06-09-2021, 10:33 AM | #25 |
Rep 630
I've listened to that video and it's definitely subtle. Sounds like going over road seems/gaps like you would hear on some bridges. How big of a bump do you have to go over for the noise to present itself? Does it do it going over driveways at an angle? Speed bumps going slowly?
Out of curiosity, has your reinforcement plate been removed by anyone for any reason? I am not great at identifying individual parts failure through noise since, like I said, I tend to replace the entire thing all at once when anything makes a noise. But I'll try to help if I can. |
M302_imola844.50 |
06-09-2021, 12:41 PM | #26 | |
Rep 1,497
I don't really know what reinforcement plate you're referring to? And to my knowledge it hasn't been messed with. Appreciate the help. |
06-09-2021, 12:47 PM | #27 |
Rep 2,373
M302_imola844.50 |
06-09-2021, 01:09 PM | #28 | |
Rep 104
https://www.carid.com/meyle/front-lo...0-0004-hd.html |
06-09-2021, 01:11 PM | #29 | |
Rep 630
The reinforcement plate is #4 in that diagram. If not torqued back down properly it can cause a creak/groan. Not a concern if it's never been removed. |
06-09-2021, 02:28 PM | #30 | ||
Rep 1,497
I might just do that! Appreciate the invite!
06-09-2021, 05:11 PM | #31 |
Rep 104
Has #13 been replaced (I've lost track)? If not, try injecting lube in the ball joint boot to see if that reduces the noise?
M302_imola844.50 |
06-09-2021, 07:02 PM | #32 |
Rep 1,497
I think you're right on the money. #13 is the only control arm I haven't replaced on the passenger side where the noise is coming from. I'm highly considering the delphi brand since it's only $60 and on amazon prime.
06-09-2021, 07:46 PM | #33 |
Rep 11,147
I bet you anything it's #13. I'm on my seventh!
Violator4587.50 M302_imola844.50 |
06-09-2021, 08:27 PM | #34 |
Rep 1,497
That's right, I remember seeing a few of your threads. 7th?!?! That's crazy bro! How many were replaced under warranty? I'm considering the Delphi brand because of the price and can have it in my hands in 2 days. Thoughts? Sounds like the OEM arm isn't the best quality. Did you hear a sounds similar to mine when it failed? Any looseness or floaty feel while cornering?
06-09-2021, 08:39 PM | #35 |
Rep 1,859
Drives: 23' X7 40i M Sport
Guys - Do we need an alignment after replacing #13?
06-09-2021, 11:43 PM | #36 | |
Rep 11,147
That being said, my service advisor told me BMW has now created/released a v2 of this part, given the fact there were so many problems with it. Both of mine are now v2, and so far, no issues yet. Mine would groan/moan at low speeds or going over a small bump, like pulling into the garage or parking at the supermarket. |
06-09-2021, 11:44 PM | #37 |
Rep 11,147
06-10-2021, 07:48 AM | #38 | |
Rep 1,497
Yes, unfortunately! I literally just had an alignment done 3 weeks ago. If they really did the alignment. I wasn't given an alignment spec sheet and he's telling me the machine doesn't store the specs. This is the same shop that installed the coilovers and misdiagnosed my "creaking" sound as FCA #8. They f'ing suck and my car won't be back over there. I will spread that word around time about my experience and the lack to make it right. Bitter? Fuk yeah I am! I don't take kind to people cheating me out of money.
It sounds like you caught your FCA failure at the beginning stages. Mine started w/ a slight groan and now has become a louder creaking w/ traction control coming into the picture now |
P111593.00 |
06-10-2021, 08:41 AM | #39 |
Rep 1,564
I'm sure you are already doing it, but gotta ask anyway - you and all the mechanics that have worked on this have always pre-loaded the suspension to ride height before torquing everything to the specs BMW lists right? I recently helped a friend with a similar issue and it was caused by him torquing everything down without preloading the suspension.
Also double check the chassis plate as mentioning above and see if the bolts look like they have ever been messed with. If so order new bolts (they are one use only)and re-torque, this plate has to be done with entire suspension pre-loaded also, easiest way is drive truck up on 4 car ramps (assuming you have x-drive). |
M302_imola844.50 |
06-10-2021, 05:57 PM | #40 | |
Rep 1,497
06-13-2021, 01:22 PM | #41 | |
Rep 5,023
Sry to hear about your troubles, but mega appreciate the information and knowledge for the community! |
M302_imola844.50 |
06-13-2021, 10:35 PM | #42 |
Rep 11,147
I'm not sure if there was a new part number. I think it's the same part number, just a v2 version. Unfortunately my dealership stopped showing part numbers on the receipts last year.
06-14-2021, 12:10 AM | #43 |
Rep 5,023
06-14-2021, 07:05 AM | #44 | |
Rep 1,859
4
