01-06-2015, 02:40 PM | #903 |
Rep 39
Revisiting the Kombi display with X5 M50d. I didn't have any other option than BMW/MPM. Suspect i need a software update for the Kombi.
What production date do you guys have so you could enable it? pit from sssmokie's thread I came across the below thread, and seemingly a Kombi flash update sorted it. Don't think I am brave enough to risk doing it myself so will get it done at the dealer next time the car is there. http://www.bimmerfest.com/forums/sho...ight=kombi+mpm |
01-07-2015, 12:31 AM | #906 |
Rep 1,771
Hi opasha
Does coding also reset the learned driving habits? Just curious.. When it resets on-board info, does it also reset acceleration/transmission training that it learned over driving period?
2024 X3 m40i
01-07-2015, 12:40 AM | #907 | |
Rep 3,990
"1. Key in slot, do not touch brake pedal 2. Still not touching brake pedal, hit start button 3. Floor throttle pedal for a good 30 seconds (used my phone stopwatch, it's longer than you think) 4. Still not touching brake pedal, hit start button again 5. Wait 30 seconds, I waited longer actually 6. Start the car normally" No idea if this works or not, but people noticed their car being more responsive afterward. The f15 is far newer, so beats me. I've never come across it in my coding research, but if anyone finds anything, let us know.
01-07-2015, 02:13 AM | #908 |
Rep 265
01-07-2015, 05:52 PM | #909 |
Rep 193
01-07-2015, 05:57 PM | #910 |
Rep 193
01-07-2015, 11:51 PM | #911 |
Rep 24
psdzdata version
Hi Opasha.
I have the same problem as Charles521. I downloaded the full psdzdata v5.4.2 and when I open Esys (v3.26.1) the version showed is 5.0.1. I put the pszdata folder extracted from the file in the folder c:\data as I read in the installation instructions, so may be the psdzdata I downloaded wasn´t v5.4.2. Can you PM me the link for latest Esys and PSdZData? Thanks. |
01-08-2015, 12:30 AM | #912 | |
Rep 3,990
01-08-2015, 02:27 AM | #913 | |
Rep 41,190
If your Connection target is F025-14-11-502, then your using 54.2 PSdZData.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 01-08-2015 at 02:51 AM.. |
01-08-2015, 02:48 AM | #914 | |
Rep 37
I really do not know where I did wrong as well, my PSDZdata version is still 5.0.1. Would you please assist. thanks! |
01-08-2015, 02:50 AM | #915 | |
Rep 41,190
Where are you seeing version "5.0.1" displayed?
01-08-2015, 02:51 AM | #916 | |
Rep 37
01-08-2015, 02:55 AM | #917 |
Rep 41,190
01-08-2015, 11:23 AM | #919 | |
Rep 24
01-08-2015, 11:28 AM | #920 |
Rep 3,990
You're very welcome. Glad Shawn helped you figure it out .
01-08-2015, 12:58 PM | #921 |
Rep 34
Hi,I went to BMW service and they told me that there is important update and I agreed.
when I recived my car, all the coding I done was deleted, so I wanted to code it again. BDC_BODY coding was good. but when I wanted to read HU_NBT, I got this error: Transaktions-Report: Aktion: Codierdaten lesen HU_NBT [63] [0J30266] readCPS o.k. cafd_00000ded-003_013_025 Fehler: File for "cafd_00000ded-003_013_025" not found! [C012] any help |
01-08-2015, 01:01 PM | #922 | |
Rep 3,990
01-08-2015, 01:02 PM | #923 | |
Rep 41,190
http://www.bimmerfest.com/forums/sho...2&postcount=12
01-08-2015, 03:22 PM | #924 |
Rep 34
thank you bros for your help, all worked fine.
only one code did not work for me, the tire pressure and temperature did not appeared for me. I've coded it twice with no success. |
