04-01-2019, 01:40 PM | #4754 | |
Rep 219
Anyone have any thoughts on what to look for or how to correct? |
04-01-2019, 01:47 PM | #4755 | |
Rep 219
Currently, I am simply trying to get the errors cleared (have not tested trailer lights). Then, i can work on getting the trailer stability controls working. |
04-01-2019, 02:21 PM | #4756 | |
Reads books at a 4th grade level; I'm an enabler
78
Rep 116
Drives: X5 35d, 335i Msport, X3, 325iX
Garage List 1993 BMW 525iT [0.00]
1989 BMW 325iX [0.00] 2015 BMW 335i M-Sport [0.00] 2007 BMW X3 M-Sport [0.00] 2015 BMW X5 [0.00] |
2) Something is incorrectly wired from the original installation. FDL, the AAG + the six others listed in the PM I sent. |
04-01-2019, 08:56 PM | #4758 | |
Rep 1,061
Try this: 1) Add 'K235' to HO-Wort in your VO 2) VO Code entire car 3) Make sure correct CAFD is injected in trailer module (AAG) 4) Test trailer lights Other option is in ISTA+ to go to "retrofit" and add trailer module which will add K235 and code all modules impacted (which is a lot). |
04-02-2019, 01:11 AM | #4760 |
1152
Rep 2,426
I was not aware that the trailer retrofit was an option via Esys…
2015 BMW X5 xDrive50i
BMW CCA 509766 |
04-02-2019, 07:13 AM | #4761 | |
78
Rep 116
If someone with K235 programmed is up for sending over their 7 CAFD files for the modules, I'd be curious to look at any differences in end result using the comparison tool. |
04-07-2019, 10:44 AM | #4762 |
Rep 9
Sorry if this this been discussed but I did try but not sure what keyword to use.
I coded my F10 for "flash to pass" so the headlight flash like strobe/police like. it was 3 years ago when I code my F10 and I cant remember where did I read it. any one knows which one that I need to code for F15? |
04-07-2019, 11:09 AM | #4763 |
Rep 41,221
PM sent.
04-07-2019, 08:27 PM | #4764 |
Rep 205
I'm running the Launcher 2.8.2 and the re-arm 2.0.4. I run through the setup instructions in the .pdf (all very clear). When I run the launcher for the first time, enter the PIN, and generate the token, I get a success message. But no .est file appears in the Tokenmaster directory, and E-SYS options are never configured to point to that location.
Any idea why the .est file isn't appearing despite everything appearing to go as normal? I have the date set for October 2018 and am successfully running the re-arm tool. |
04-07-2019, 08:28 PM | #4765 | |
Rep 41,221
04-07-2019, 10:16 PM | #4767 |
Rep 2,529
04-08-2019, 05:52 AM | #4768 |
Rep 205
Thanks - I'll check out esysx. Wanted to try Bimmercode, but not sure if expert mode will allow coding the modules needed for TJA and anti-glare High beams. I've already VO coded the high beams, so maybe BimmerCode can do that. But TJA should have VO ideally.
04-09-2019, 07:13 AM | #4769 |
Rep 95
Need help - iDrive stuck rebooting loop
My 2017 f22 idrive is stuck in a reboot loop after a Carly coding attempt and it won't stay up long enough to complete a restore from backup. I do not have Esys, but I would be willing to get it if there is any chance I can revive it... (or is a dealer trip required)? I get codes:
CD0487 E1C440 E1C603 801C15 801C20 E14600 Any thoughts on what best to do? TIA |
04-13-2019, 03:59 AM | #4770 | |
Rep 43
SZHEA 21 *** 8243; LAW Y-spoke 375 SZC4A BMW Performance Interior Carbon moldings SZPFA BMW Performance Alu pedal plates SZP1A BMW Performance brake system or 2NH M brakes SZP8A BMW Performance Sport steering wheel SZPHA BMW Performance Aerodynamics Package |
04-13-2019, 05:36 AM | #4771 | |
Rep 401
2015 BMW X5 35d Msport Carbon Black/Mocha Nappa 2013 Cadillac Escalade Platinum Diamond White Pearl/Cocoa 2007 BMW M6 Sapphire Black Metallic/Black 2005 Ninja 636 Lime Green |
04-13-2019, 11:47 AM | #4772 | ||
Rep 95
04-14-2019, 12:20 AM | #4773 |
Rep 2
Need Help. New with Programing.
Where can I find profiles for NCS expert? The only thing I have been able to code were injectors, and I only have 2 profiles for my NCS expert. I'm guessing the more important one I need is Expert mode.
04-23-2019, 04:35 PM | #4774 |
Rep 137
Is there any way to prevent the vehicle from putting itself in park when trying to back up with the drivers door open?
I remember reading in one of the two coding threads that this question was asked, but I never saw any reply. |
