct ,the thing is heavy for the size of it .
04-12-2022, 06:58 PM | #620 |
Rep 7,542
Yeah insane isn't it? I would think it's from the wiring and control boxes that aren't shown.
irunalot1518.00 |
04-12-2022, 09:58 PM | #621 |
Rep 3,245
What is weird...Ferrari seemed to be porpoising more than ever in Australia and they were blitzing the field. Merc definitely decreased their porpoising by a substantial amount and were still 1sec+ off Ferrari's race pace. Merc has other deficiencies in the car.
04-12-2022, 10:19 PM | #622 | |
Rep 7,542
1) Mercedes were porpoising exactly at the speeds they were cornering at, this caused cornering instability so they had to raise ride height to stop the porposing in the corners and limit it to the straights. This stopped porposing in the corners which allowed the car to corner without instability but the increased ride height robs them of down force decreasing cornering speeds. This is a double whammy because they porpoise exactly at the cornerning speeds they need. 2) Ferrari porpoises, but the speeds their car does it at is above the peak cornering speeds that their car can do, so they are fine in the corners. This means they mostly porpoise on the straights which is fine so long as their drivers can handle it. Thus they do not need to raise ride height as long as their drivers can handle it, and this means no down force is lost in the corners. So the higher the threshhold speed is for porposing the better off your car is, and that also means you can trade it in for a lower ride height. With lowering of the ride height decreasing the speed that porposing occurs at (because it makes it easier for the underfloor to stall). So if your car has a super high porpoising speed you can run really low. For merc their porpoising is so bad they have to run really high, and if they solve that they will get alot of performance back. For ferrari it wouldn't bring much performance back because they can already run at the optimal ride height - but it would bring driver comfort and thus consistency.
irunalot1518.00 |
04-13-2022, 03:27 AM | #623 | |
Rep 19,973
///M Power-Belgium64716.00 |
04-13-2022, 03:37 AM | #624 |
Rep 19,973
Just heard that Audi want to take control of an F1 team, they are not content to just playing a supporting role from '26 with it's own PU.
04-13-2022, 03:45 AM | #625 | |
Rep 19,973
Ferrari have a problem with Sainz while Checo is finally delivering. |
///M Power-Belgium64716.00 irunalot1518.00 |
04-13-2022, 04:02 AM | #626 |
Rep 7,542
I wonder who they will buy. Haas or williams are potential candidates. Maybe even aston if lawrence looses hope.
Killed by Death13212.00 irunalot1518.00 |
04-13-2022, 05:41 AM | #627 |
Rep 19,973
04-13-2022, 06:34 AM | #628 |
#buildnotbought
11123
Rep 4,930
I was wondering:
Has any of you heard of a protest that Alpine filed against Haas (before this race) about that certain parts on the Haas looked too much like Ferrari parts and that Haas had to change them? And that arguably the Haas cars werent as fast as previous races? I think I heard that on dutch tv by one of the commenters (ex F1 driver), but I can't find anything of this online. I know Haas has very close collaberation with Ferrari, and the FIA has a list of parts that can be shared, but these were apparently aero parts. Maybe not 100% the same but too much the same? It's unclear to me
Z4 3.0i | ESS TS2+ supercharger | Quaife ATB LSD | Brembo/BMW performance BBK front/rear | Schrick FI cams | Schmiedmann headers+cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers/KW camber plates | Sachs race engineering clutch | tons of custom sh#t
///M Power-Belgium64716.00 M5Rick61854.00 |
04-13-2022, 08:03 AM | #629 | |
Rep 3,672
04-13-2022, 08:19 AM | #630 |
Rep 3,672
TECH TUESDAY: Why gearbox layout could be key to solving the porpoising puzzle
https://www.formula1.com/en/latest/a...XsoXdlwQE.html |
04-13-2022, 09:32 AM | #631 | |
Rep 10,084
04-13-2022, 02:40 PM | #632 |
Rep 3,672
04-13-2022, 02:44 PM | #633 | |
Infinite Boulder Roller
585
Rep 413
They are close - but lack the marketing/brand glitter that can help a team make up for $$$ shortage.... putting every piece together to climb the success ladder. |
04-13-2022, 04:48 PM | #634 | |
Rep 24,950
Audi did a new 650 million Euro bid , first bid was 500 .
4
04-13-2022, 04:49 PM | #635 |
Rep 7,542
But mclaren doesn't want to lose any control so I don't think that will work out well.
irunalot1518.00 |
04-13-2022, 04:56 PM | #636 | |
Rep 24,950
Everything is taken apart because there can be damage from the fire .
04-13-2022, 04:58 PM | #637 |
585
Rep 413
04-13-2022, 05:00 PM | #638 |
Rep 24,950
Yep . So it is for the moment . But there are 3-4 years to go .Time will tell ...
