10-12-2018, 09:20 AM | #4489 |
Rep 6
I just purchased the Bimmercode app. I selected start/stop off by default - but it stays on. I could get the light of the start/stop button off when starting but it still stops at traffic lights.
I also want to program my HUD - but I cannot find the option in the app to do it? I have top down cameras - but when trying to select that ECU it is grayed out and says not available. Any advise please? |
10-12-2018, 10:28 AM | #4490 | |
Rep 627
Drives: X5 F15 M package
10-13-2018, 12:47 PM | #4491 |
Rep 703
This forums is awesome, I coded today almost everything from the F15 cheat sheet. Thanks everyone for the help!
One thing I'm still missing, I don't see the HU_NBT2 so I can code to id6_light. Does this means my car has id4?! It's a 2016 F15 (2016 build date too) How can I check the id version I have? |
10-13-2018, 12:48 PM | #4492 | |
Rep 41,221
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 10-13-2018 at 12:59 PM.. |
fbuzila367.00 |
10-14-2018, 07:19 PM | #4494 | |
Rep 8,364
North American F015/F016/F085/F086 552 LED's lack cornering lights (unlike European counterparts). Instead, they use Fog lights. Did you code NGHB using European values for cornering lights? You can VO with 8S4 present? |
10-15-2018, 10:29 AM | #4495 |
Rep 627
Guys,
while attempting to read edit FDL and see all codes I get the following error: The chosen token EST "c:\program~3 \TOKENM~1\E-SYSL~2\FREETO~1.EST" is no existing file. [C156] While I understand the issue I have no clue how to fix it. Any help please ? |
10-15-2018, 02:33 PM | #4496 |
Rep 2
BMW X5 2018 Coding Question
On the 2018, anyone was able to change the interior X-Lines using E-SYS? Read somewhere that it is no longer functioning. Please point me to right direction with E-SyS.
10-16-2018, 01:34 AM | #4498 | |
Rep 8,364
Not possible. |
10-16-2018, 08:38 AM | #4499 |
Rep 627
@Almaretto using 3.27.1
Maybe I am missing the token program ? |
10-16-2018, 10:28 AM | #4500 |
Rep 23
Remove errors from accidental folding trailer hitch VO add (3AC)
I installed a trailer hitch (Draw-Tite -- the one that reuses the rear bumper beam) and installed the BMW tow hitch wiring harness (82-71-2-349-500) and the control unit for the hitch (71-60-6-889-589).
Went to do the coding and mistakenly added 3AC (folding trailer hitch option) based on some coding suggestions I saw on the forums. Unfortunately, the car started giving an error related to the folding hitch (see attached). I subsequently removed 3AC and cleared errors using Esys Transmitter. However the error remains. Any suggestions?
Current BMWs: '16 M3 6mt, '16 535d, '18 X5 35d
Prior BMWs: '15 X5 35d, '13 335xi, '00 528i Sport Wagon, '98 M3/4, '78 530i Others: Radical SR4 |
10-16-2018, 05:54 PM | #4501 | |
Reads books at a 4th grade level; I'm an enabler
78
Rep 116
Drives: X5 35d, 335i Msport, X3, 325iX
Garage List 1993 BMW 525iT [0.00]
1989 BMW 325iX [0.00] 2015 BMW 335i M-Sport [0.00] 2007 BMW X3 M-Sport [0.00] 2015 BMW X5 [0.00] |
10-17-2018, 01:27 PM | #4502 |
Rep 525
I've got a 2016 X5 35i that I can't seem to get coded to unlock the doors at ignition shut off. Originally tried to do it via ESys = no dice. I've also tried using BimmerCode and even though I have the option to enable/disable it, it also doesn't work. Do I have some weird version of software on my F15 that doesn't respond to this coding line the way it should? All other things I've coded work just fine.
10-18-2018, 12:36 AM | #4503 | |
Rep 8,364
https://www.bimmerfest.com/forums/sh...d.php?t=983244
10-18-2018, 09:40 AM | #4504 | |
Rep 525
Unlock when STOP Engine (older software) BDC_BODY 3040 VAM_UNLOCK_KL15OFF_AFTER_PIA_AUTO_LOCK nicht_aktiv aktiv Unlock when STOP Engine (newer software) BDC_BODY CLI_DEFAULT_UNLOCK_AFTER_END_OF_DRIVING nicht_aktiv aktiv |
10-18-2018, 10:04 PM | #4505 | |
Rep 8,364
10-19-2018, 01:58 AM | #4506 |
Rep 6
6NS issue
If i want to disable Seat belt alarms from ACSM module, which CAFD file should you modify? There are 3 different ones...
10-19-2018, 08:54 AM | #4507 |
Rep 525
10-19-2018, 12:47 PM | #4508 |
78
Rep 116
IIRC for the Body it's a single CAFD file with a .ncd extension. You'll need to pull it from the ESys storage folder, which is typically C:/Data/CAF
10-20-2018, 03:33 AM | #4509 | |
Rep 8,364
Then, add to post using cloud link or add *.pdf and using attachment option. |
10-20-2018, 04:52 PM | #4510 |
Rep 627
Getting weird error today while launching Esys 3.27.1
Help is kindly appreciated |
