06-25-2023, 09:25 PM | #311 |
Rep 41,224
FA Null is a VIN issue.
I do not know what is up with the psdzdata ethernet Topology error is.
08-07-2023, 12:45 AM | #312 |
General of the Armies
156
Rep 657
I got my iDrive flashed, but I need to activate the headunit now? I know this is possible in ISTA, but for some reason I don't have the software update option available in ISTA+. Programming is enabled, as is programming over ENET in the configuration file for ISTA. I have all the sp_daten files loaded.
Why can I not activate my HU via ISTA? Does this require an ICOM? Is there any other way to do this? |
08-07-2023, 08:52 AM | #314 |
156
Rep 657
I did use esys for the flash. But after the flash I am now stuck with a head unit that needs to be initialized. That initialization is in the INPA+ Software Update screen (which is grey for me and I can’t get there) but it isn’t a flash.
Why would my INPA+ software update be unavailable? Is there any other way to initialize my HU? |
08-07-2023, 09:41 AM | #315 |
156
Rep 657
Ah, ISTA+ was looking at a registry key for enabling programming and not paying attention to the .configuration file. Updated the reg key and software update became active.
08-07-2023, 12:16 PM | #317 |
156
Rep 657
I flashed the Head Unit to go from ID5 to ID6. After flashing the HU it behaved like it was a factory fresh part, and needed to be initialized which is a simple process in ISTA+ in Software Update, Additional Software, Initialize HU. I think this only supposed to happen if you get a new factory fresh HU installed. Not sure, but mine did it.
All my googling shows only a couple people had this happen (who posted about it). It's an easy extra step, but you need a functional ISTA+ install which was what I was fighting. |
SaNGRia996.50 |
08-20-2023, 01:43 AM | #318 |
Rep 7
Good afternoon . Before updating nbtevo from version N to version Y, Car play work, but not in full screen, after updating and coding (APPLE_ENHANCEMENTS => aktiv
HMI / HMI_39_39_128 => active; id6_light) car play did not appear even after the reboot. please tell me what to do next? |
08-27-2023, 05:28 PM | #320 |
Rep 12
Hello all,
So I tried updating today but after flash navigation is stuck on loading and I have check engine light? Previously I was on NBTEvo_L and had CarPlay activated using USB method. Do I need ISTA to clear fault codes? I can’t even check to see what version it is on since navigation is not accessible. Any help would be greatly appreciated. Thanks in advanced |
08-27-2023, 05:44 PM | #321 | |
Rep 41,224
08-29-2023, 08:00 PM | #322 | |
Rep 563
Trying to flash, vin error went away by using read VIN out of FA setting, but I keep getting this gateway issue: |
08-29-2023, 08:15 PM | #323 |
Rep 41,224
If using an ENET Cable, Flash by VIN not Gateway URL.
08-30-2023, 06:39 AM | #324 |
Rep 563
I'm trying to flash nbtevo retrofit (hw4) into e92 m3 using enet. So the ethernet pins are connected to the nbt directly through OBD2 port. Not sure if I'll be able to get connection via VIN to work?
08-30-2023, 06:41 AM | #325 |
Rep 41,224
Ok. Probably not. I have no idea on flashing in E-Series car.
The-Traveler139.00 |
08-30-2023, 05:39 PM | #326 |
Rep 2
Awesome! great effort
I was searching for such amazing guidelines for a long time and finally got it. I will test it as soon as I download the PSDzdata full and will update you |
09-02-2023, 03:59 PM | #327 |
Rep 1
Navigation greyed out (novice)
I've just completed the flash, but upon the screen coming back on, the navigation isn't clickable? Does anyone know what would have happened and what I can do to resolve this please? Thanks
09-19-2023, 07:07 PM | #330 |
Rep 1,353
That cant be done on the car. You will need a bench setup to VIN flash a retofitted HU! Plus VIN flash will not be enough to retrofit since you will need FSC Pack as well!
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit |
