10-18-2021, 08:06 AM | #23 | |
Rep 12
10-18-2021, 04:56 PM | #24 |
Rep 2,528
Yes.
N7_Prolific0.00 |
10-18-2021, 06:02 PM | #25 |
Rep 12
Thanks man. Am just about to start my build but doing my cosmetic stuff first. Could you tell where do I start from in ordering the parts for the conversation. As any one on here ever heard of forza performance group? They offer to sell me the entire x5m conversation kit both back and front bumper. But I don't know if they are legit.
10-18-2021, 06:40 PM | #26 | |
Rep 2,528
10-21-2021, 06:02 AM | #28 |
Rep 5
10-25-2021, 12:14 PM | #31 |
Rep 5
02-10-2022, 02:12 AM | #33 | |
Rep 1
02-10-2022, 07:36 AM | #34 |
Rep 270
I don't think that the F85s had ACC as an option (the steering wheel buttons are used for M1 and M2 settings instead) so finding OEM mounting parts for ACC from an X5M is highly unlikely or impossible. I haven't looked at it (I have an M Sport with ACC) but it may be possible to transfer it over with some creative bracket fabrication/modification as the lower areas where the sensor lives of both the M Sport and X5M are not completely different on the surface. If you're really lucky it's just a straight swap of the mounting hardware (if you have an M Sport - I think the non-M Sport mount is different altogether). In the end I suspect it's quite doable but not with F85 parts. I'm sure some here would be interested how you make out with that.
02-13-2022, 10:05 AM | #35 |
Rep 2,737
Got my bumper installed and also trimmed the driver side vent slightly to take care of the fitment issue. Also swapped the digital cluster and LED headlights installed on my 40E finally! Loving it !
Mirrors, rear bumper and extra body bits coming later….. have the stock M brake calipers but need the rotors so that maybe in spring time ! (Led refresh on cluster pulses in camera so in the pic the gas gauge looks off but it's working) |
02-21-2022, 05:42 PM | #36 |
Rep 30
Unfortunately I am not familiar with the radar system @RV.
-C- Your ride looks fantastic!! Great job! I didn't run into the issue with having to trim anything, it was just a straight swap. I have my M rear bumper getting painted right now! I am curious about your instrument cluster though, I have seen many threads regarding that swap, but there's a lot of conflicting information as well. Would you mind discussing via PM? |
03-11-2022, 10:33 AM | #37 |
Rep 30
I got the rear bumper painted, and nearly installed, until I realized that all the rear mounting points have to be replaced. It was about another 2 weeks wait and several hundred dollars of mounting brackets..
I received all the brackets, installed them, and then realized that the brackets for the lane assist ALSO need to be replaced. So now it’s another waiting game for those. Unfortunately nothing is local and can be had from the dealer. They can be ordered from the dealer, but the wait time is still lengthy and the prices are considerably higher than from other sites. So far for this rear conversion, I have bought: 1 rear bumper - included the tow hook covers 1 rear diffuser 1 rear diffuser insert 1 pair of Acexxon reflector delete in gloss black 4 mounting brackets for bumper 2 mounting brackets for lane assist And of course, the paint job. This rear conversion was not as straightforward as the front. I had to cut the rear trapezoid exhaust tips to even get the bumper on for test fitting. If you are doing this at home yourself, you’ll want to cut off those tips, get the bumper on right, and then take it to muffler shop for final fabrication of a custom set up. If left as is, you will have the pipes covered by the bumper, and where the X5M tips usually come out, you’ll have your stock muffler blocking that. Not a very fun conversion, but hopefully this helps others to not make the same mistakes that I did. I don’t think I’ve seen a parts list or a detailed exhuast modification for this project. |
03-11-2022, 10:42 AM | #38 |
Rep 30
Here are some pictures of the rear. Hopefully gives you all a better idea as to what’s going on. The red circled areas are all mounts/brackets that need to be replaced to match the x5m bumper. The blue is the exhaust where I cut to allow the bumper to fit properly. And the yellow is the stock muffler that runs sideways and will ultimately block the cutouts on the new x5m bumper.
I have yet to figure out the best way to do the exhaust once this is all said and done, so any input would be great. My f15 is an Xdrive 35i. A single 3” pipe going into the stock muffler, then split to two. I really don’t want to make this loud and obnoxious. Any input or advice is greatly appreciated! |
03-19-2022, 07:09 PM | #39 |
Rep 30
I’m back with some updates on the exhaust…
I went to one shop and was told I wouldn’t be able to do any sort of custom muffler work because of the limited space in the rear of the X5. So I went to a different shop after seeing a video of a guy that had installed a Flowmaster Super 10, and they were pretty confident that it could be done. I went with the Super 44 by Flowmaster (which is considerably bigger, but more quiet than the 10), and it all worked out great! I was expecting to have to buy a used X5m muffler and do some custom work to that $$$ My F15 is an Xdrive35i, and while the Flowmaster does change the sound a bit, it’s not a dramatic difference. It does have some gurgles and pops, but nothing too exciting. There is a slight drone on the highway in comfort mode though, but pretty negligible. The tips are 3.5” double wall, but I might change to 4” sometime down the line. The bumper was only halfway installed to get the proper fitment of the exhaust tips. Still waiting on the Blind Spot Detector mounts - once I have those, I can button this all up and be done for now I should have the 6WB instrument cluster arriving this week as well. Last edited by Javila; 03-25-2022 at 11:29 AM.. |
03-19-2022, 07:21 PM | #40 |
Rep 30
03-19-2022, 08:38 PM | #41 | |
Rep 73
I would rather the Super 44 because my concern is the Super 10 would be too loud. Any under the car pics so I can show the muffler shop? Also, Any video of the sound? |
03-20-2022, 04:01 AM | #42 |
Rep 30
I don’t really have any close ups from when it was on the lift, but basically the shop just cut the 2” or so protruding from both ends of the super 44 to make it short enough to fit. It’s very doable.
I don’t have video either, but I’ll see what I can do! Once I get the rear bumper on, I’ll get some pictures all around. I know I haven’t posted any of the front end.. |
Hop7464.50 |
03-20-2022, 09:41 AM | #43 | |
Rep 73
Tags |
bumper, exhaust, f85, flowmaster, swap, tips exhaust, x5m |
