06-26-2019, 07:06 PM | #353 | ||
OEM CSL Whore
1255
Rep 1,476
5
06-26-2019, 07:40 PM | #354 |
Rep 143
06-26-2019, 08:12 PM | #355 |
OEM CSL Whore
1255
Rep 1,476
r33_RGSport13128.00 |
07-07-2019, 08:23 PM | #356 |
Rep 651
I ended up getting another set of spacers from Ben.
The new wheels despite their more aggressive ET, still needed a bit more.. (I would probably not need spacers if I rode on stock springs though) 15mm for the rear 20x11 ET22 wheels and 5mm up front on the 20x10 ET30 wheels. I could almost run a 15mm spacer up front also, but it makes the front lip look way to narrow. |
07-11-2019, 09:57 AM | #358 |
Rep 18,795
PM'ed.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com Memorial Day SALE!! 05/24 - 06/03 Coupon Code: "MEMORIAL" MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
08-10-2019, 11:08 AM | #359 |
Self-Deprecating Narcissist
7274
Rep 6,561
F85 spacers with 612M wheels and bolts available? I only see spacers listed and whichever wheel bolts I find they are all for aftermarket wheels.
08-10-2019, 12:14 PM | #360 | |
Rep 18,795
The lug bolts listed on my website are for when you use wheel spacer. H&R sells the lug bolts separately, that's why I have it as an option on my website. I got a few cases where the customer thinks that my price is high where others quoted them without the lug bolts. For F85 with 612M, I recommend 5/12 for conservative setup and 15/15 for flush setup.
08-10-2019, 01:06 PM | #361 |
7274
Rep 6,561
I would like to do 15/15 and bolts. Care to send over a quote?
08-10-2019, 02:14 PM | #362 |
Rep 18,795
PM'ed
08-16-2019, 08:02 AM | #363 |
7274
Rep 6,561
Dinan Spring & Handling Kit with 15mm spacers for the front and rear. Purchased through Ben at RGsport.
08-16-2019, 08:53 AM | #364 |
OEM CSL Whore
1255
Rep 1,476
iconoclast7273.50 r33_RGSport13128.00 |
08-16-2019, 11:13 AM | #365 | |
Rep 18,795
Thank you for the kind words.
iconoclast7273.50 |
08-16-2019, 11:17 AM | #366 | |
Rep 41
I have 22 612m reps in the mail along with some 20mm rear spacers from Ben. Cant wait. |
08-16-2019, 02:16 PM | #367 |
7274
Rep 6,561
Yes, they are the OEM 612M. The spacers show on profile shot and where I notice it the most if you compare it to the same spot, same car, with/without.
08-16-2019, 05:59 PM | #368 |
Rep 530
Drives: 2020 BMW X5 MSport Arctic Grey
I think what he is saying is from the side you can't tell if you have them or not. The spacers can only really be seen from the rear or some 3/4 shots. You can't tell the depth from a side shot.
iconoclast7273.50 |
08-19-2019, 01:41 PM | #369 |
7274
Rep 6,561
15mm Spacers All Around:
parkstr8562.00 r33_RGSport13128.00 |
08-19-2019, 06:36 PM | #370 |
OEM CSL Whore
1255
Rep 1,476
08-19-2019, 09:49 PM | #371 |
7274
Rep 6,561
you're absolutely right. i think the pairing goes well. if i were to lower i would do 20mm front and 25mm rear to get the flush effect but for this application it lands perfectly for my objective. i am pleased with the results and ben was great as usual. professional and prompt. could not ask for more.
08-20-2019, 03:31 AM | #372 |
Rep 147
I have a 2014 without the extended fender flares. Most photos seem to show pictures with the extended fender flares. So, my question is would the 5/15mm setup with 19inch wheels stick out too much, or would it be about right. Planning on doing this when lowering with Eibachs.
08-20-2019, 09:11 AM | #373 | |
Rep 18,795
And there are square 19" and staggered 19". I will need more information to give you a suggestion on which spacer to run.
