05-07-2024, 11:37 AM | #23 |
Rep 32
The late F15s have the white telematics module directly below the roof antenna above the headliner. If yours was originally in the left side of the trunk, you're not going to have that.
You put in a replacement module, did you code it to the car? That must be done. |
05-08-2024, 06:44 AM | #24 |
Rep 7
i bought a replacement , then i found the original in a different location that had been ripped out , so i put that original back instead. however the replacement does the same as the original no mic , no voice commands,no mic during calls everything else works , when i put in the replacement i did code it with protool (code to car factory vin) so maybe i need to buy another mic first ?
so 2 of them are doing the same thing ,and yes its 2014 so nothing under the fin apart from antennas thanks |
