03-31-2021, 08:12 PM | #243 | |
Rep 535
Initial bite is noticeable. Just thought I'd pass along. |
04-01-2021, 02:08 AM | #244 | |
Lamininist
84
Rep 1,030
Thanks for the honest feedback 👍 |
04-01-2021, 06:41 AM | #245 | ||
456
Rep 352
2016 BMW X5M F85 | 2019 - Present
2015 BMW X5 F15 5.0i m-sport | 2016-2019 2001 BMW X5 3.0i Sport | 2005 - 2008 |
04-01-2021, 10:45 AM | #246 |
Rep 1,040
Drives: BMW X5M, M3 ZCP, MB E63 AMG
There is always a compromise between Semi-Metallic pads vs Carbon Ceramics. Initial Bite vs No Dust. For me, I will take no dust over initial bite.
04-01-2021, 10:49 AM | #247 | |
Rep 535
I've since also powder coated both my summer and winter setups (black) so dust doesn't bother me as much. The performance for me further degraded in the rain, and I'm an aggressive driver so just couldn't keep with them. |
04-02-2021, 07:53 AM | #248 | |||
Rep 417
If you need the rear pads for the f85 power stop ceramic I have a brand new set for 50 bucks since I upgraded my rear brakes to Porsche. Dm me if anything.
ACID.
04-02-2021, 06:04 PM | #249 |
199
Rep 363
I just put the PowerStop pads on today - front and rear. The pedal feel is going to take a lot of getting used to since it feels like a luxobarge’s brakes. But the sound, or more importantly the lack thereof, is heavenly. I only put about 25-30 miles on them, but the lack of firmness in the pedal is very different.
2017 X5 ///M
2019 X3 XDrive 30i 2003 Porsche C4S |
Klienfeld303287.00 |
04-02-2021, 06:20 PM | #250 | |
Rep 417
ACID.
04-03-2021, 09:17 PM | #251 |
166
Rep 381
Interesting everyone's view point on this! So I'm a custom wheel guy and aesthetics guy and nothing more than an aggressive driver at times. I owned my F86 for less than a month and said F this the dust and squeal alone and coming from an E70 X5M Obv no different actually there was less squeal only in reverse for some reason but anyways No way, me personally I will take less bite and what's discussed about pedal feel vs cleaning a stock 21" wheel or what's even more challenging with a custom set daily literally vs what's now monthly on power stop pads or whatever
04-04-2021, 10:23 AM | #252 |
Rep 1,233
Ceramic
Anyone ceramic coating their wheels and calipers?
My rig is in the shop and will have ceramic coated wheels and calipers when completed. Hoping that the wheels stay cleaner since I'll be using stock pads because I want as much bite as possible as an aggressive daily driver. Now that the weather is getting nicer, I'm okay with a weekly or so touch-up if necessary. The squeal on the other hand... Might need to crank the tunes that much more! |
04-04-2021, 10:51 AM | #253 | |
Rep 417
ACID.
m3fuz199.00 |
04-04-2021, 06:33 PM | #254 | |
Rep 1,233
I hear you
Thankfully curb rash has not been a thing for me. I'm only in urban areas every so often. When I am I'm on pothole and curb alert though! Since I'm new to driving this rig, I park like I have no idea what I'm doing whereas I would just throw my current SUV into the spot in a NY second. My wheels and calipers will be powder coated. The ceramic coating is like a permanent wax for your paint, so brake dust and dirt and debris is less likely to stick and usually can be removed easier. At the very least, it's a good idea to have your wheels thoroughly waxed. Inside the barrels and everything. That way they'll be a little slicker to avoid build-up and/or they will hopefully clean up that much easier. |
04-06-2021, 07:54 AM | #255 |
Rep 1,040
One of the drawbacks to carbon ceramic pads is the lack of initial bite. As I was driving into work today, I had to get of the brakes extremely hard as the traffic came to an abrupt stop. It would have been nice to have it. Luckily I didn't hit the vehicle in front of me
I have to learn to give myself more stopping distance, as I get use to these pads.
04-06-2021, 08:52 AM | #256 | |
224
Rep 379
Blue By You631.00 |
04-06-2021, 09:17 AM | #257 |
Rep 1,040
Also ceramic coatings don't last forever, it must be applied again and again. And it can be expensive to have it professionally done.
04-06-2021, 09:40 AM | #258 |
Rep 271
Hmmm....my F85 had schoolbus squealing brakes prior to taking it in in May 2020 for the last service where they changed the front pads/rotors. It's been squeak free since then where maybe I heard a whiff of a faint squeak once or twice. I wonder if it has something to do with worn pads and the pistons being extended a lot and perhaps pushing them back in and replacing the pads will help. I also recall when I first serviced the brakes on my e39m5 years ago (bought second hand, so whatever maintenance it had prior was unknown to me) and there was this red, dried, rubbery substance surrounding the piston/perhaps on the entire back of the pad. It looks like it might be this:
https://www.amazon.com/CRC-05016-Sin...V88/ref=sr_1_2 I wonder if using that with stock pads will work. I have a set of new powerstops waiting to go on, but after hearing these reviews that pedal feel is mush (could that be from the rubber coating on the shims?) and stopping performance might be diminished, I'm not sure if I want to install them... |
04-06-2021, 10:45 AM | #259 |
Rep 1,040
These are similar pads that I have on my E63, and they work great. I think that since, the rotors and pads are new they haven't fully bedded in yet. I also coated the contact areas of the pads and calipers, to eliminate squeaks. So, I think that rubber coating was that.
04-19-2021, 10:30 PM | #260 | |
Rep 1
I'll go with your recommendation on the EBC Yellowstuff pads - I trust there's been no performance issues? |
04-20-2021, 07:34 AM | #261 | |
199
Rep 363
2017 X5 ///M
04-20-2021, 08:04 AM | #262 | |
Rep 1,247
After I got used to it on that car, I actually liked them better. When throwing it around the twisties on and off the brakes, I felt they were much better and more forgiving. If you hit the pedal a little harder than expected it did not put you thru the windshield or dig the front in too hard. I could pulse the brakes better for the desired effect without worrying about that sharp bite. I have had 3 cars since then and put these on them immediately even when they were not needed. I have them on my X5 too. I'll stick with them till I find something I like better. I have 1,000% confidence in my brakes.
04-20-2021, 09:15 AM | #263 |
Rep 1,040
I have Power Stop Carbon Ceramic Pads on both my X5M and E63 AMG, and I absolutely love them. As everyone has stated, you lose the initial bite but the trade off is that, their more rotor friendly and no brake dust.
Not having to clean the wheels every few days is great. I wouldn't go back to semi-metallic pads for anything.
06-08-2021, 08:44 PM | #264 |
Rep 19
1 week behind me now with Power Stops all around. I did not notice as big a bite difference as most have stated. I absolutely LOVE them. No squeal and no (very little) brake dust! I can finally drive amongst people and not be embarrassed that this 100k+ car sounding like something out of a junkyard. I will recommend these to everyone.
Slickrick2211.00 |
