      09-10-2018, 04:47 AM   #617
chamindab
Drives: X5 XDrive 40E IPerformance
X5 real issues
Disappointed big time with the X5. Paid USD 152,000 with local taxes.
It's a brand-new car manufactured in USA
At only 580km on the meter, after few weeks of usage here are the faults and issues.
Steering hum when turning.
Suspension noise coming from front sides, spreading to the center along the steering rack, as if an old vehicle badly maintained.
Thumping noise from brake booster. Also comes when park brake is engaged.
Driver seat belt warning malfunctioning, even at 50kmph no warning.
Two hub caps lost, weaken bonding, emblem comes off.
Chrome molding on rear bumper came off, weak double sided sticker.
Speed warning does not rest and does not warn if speed is exceed, even after dropping speed below the set limit by 10kmph.
Does only 11 km per liter of petrol on expressway at 100kmph, on eco pro.
Auto lights want turnoff in broad daylight. There was nothing covering the sensor.
Boot door makes noises, as if an old vehicle badly maintained.
What a disappointment. Dealer is willing to cover with warranty. Who wants to remove all parts and repair a brand-new car.
Does X5 have any quality control at all before releasing the cars to customers?
Chaminda Bandara
      09-10-2018, 03:06 PM   #618
A-4WD
Long Time Bimmer Fan
Drives: 2014 X5 35i
Originally Posted by RotaryPowered View Post
New issue started a week ago. When I plug a phone into the USB, it constantly cycles charging/not charging/charging/not charging very fast. Ends up just draining the battery... Will take it in under warranty soon.
I have this same problem and my cable works fine everywhere else (both via direct USB and through the outlet plug).
Did you find out what the issue is?
Thanks.
2014 X5 XDrive 35i - Current
2010 X5 XDrive 4.8iS - Traded
1990 325iS - Sold
1985 318i - RIP
      09-11-2018, 12:34 AM   #619
CatalinP
Drives: BMW X5 F15 2014 3.0xd
NBT Headunit must be replaced. The information is available in other threads.
A-4WD215.00
      09-12-2018, 08:31 AM   #620
RotaryPowered
Drives: F15 x50i M Sport
Thanks.
I haven't, I ended up just getting some 12v USB adapters to put in the front and rear seats and just use those now. TBH, those adapters are more handy to use/get to then opening the center console to use the built in USB anyway, so not really an inconvenience for me.
A-4WD215.00
      09-12-2018, 11:26 AM   #621
A-4WD
Drives: 2014 X5 35i
Thanks
1990 325iS - Sold
1985 318i - RIP
      09-12-2018, 11:29 AM   #622
A-4WD
Drives: 2014 X5 35i
I agree that the adapters are much easier to use and that's exactly what I've been doing as well. I had forgotten about this problem actually until I saw this post then my OCD kicked lol. I'm just going to put it on my next service-due-list since it's still under CPO warranty, so may as well see what the dealer says. Thanks for your reply.
1990 325iS - Sold
1985 318i - RIP
      09-19-2018, 10:54 PM   #623
series8217
Drives: 2015 X5 xDrive35i, 2005 BMW M3
Originally Posted by MiLo View Post
Hi Y´all,
I´ve been experiencing a very unresponsive and floaty steering above 40 mph. Doesn't act like any BMW I´ve driven. As a matter of fact, I don´t think I´ve driven a car with such a terrible steering. Above 40mph when I slightly turn the wheel in kind of keeps the steering angle, doesn't move back to neutral, it almost feels like it locks itself.. I don´t know if its normal...... I have an appointment on Monday for a checkup.
If your car has the Active Steering option, I believe this behavior is normal.
      09-20-2018, 12:23 AM   #624
hacksics
Sri Lanka
15
Drives: BMW X5 40e M-Sports 2016
You mean, upgrade to NBT Evo yes? As per other threads it's due to to USB port is unable to deliver current more than 0.5A right?
      09-20-2018, 01:08 AM   #625
CatalinP
It depends whether or not NBT is still available as spare part.
      09-20-2018, 08:28 PM   #626
eeclark
Drives: F15 X5
Having a heck of a time replacing the right side (passenger side in the US) door pull. Ordered the part from BMW but not able to remove the handle from the car. Removed the leather and two torx <20> screws. Feel like there is one more small one since the older models show it and the replacement piece looks like there is a spot for a smaller screw. Don’t want to force it off the car just in case there is that third screw.
Anyone else do this replacement before?
      09-21-2018, 12:51 PM   #627
eeclark
Drives: F15 X5
F15 Door Handle Pull - Third screw behind panel - need to remove it
Went to local BMW Body shop and they explained that the older X5 (not the F15) can easily be replaced with three screws facing the occupant. The new X5s (F15) the third screw is accessible only by removing the door panel.
      09-28-2018, 08:55 PM   #628
aymanb
Drives: BMW X6 2017
Hey Guys!
I need your help. I faced one problem with the trunk of my BMW X6 2016 and I do not know what to do with it.
Not long ago I heard a horrible rattle sound from the back of my car. I stopped by a dealer in Toronto, Canada.
The first time, he did not hear anything. The second time, he told me that it is a plastic trim and that is fine. The third time, they told me that that is normal for a 2-year-old car and they will not be able to help me.
The video of the sound I recorded today can be found here https://drive.google.com/open?id=1_F..._AluGGjhPgWVj6
Have you faced with the similar issue? If so, how did you fix it?
Thank you so much for your help! Appreciate your advice.
      09-29-2018, 10:32 PM   #629
Torrentlord
Drives: Bmw X5 40D 7 seat alpine white
Cheers for the alloygator link
      10-04-2018, 12:20 AM   #630
ryegateli
Drives: 2015 BMW X5 Xdrive50i
I got it a 2015 X5 Xdrive 50 i M sport before a month.Today i noticed a warning saying DrainTrain Malfunction . I was able to check the CC-ID code in the check submenu and it has a code of 0034. Not sure what is it (checked the list of codes and could not find this code). The warning was gone with in a mile or so , after i turned the engine off and then restarted. Any one faced this before ? should i ignore this till i see it again or take it to service center? i am out of warranty on the car, 2 weeks back. Will this be a spark plug issues ? any suggestions ?
      10-04-2018, 11:25 AM   #631
A-4WD
Drives: 2014 X5 35i
Did the truck jerk or bog when the Drivetrain Malfunction warning came on? I had this issue with my E70...
1990 325iS - Sold
1985 318i - RIP
      10-04-2018, 02:04 PM   #632
ryegateli
Yes it did jerk for a few seconds may be for like 30 seconds and i stopped at red signal , turned the car off and and turned on .. warning remained for less than 10 seconds again but this time no jerk and later its gone .
      10-04-2018, 02:18 PM   #633
A-4WD
Drives: 2014 X5 35i
The dealer/mechanic will have to read the codes when it's in error mode and I think you need to have it checked as mine only got worse over a month or two. Unfortunately, i don't think this problem will go away on its own. I ended up trading mine in instead of repairing it so I don't know what caused it, but from what a few BMW mechanics told me, it needs to be read in error mode to see what's causing it.
If I were you, since you're just out of the warranty period, I would still take it to BMW service to have them check it and log it in your file. They may be willing to help you with pricing or even cover the repair since it's so close to warranty expiration. Are you out of warranty because of the mileage, because you're in a 2015 and factory warranty is usually 4 years?
1990 325iS - Sold
1985 318i - RIP
      10-04-2018, 02:52 PM   #634
ryegateli
Yes I just crossed 50k 2 weeks back. And yes I did check both Error Codes(sub menu) and Checks(sub menu) Codes from the hidden menu by unlocking it. There is no Error code at the miles when this Warning came up. But there is a Check code ( CC-ID) 0034 came up exactly matching with the miles when i got the warning yesterday. So, the error mode you talking about is totally different than these two ?
      10-04-2018, 02:57 PM   #635
A-4WD
Drives: 2014 X5 35i
I am referring to the error code when they plug in the OBD. I don't know if that's the same error code you're getting. Try searching the error code and see what you come up with. There are lists of codes on the interwebs.
1990 325iS - Sold
1985 318i - RIP
      10-04-2018, 03:03 PM   #636
ryegateli
Ok let me investigate more and yeah i better take this to BMW service center to log it.
      10-04-2018, 03:12 PM   #637
A-4WD
Drives: 2014 X5 35i
Good luck. Hope it's nothing major
1990 325iS - Sold
1985 318i - RIP
      10-04-2018, 03:28 PM   #638
ryegateli
Thank you . Yeah , hope they dont rob me
