02-10-2017, 05:33 PM | #3169 |
Rep 648
Drives: 2016 F15, 2015 F83
02-10-2017, 05:41 PM | #3170 |
Rep 84
02-10-2017, 05:42 PM | #3171 |
Rep 648
02-10-2017, 06:33 PM | #3172 |
Rep 5
Has anyone had any luck with coding the anti dazzle led lights on a 2017? I removed 5AP and 8S4 from the FA/VO and VO coded BDC_BODY, KAFAS2 and both FLE ECUs. After that I used the cheat codes to do part 2.
Do you need to wait a period after coding for the car to updated? Any help would be much appreciated. Thanks. |
02-10-2017, 07:02 PM | #3173 | |
Rep 8,364
I just end up updating my Launcher Cheat Codes for values. Also, if you have ID5, code H-H2: 5_FACH_TIPPBLINKEN = 01 View post on imgur.com |
02-10-2017, 07:36 PM | #3174 | |
Rep 5
02-11-2017, 06:17 AM | #3175 | |
Rep 9
I don't seem to have; (which section is it in?)
02-11-2017, 12:04 PM | #3176 |
Rep 8,364
02-11-2017, 03:01 PM | #3177 |
Rep 9
02-11-2017, 06:00 PM | #3178 |
Rep 8,364
02-12-2017, 11:18 AM | #3179 |
Rep 9
02-12-2017, 01:50 PM | #3180 |
Rep 8,364
02-12-2017, 02:34 PM | #3181 |
Rep 9
02-12-2017, 04:24 PM | #3182 | |
Rep 30
02-12-2017, 04:33 PM | #3183 | |
Rep 8,364
There is no direct way, of which I am aware, to search entire vehicle (ie across multiple ECU's). As an aside, you could do the following if you really wanted:
You also should be using Launcher Cheat Codes |
Howi0.00 |
02-12-2017, 04:37 PM | #3184 |
Rep 8,364
02-13-2017, 03:43 AM | #3185 |
Rep 30
02-13-2017, 12:17 PM | #3186 |
Rep 18,794
Almaretto , PM me your email address, I'll add you into the cheatsheet so you can update on your new finding on iDrive5.0.
I did found a few items over the weekend too, I will update by the end of the week or earlier if I can catch up with work.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com Memorial Day SALE!! 05/24 - 06/03 • Coupon Code: "MEMORIAL" MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
02-15-2017, 07:02 PM | #3187 |
Rep 3
How do you find new items? Is it just trial and error? Or is there an established safe procedure for this?
02-15-2017, 07:58 PM | #3188 | |
Rep 8,364
I have vehicle files from every Fxx- / Ixx- / Gxx-series BMW. View post on imgur.com |
02-15-2017, 10:25 PM | #3189 | |
Rep 18,794
And play around with it.
02-15-2017, 11:49 PM | #3190 |
Rep 96
Drives: 2010 335d, 2018 540d
Is there a definitive way to determine which modules need coding after a VO change. I am adding 5A1 to my VO so I know I need to code BDC but how do I know if any related modules need coding?
