04-17-2019, 12:40 PM | #23 | |
Rep 535
https://www.ebay.com/itm/BMW-F-SERIE...53.m2749.l2649 This wiring loom works as long as you don't have to upgrade the software on your NBT HU. Its fully plug and play with an ATM and you will get connecteddrive services etc like RTTI. Looks like the seller updated the wiring to work with software upgrades too. If you don't get an ATM, you can get a GPS emulator or wait till you find one. If you are on NBT, this isn't easy. Most of it is documented in parts everywhere and depends on the situation, so a DIY isn't going to help much.
Present: 2014 X5 50i
3rdRow;ACC;HK;HUD;X5M Filters;Bootmod3;FenderFlares;NBTevo6+ATM+carplay; MPBK;612m;X5M-CF-rear-view-mirror-cover;ALPjammer;eurostyle-mirrors Past: 2013 750i xdrive, 2008 535xi Last edited by sj22; 04-17-2019 at 12:53 PM.. |
anki122.50 |
05-08-2019, 03:08 AM | #25 |
Rep 170
@sj22 i recently did an nbt evo retrofit thru bimmertech using an atm emulator. Yes it sucks we dont have connected drive service working. Are you saying if i source an NA ATM, and the CAN wiring from ebay, its possible to have connected drive working?
05-08-2019, 12:39 PM | #26 |
Rep 535
See my reply to your pm. Absolutely. The only things that arent working for me is lock/unlock from iphone and send to car. Everything else works.
05-28-2019, 10:41 PM | #27 | |
Rep 590
05-29-2019, 12:53 AM | #29 | |
Rep 535
There are just 2 big parts- the donor Hu and the donor atm. Once you get those, rest is relatively easier. Tons of people on the F30 threads doing this. |
CatalinP591.00 |
05-29-2019, 09:16 AM | #30 |
101
Rep 302
Is there some kind like a DIY on how to do this retrofit and a list of everything needed. I would like to do this. I am reasonably mechanically inclined. If I could do this myself (Except Programming) it would be awesome.
RUN FLAT TIRES? NEIN DANKE!
05-29-2019, 09:21 AM | #31 |
101
Rep 302
Silly question.... But what is an ATM? The ATM I know gives you money when you stick your card in it!!!
05-29-2019, 11:00 AM | #32 | |
Rep 887
https://www.bimmer-tech.net/blog/ite...trofit-carplay From what I understand, anyone looking to retrofit updated HU/iDrive from 4, needs to either source a new Telematics module or emulate. |
Kraftwerk AG460.00 |
05-29-2019, 08:20 PM | #33 | |
101
Rep 302
Cool, thanks for the info.
05-29-2019, 09:27 PM | #34 |
Rep 7,167
Hmm Money machine is not where my mind went first...dang it. Time to go back to church.
Russmov1328.00 |
05-29-2019, 09:52 PM | #35 |
Rep 1,343
Lmfao
05-30-2019, 12:56 AM | #36 | |
Rep 535
NBT used TCB modules for data so they cannot be used. May I suggest buying a full kit and doing the install from bimmerretrofit/codemybimmer or one of the big vendors who collect all the right stuff and then just ship it to you? It may be only $300-$500 more but you will get everything that you know will work together.
05-30-2019, 01:16 AM | #37 | ||
OEM CSL Whore
1255
Rep 1,476
05-30-2019, 06:55 AM | #38 | |||
Rep 7,167
daytonaviolet1254.50 |
05-30-2019, 07:39 AM | #39 | |
Rep 1,270
If you want a dedicated wlan hotspot, bmw sells one that fits in the snap-in connector in the central console... |
05-30-2019, 04:53 PM | #40 | ||
OEM CSL Whore
1255
Rep 1,476
05-30-2019, 07:47 PM | #41 | |
Rep 535
If ATT on your phone is asking you for $ to allow tethering to share your data with your car, its upto you. You can "program" the car to use bluetooth data from your phone for some things. If ATT is asking you $ to share the data from your car, its upto you. The WLAN service with some new bmws is quite good. But unnecessary for most unless you have wifi only entertainment devices in the back and want to play youtube on them. WLAN is separate from connecteddrive and I think are renewed as separate services.
05-31-2019, 01:35 AM | #42 | ||
OEM CSL Whore
1255
Rep 1,476
1. I'm aware of oem wlan with Verizon data but bmw wants to charge me to use it. So I'll pass. 2. I wanted to know if there's a way to use the data I'm already paying on iphone ATT to be used on the bmw wlan. Not sure it's even possible. 3. Yes I can turn in the tether option on iphone so kids can use there iPads in there car, but I'm too cheap 😝 |
Russmov1328.00 |
05-31-2019, 02:35 AM | #43 |
Rep 1,270
The snap-in wlan option as well as the integrated hot-spot subscription in CD have 1 advantage: the network reception is better compared to the phone, as it uses the external car antenna.
Maverik2594151.50 |
06-16-2019, 10:39 PM | #44 |
Rep 535
Ok guys, just wanted to post an update. I ended up downgrading the idrive on the retrofitted NBT evo to 18-03 and now everything including connecteddrive, send to car, remote ventilation etc. is working like OEM. It even allowed me to renew them or buy additional stuff.
In terms of technical detail: it needed an ECU upgrade/downgrade with the correct vin selected during TAL processing. Not a VIN change with FSC after flashing. Also was able to use a 25A continous charger w/o any issues.
