01-20-2019, 04:34 PM | #4665 |
Rep 166
Ok thanks for that - I'd heard of the token expiry but thought that was only for the generation of new tokens, and that existing setups would continue to run. Guess I need launcher pro? If so, can someone pm me a link?
01-20-2019, 06:18 PM | #4666 |
Rep 627
Drives: X5 F15 M package
Or you can use a virtual machine that has all the workaround it
01-23-2019, 11:47 AM | #4667 |
Rep 30
Hi all,
I coded my bmw x5 f15 before (read 2 years ago) so have the cable and the esys software installed (probably old version). Today it went in for maintenance with the new updated software of course overwriting my codes. Can anyone guide me to recode my car? I read something about new tokens / new software?. Any feedback is highly appreciated. Thanks in advance. |
01-23-2019, 11:49 AM | #4668 |
Rep 41,178
Launcher PRO 3.x requires Web Login, which only the Developer, TM, can provide.
01-23-2019, 11:50 AM | #4669 | |
Rep 41,178
01-24-2019, 11:20 PM | #4672 |
Rep 41,178
PM sent.
02-02-2019, 10:44 AM | #4674 | |
Rep 4
Al |
02-02-2019, 01:07 PM | #4675 |
Rep 41,178
PM's sent.
02-02-2019, 02:18 PM | #4676 |
Rep 19
Can someone in US with access to coding tools post(PM) their BDC CAFD please? Trying to compare with a EUR version for a couple different things I'm trying to figure out.
with LED Adaptive headlight Thank you in advance! |
02-03-2019, 02:51 AM | #4677 | |
Rep 8,364
https://www.bimmerfest.com/forums/sh...38&postcount=1 |
02-03-2019, 01:37 PM | #4678 |
Rep 166
Hi all, is there a way to increase the delay for the key fob-operated trunk release? I've had several occasions where a neighbour has knocked on the door to tell me my X5's trunk is open. I must be catching the button on my key fob. I'd like to keep the function (i.e. not disable entirely through coding), but increase the delay so it needs a longer push. Hopefully I can simply change a werte value somewhere. Any pointers gratefully received
02-03-2019, 02:13 PM | #4679 |
Rep 1
Hello All,
I am trying to change the lightings in myX5 X40e, i am able to dig down to GROUP_0_FARBE_ENSEMBLE_1 section but i don't see options to change the color(i mean i dont know the werte values to colors) - Any suggestions or any links that can lead me to that point. Thanks. |
02-03-2019, 07:35 PM | #4680 |
Rep 13
KOMFORT_SCHLIESSEN and alarm going off?
Hi All,
Working on my X5M and made sure the following were set to aktiv: KOMFORTOEFFNUNG_FB KOMFORTSCHLIESSUNG_FB (needed for side mirrors) KOMFORTSCHLIESSUNG_PA (needed for side mirrors) KOMFORTOEFFNUNG KOMFORTSCHLIESSUNG ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN Problem I'm having is that when I go into KOMFORT_SCHLIESSEN and change the wert value from 0F to 00, my alarm goes off while the mirrors are folding. Changed it back back to 0F and it works perfectly. Any ideas? -CP Last edited by cpalacay; 02-03-2019 at 07:41 PM.. |
02-04-2019, 11:48 AM | #4681 | |
Rep 2,528
02-04-2019, 09:17 PM | #4682 | |
Rep 8,364
Is this with ENET plugged in with both cases? |
02-05-2019, 08:27 AM | #4683 |
///M
196
Rep 272
Drives: 2015 F15 X5 50i M Sport
Hey guys, I've been searching and searching and searching and know it's gotta be in here but I'm not having any luck. Does anyone have a cheat sheet to be able to turn on the front camera at any speed?
2015 F15 X5 xDrive50i - M Sport - Space Grey Metallic - 21" 612M - Accelera Iota ST68's - Black Dakota - Leather Dash - Poplar Wood - Ceramic - Shawdowline - Anthracite - Adaptive M - Full LED - Executive - DA+ - Surround - HUD - Enhanced BT - Soft Close - B&O - ACC Stop & Go - Multi Contour - 4 Zone Climate - Comfort Seats - Cold Weather - Muffler Delete - Akrapovic Tips - F85 Grille - 35% Tint - BMW All Weather Mats -- Missing DHP, NV, Active Steering, Rear Entertainment, & Cooled Seats
02-05-2019, 11:08 AM | #4684 | |
Rep 1,247
Not sure what you are using, but it should be possible if you can get access to that ECU.
BimmerTy195.50 |
02-08-2019, 07:00 PM | #4685 | |
Rep 1
02-10-2019, 05:00 PM | #4686 | |
Rep 100
any other tricks or steps that have worked? I have EBT |
