      07-28-2019, 08:42 PM   #23
satish1015
Drives: BMW F85 X5M
Originally Posted by spacejamm_x5m View Post
Originally Posted by satish1015 View Post
What is the purpose of the bump stop and would removing it cause any issues in the future?
They are just used to assist in the case that your suspension bottoms out due to a heavy heavy toe or load. That's it.
So now that it's riding better that means that the suspension isn't hitting the bump stop anymore and is now hitting something else? Curious because I like the ride height and I'm about to install mine.
      07-28-2019, 09:57 PM   #24
F85MTuNED
IG: @88jae88
F85MTuNED's Avatar
1624
Drives: ///Ⓜ️
Originally Posted by F85MTuNED View Post
Shit looks like somebody beat me to it lol..dope color and the car sits perfect 🔥
If I keep her I just might 💪🏽
IM POOR..
      07-29-2019, 06:17 PM   #25
spacejamm_x5m
spacejamm_x5m's Avatar
Drives: 16’ X5M
The bump stops are huge. Lol. I'm not hitting anything now. I don't bottom out or anything
Phara107.00
      07-30-2019, 02:32 AM   #26
daytonaviolet
OEM CSL Whore
daytonaviolet's Avatar
Philippines
1255
Drives: 2017 F85 X5M
So did you take them out completely or just cut them down to size. Perhaps I should of tried this before getting kw 🥴
      08-07-2019, 03:30 PM   #27
Phara
Drives: BMW X5M F85 2018
Originally Posted by artgo View Post
Car looks perfect! Nice job. What wheels are those?
Signature Performance
Are these 21"?
      08-07-2019, 06:12 PM   #28
F85MTuNED
IG: @88jae88
F85MTuNED's Avatar
1624
Drives: ///Ⓜ️
I'm wondering if I do this would I be good for these NYC / NJ / PA roads...
IM POOR..
      08-07-2019, 06:20 PM   #29
spacejamm_x5m
Drives: 16’ X5M
Nashville is worse than NY
iconoclast7273.50
      08-07-2019, 11:37 PM   #30
F85MTuNED
IG: @88jae88
F85MTuNED's Avatar
1624
Drives: ///Ⓜ️
Nah no way...you serious?!?!? Lol
IM POOR..
      08-08-2019, 09:03 PM   #31
theone_06
theone_06's Avatar
Drives: BMW x5m 2015
2015 BMW X5M  [0.00]
Originally Posted by daytonaviolet View Post
So did you take them out completely or just cut them down to size. Perhaps I shouldn't of tried this before getting kw 🥴
hihi :S I might try that when I get yours
      08-09-2019, 07:26 PM   #32
spacejamm_x5m
Drives: 16’ X5M
Are these 21"?
22s
Phara107.00
      08-09-2019, 07:27 PM   #33
spacejamm_x5m
Drives: 16’ X5M
They are completely gone.
      08-10-2019, 08:17 PM   #34
musa
musa's Avatar
Drives: F86, E92, E53, E39.
You must be referring to part #3 (Auxiliary damper w.protective tube rear) in this diagram of the rear suspension, no? Yeah, it's pretty long. So you were reassured it's fine without it? What would happen if you accidentally hit a bump/speed-bump or pot hole at speed, say 40mph?
      08-10-2019, 08:23 PM   #35
spacejamm_x5m
Drives: 16’ X5M
You must be referring to part #3 (Auxiliary damper w.protective tube rear) in this diagram of the rear suspension, no? Yeah, it's pretty long. So you were reassured it's fine without it? What would happen if you accidentally hit a bump or pot hole at speed, say 40mph?
No. It's literally a "bump". I'll get a picture of it
      08-10-2019, 08:28 PM   #36
musa
musa's Avatar
Wow, what would it be? I see nothing else in this complete technical diagram of F85 rear axle. Or may be you saw it without its protective tube?
https://www.realoem.com/bmw/enUS/par...BMW-X5_M&mg=33
      08-10-2019, 09:04 PM   #37
musa
musa's Avatar
Oh, I got it. It's the bump stops that come with HR spring kit as depicted in this pic of 23008-1 VTF Adjustable Lowering Springs, right?
      08-10-2019, 09:57 PM   #38
daytonaviolet
OEM CSL Whore
Philippines
1255
Well that's just it.. the HR Vtf kit didn't come with any bump stops 😩
      08-10-2019, 10:36 PM   #39
musa
musa's Avatar
You're indeed correct per H&R pic of the kit.
http://www.hrsprings.com/application...s/4/1767/2018/
      08-22-2019, 10:16 AM   #40
StatenEye
Drives: X5M F85
2016 BMW X5M  [0.00]
2011 BMW X5M  [9.00]
Hey is the bump inside the airbag itself? Confused to where it would be. About to do this install.
      08-22-2019, 10:27 AM   #41
spacejamm_x5m
Drives: 16’ X5M
Hey y'all. I'm going to get pics of the bump stops
      08-22-2019, 10:39 AM   #42
StatenEye
Drives: X5M F85
2016 BMW X5M  [0.00]
2011 BMW X5M  [9.00]
Great thanks and I'm assuming/hoping its in the boot on the strut. Hoping its not somehow in the airbag itself.
      08-22-2019, 10:40 AM   #43
spacejamm_x5m
Drives: 16’ X5M
It's NOT the airbag at all. Stand by
      08-22-2019, 06:21 PM   #44
musa
musa's Avatar
Correct, it can only be the above mentioned part #3 which sits between the struts and the strut mounts. It's called the Auxiliary damper and is inside the protective corrugated rubber boot - part number 33537850217. There's nothing else in the entire rear axel. It's not much different than the rear suspension of my X5 E53 in which I overhauled myself the entire suspension system of the vehicle, installing the E53 HR springs and links.
In any case, I'm planning to do the same mode with VTF HR springs on my F86. Your F85 looks amazing. But I think I will shorten this auxiliary damper rather than remove it entirely.
Here's a pic of it I found on the web.
