11-10-2016, 10:23 PM | #2883 |
Rep 8,364
PSA: New Launcher & NCD / CAFD tool released. Includes Hi-res Fix & mapping for new ECU's (eg, IHKA2 = CAFD_000047D6; HKFM2 = CAFD_00002098).
11-12-2016, 06:47 PM | #2886 |
Rep 96
Drives: 2010 335d, 2018 540d
I just purchased a 2015 X5 35d M-Sport and am excited about coding. I just received my cable from R33_RGSport. Can someone send me the links for the software I need, please?
Thank you! |
11-12-2016, 07:18 PM | #2887 |
Rep 41,229
PM sent.
11-12-2016, 09:25 PM | #2888 |
Rep 96
Thanks very much, Shawn!
11-13-2016, 02:15 AM | #2889 |
Rep 3
11-13-2016, 08:31 AM | #2890 |
Rep 176
Logo on HUD F16
I'm trying to change the logo on the start up hud. When i change it in BMW_Logo in Kombi nothing is changing in the HUD, it is only changing the logo on the digital cluster.
Can i change the logo on HUD startup? If so, where can i change it? |
11-13-2016, 09:28 AM | #2892 |
Rep 41,229
11-13-2016, 11:12 AM | #2894 |
Rep 591
I coded the halo angel eyes to 100% per instructions here in the forum for the 4 FDLs how will long it take to become effective? I verified that the coding went through but testing right after coding I didn't see the desired outcome, which is 100% brightness with lights on.
11-13-2016, 05:46 PM | #2895 | |
Rep 8,364
11-14-2016, 06:55 AM | #2896 | ||
Rep 591
MAPPING_STANDL_V_R_PWM_1_STANDARD MAPPING_STANDL_V_L_PWM_1_STANDARD MAPPING_PARKL_1_V_L_PWM_1_LEFT MAPPING_PARKL_1_V_R_PWM_2_RIGHT Last edited by HZX540e; 11-14-2016 at 08:22 AM.. |
11-14-2016, 02:16 PM | #2897 | |
Rep 8,364
HZX540e373.50 |
11-17-2016, 04:35 AM | #2898 |
Rep 481
There is an option (idrive) to automatically lock the doors after a certain amount of time. This option ensures that if you forget to lock your car, it will be done automatically. What is the delay time? Can this be coded (couldn't find it in the cheat sheet).
11-17-2016, 07:08 AM | #2899 | |||
Rep 591
11-17-2016, 08:40 PM | #2900 |
Rep 65
I think that setting is to re-lock the doors if they've been unlocked but not opened after already being locked. It will not automatically lock the doors if they were not previously locked.
11-18-2016, 09:54 AM | #2901 |
Rep 185
Hey Guys,
I just got a 2016 40e, downloaded e-sys 3.28 and 2.6.2 launcher. I was able to see all the CADF when I connected to the car and all looks well, I backed up the CADF files. I haven't changed any settings yet, as I`m a little worried. Primary I just want to change few settings based on the cheat sheet. I`m a little confused about NCD / CAFD Tool what does it do and what do I need it for? Also I keep seeing reference to EDIABAS.INI file which I do not have, but I`m assuming since I was able to connect to the car its fine ? Other big concern is the ISTA/P version I guess, I`m using provided PSdZData lite from file pszdata_v3.60.1.003_lite... is that the latest and fine for my 40e ? I`m a little stuck on how to verify my version compared to the downloaded files... Also everywhere it says that this file should be pretty big(pszdata_v3.60.1.003_lite), but I`m only getting about 2gig when extracted is that right ? I want to try to code it tonight, would really appreciate some feedback before I do something wrong... Sorry if I sound like a total noob, just want to be careful with a new car.... |
11-18-2016, 10:27 AM | #2902 | |
Rep 8,364
EDIABAS is part of BMW Standard tools. It is also not needed for E-sys. It is used for ISTA+ and ISTA-P. Psdzdata comes from ISTA-P. Full version (~60-80 GB) contains 9 additional folders (%\Psdzdata\swe) and is used for flash programming. From full, lite (~2GB) is created and all that is needed for VO and FDL-Coding. |
11-18-2016, 11:04 AM | #2903 |
Rep 591
Halo brightness to 100% help
I have an x5 40e and I've been trying unsuccessfully to code the halo rings to remain at 100% all the time. Right not they are 100% only when DRL or parking is on. They dim when the low beams are on. Any help or insight is greatly appreciated. I read that some have been successful on doing so on other models, has anyone done it on the F15? What do I need to change in addition to the four codes I listed few posts ago?
11-18-2016, 12:13 PM | #2904 | |
Rep 185
Just to make sure about pszdata_v3.60.1.003_lite, is this the correct one to use for my car ? Is that the latest ? Or do I still need to compare versions with my car ? I`m a little confused about that part... |
