      05-22-2014, 11:13 PM   #67
greentrbo95gst
greentrbo95gst's Avatar
1256
Drives: 21 M5 Comp
Haha me too. I guess we won't find out until tomorrow. I did the software upgrade today and used my go pro charge cable. Worked great. Everyone make sure you update your software with the instructions they sent.
Dealer told me I will have my car in 3 weeks exactly.
Current: 21 M5 Comp, 23 M3 6spd, 23 i4, 20 Tundra TRD PRO
      05-23-2014, 01:22 AM   #68
bclk55
Drives: 14 X5 35D, 15 GT3
Thanks for dropping off the RaceChip tune today greentrbo95gst. First off I was impressed with the quality of the RaceChip unit itself. The cables and material used are top notch. It took me less then 2 minutes to install the chip, just plug and play. Right now it is currently setup at default which is at the most conservative setting. I was able to do a couple run to 60mph tonight and noticed that it pull a little harder. I will play around with the setting tomorrow and give an update. You can adjust how much power you want by dialing the setting in the module itself. I will post some install pictures tomorrow.
      05-23-2014, 10:44 AM   #69
greentrbo95gst
1256
Drives: 21 M5 Comp
Cool vid I found
      05-23-2014, 12:40 PM   #70
jpsjr70
jpsjr70's Avatar
Drives: 2015 BMW X5M
Ordered mine on Tuesday, looking forward to installing and getting numbers. We should feel something especially going from 255hp to 331hp right? Torque was a pretty decent jump also. I'll keep you guys posted...... Thanks to greentrbo95 for the find!
Joe
      05-23-2014, 01:01 PM   #71
Ggluck3
Ggluck3's Avatar
Drives: 2020 x5 M sport
Hey guys need some help. Had no problems installing one of these on my E70 however on my 2014 F15 diesel I can't find the plugs. The picture that someone posted previously does not match up with my engine layout. Help....
      05-23-2014, 02:16 PM   #72
bclk55
Here are my install pics. Hope this help. Pretty straight forward.
      05-23-2014, 10:06 PM   #73
42pilot
42pilot's Avatar
593
Drives: 2014 X5 35d MSport
I'll be interested to hear how everyone likes the chip. How does it handle the switch to SPORT mode? Does anyone know the logic they use to bump the power - fuel timing, boost, fuel pressure, etc??
      05-24-2014, 07:02 PM   #74
Ggluck3
Ggluck3's Avatar
Ok so got my tuner in and ran it at
E/2 with 350 ish horsepower showing on I drive display, no problems as of yet driven 25 miles hard so far. I definitely feel a difference
      05-24-2014, 07:04 PM   #75
greentrbo95gst
1256
Drives: 21 M5 Comp
I am so jealous. My pcd delivery is June 5th and for now I'm playing with the tuner box and starring at it.
      05-24-2014, 08:20 PM   #76
Ggluck3
Ggluck3's Avatar
Tuner
I meant 260ish hp showing on the sport displays on I drive.
      05-24-2014, 09:39 PM   #77
42pilot
42pilot's Avatar
593
I have a feeling everyone is going to say, "I definitely feel a difference". But what does that mean? Throttle response? Better from a dead stop? Rolling acceleration? Fuel economy?
Is there a warranty on the tuner (like Dinan provides)?
Thx
      05-24-2014, 10:01 PM   #78
greentrbo95gst
1256
Drives: 21 M5 Comp
Lifetime warranty on the tune.
It's a fairly simple receipe, adding boost and allowing ecu to compensate with more fuel and timing. When cruising its slightly leaner to where it allows you to get up to 5 mpg more.
Remember that 40d and 50d use the same exact motor but with more boost from additional turbos.
Stock monitor will only show what it's trained to do based on vacuum so it will not show you true gains.
Your butt dyno should tell you a lot more or other devices like plx.
      05-24-2014, 10:42 PM   #79
42pilot
42pilot's Avatar
593
It's a fairly simple receipe, adding boost and allowing edu to compensate with more fuel and timing. When cruising its slightly leaner to where it allows you to get up to 5 mpg more.
OK - thanks.
What does lifetime warranty mean? If it smokes the motor, do they fix it? Or is there a lifetime warranty on the chip? Big difference.
I used to build and tune turbo gas motors, and butt dyno's lie. I could add a bit more ignition timing which would add a little more low-end torque, but the owner would say its a different motor. Then I would show the tuning tables - nothing was really done. Anyway, it would be interesting if one of you would take your F15 to a dyno and do a before and after.
There are a lot of so-called tuners out there and I am obviously very skeptical of installing a chip into a +$60k vehicle that I own.
      05-24-2014, 10:56 PM   #80
greentrbo95gst
1256
Drives: 21 M5 Comp
Originally Posted by 42pilot View Post
OK - thanks.
Honestly for what we get and for what we are asking for this is all we need. X5's are not dyno queens and I can tell you that with what bmw has done to their cars modifying cars became very difficult and tricking ecus to thinking they are running more boost is all we will get. I have been modifying the m5 which is officially the fastest in the world and piggy back is all I have available.
Stock ecus have enough protection to stop anything that reaches its limit. As you can tell no companies are building stand alone ecus for our cars and we all get what we can. Research racechips and you will see that they know the knowledge and r&d behind them. It's made in Germany and passes their strict Tuv licensing.
      05-24-2014, 11:32 PM   #81
bclk55
I have been messing around with the setting and it seem like E/2 is the best setting so far. There is a difference in power especially low end. The sport display will not go over a certain HP or TQ. Seem like it maxed out at 260 hp and 430 tq no matter what setting I changed on the tune. But I was able to use my PLX Kiwi device and Dash Command app on my iPhone. This is what the Dash Command app read. I don't know how accurate this app is, but all data including wheels, tires, curb weight, passenger weight, and fuel capacity has been inputed. The result seem pretty crazy.
      05-25-2014, 01:10 AM   #82
Ggluck3
Ggluck3's Avatar
I am also running mine on E/2. It's amazing the difference from a stop as well as the freeway. Much more power from 65 mph while trying to pass vs. before the install. I'm very happy.
      05-26-2014, 11:56 AM   #83
narodk
Drives: X5 Diesel
Can we still get this deal? I want to order. Thanks
      05-27-2014, 10:09 AM   #84
greentrbo95gst
1256
Drives: 21 M5 Comp
PM'd you.
      05-27-2014, 01:37 PM   #85
SharkPhi
Contract Agent
SharkPhi's Avatar
Drives: '14 X5
Ive had mine on since last Thursday. I updated the chip to the latest tune before the install, and performed the install in less than 5 minutes, which is AWESOME.
I haven't "turned up" the tune at all, its still on the E/O setting, but I can definitely tell a difference on the low end, it pulls from a light HARD. I may try and turn it up a bit before this weekend, as I have a long highway drive ahead of me and wouldn't mind a bit more passing power.
Ill keep you guys posted.
2014 F15 Msport
      05-27-2014, 11:03 PM   #86
greentrbo95gst
1256
Drives: 21 M5 Comp
Try E/1 first and see how your truck likes it and then E/2. Based on my own experience, once it's in that setting you ever go back. The torque and power is very addicting.
On a different note I am picking up the car June 5th from PCD in SC. Anyone else doing their pick up there?
      05-27-2014, 11:05 PM   #87
SharkPhi
Contract Agent
SharkPhi's Avatar
Drives: '14 X5
Has anyone had any trouble running E/2 at all? I remember with the JB tune on my 335, turning it up for any length of time required supporting mods or it would result in limp modes.
2014 F15 Msport
      05-27-2014, 11:10 PM   #88
greentrbo95gst
1256
Drives: 21 M5 Comp
No issues and no CEL's. I would leave the first setting on E and turn it up to 1 first before you go any further. Luckily our cars have a pretty good security system and the engine is protected if it senses too much boost, too lean or too rich. I have used these for years on different cars. Had a JBD on my 335 diesel and then Racechips.
S2 setting makes much smaller increments than S1. Look at the screen shot of BCLK55 couple pages back. He is still in E/2 and did 350 hp and M5 worthy TQ numbers.
