12-25-2019, 08:32 PM | #25 |
Rep 648
Drives: 2016 F15, 2015 F83
2016 F15 X5 50i M-Sport
2015 F83 M4 |
02-27-2020, 09:03 PM | #26 |
Rep 138
Did anyone ever figure this out? I'm sure there's a way to do it in Bimmercode Expert Mode. It's a matter of finding which value in the ICM menu to change, the ICM Module/ 3000 Daten/ IcmKod_B_Sportlenkung/ verbaut value they change on f30s doesn't exist on our ICM module.
02-28-2020, 12:49 PM | #27 | |
Rep 2,528
02-29-2020, 08:23 PM | #28 |
Rep 138
03-01-2020, 09:19 AM | #29 | |
Rep 7,586
EDIT: for my application, welcome lights is controlled by the FEM (perhaps its different if your BMW uses a different module)...but coding welcome light to illuminate during daylight is the 4th selection down from the top. If you wan't welcome lights in darkness only...then select ACTIVE...if you want welcome lights during daytime, too...then select NOT ACTIVE:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 03-02-2020 at 10:16 AM.. |
03-02-2020, 12:33 PM | #31 | |
Rep 138
03-02-2020, 12:42 PM | #32 |
Rep 2,528
Can you ask in the Bimmercode coding thread? You might be able to find you answer there
https://f15.bimmerpost.com/forums/sh....php?t=1391908 |
03-03-2020, 11:42 AM | #33 | |
Rep 7,586
If you have the app and the adapter...just hook it up and check what is available under welcome lights for your model and module. EDIT: just out of curiosity...I went to the BimmerCode website and looked under SUPPORTED cars (selected the f15 X5)...and went to the WELCOME LIGHT section...and this is what's listed (see below). Have you checked for this option after opening the app? It appears to be the same easy code as for the BMWs with the FEM...except its the 2nd one down from the top...and selecting NOT ACTIVE will allow the welcome lights to illuminate during daylight.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 03-03-2020 at 11:49 AM.. |
scotty339147.00 |
03-04-2020, 08:53 PM | #34 | |
Rep 138
03-04-2020, 10:42 PM | #35 |
Rep 7,586
Glad you found it. I wonder why the Bimmercode website inaccurately shows it being available for the f15 on the regular side of coding (like pictured in my reply above).
04-27-2021, 05:36 AM | #37 |
Rep 18
BimmerCode not connecting
Any suggestions?
My BimmerCode app is not connecting to the phone Bluetooth. I recently installed Wireless Carplay unit behind the HU. Is that the reason and how do I go about it ? |
04-27-2021, 07:12 AM | #38 |
Rep 1,497
If you have the hardwire cables (eth to obd, then eth to lightning) I'd try that. That being said I always use hardwire and sometimes it can be finicky to connect. I have to restart my phone often.
04-27-2021, 07:31 AM | #39 |
Rep 1,703
Drives: 2014 428i and 2018 X5
Contact the author of BimmerCode for support.
