08-24-2021, 10:19 AM | #1058 | ||
Rep 218
08-26-2021, 12:03 AM | #1059 |
Rep 48
Drives: '18 F15 xDrive35i
Got my f15 2018 last January. Almost immediately felt wheel had a tendency to the right. Thought might need an alignment.
Finally got alignment done in June. The wheel still right leaning. Mentioned to the alignment guy who responded it could be an electronic fault with power steering system and to check in with dealer. The obvious impact on my daily driving is changing lane to the left feels like I'm over steering. Like my wrist has to twist instead of a quick tip. Plan on going to dealership soon. Anyone noticed similar issue?
"better the devil you know than the devil you don't"
2003-03-04 E53 X5 4.4i M62 [SOLD] 2006-03-16 E53 X5 4.8iS N62s [SOLD] 2006-03-28 E90 325i N52 [TOTALED] 2012-09-06 F30 328i N20 2018-01-18 F15 xDrive35i N55 |
08-26-2021, 09:13 AM | #1060 | |
147
Rep 334
bimmaone15.50 |
08-27-2021, 11:51 PM | #1061 | ||
Rep 48
09-10-2021, 02:25 PM | #1062 |
Rep 1
f15 x5 Tranfer case issues please advise !
OK, This may be long but I am at my end on trying to figure this out: I have never come across this, My truck started shifting and surging at low speeds when I drive. I felt it in the front so I thought it was the ENGINE MOUNTS changed! this got a little better, then I could feel it right under my seat in the drive train: Changed GUIBLO DISK AND TRANNY SHAFT GUIDE. Problem still happening, Transfer Case mount : Changed and now I am still having the issue. SHUDDERING! Can anyone please advise on a possible solution!!!!!!
09-11-2021, 10:31 PM | #1063 | |
SPC
7
Rep 73
09-14-2021, 01:35 PM | #1064 | |
Rep 630
I have diff and transfer case fluids on hand so am still going to do those in the near future as well, but after 350+ miles the tires seem to have cured the problem in my case. |
09-15-2021, 09:29 PM | #1065 | |
Rep 75
09-18-2021, 06:18 PM | #1066 |
Ultimate Driving Machine E92ESS625 M3/G05 X5 Msport 40i Individual
466
Rep 2,013
Drives: 2011 E92 M3 DCT/ESS 625 kit
Here is mine.
Also for sale. Thinking of upgrading.
"The Ultimate Driving Machine"
2011 E92 M3 supercharged ESS 625 2016 F15 X5 Msport 35i |
09-20-2021, 12:41 AM | #1067 |
Rep 1,179
09-20-2021, 01:39 PM | #1068 |
466
Rep 2,013
Shit wrong forum sorry🤭
09-23-2021, 12:15 AM | #1069 |
Rep 12
Strange Vibration
Haven't been able to isolate this vibration issue for some time and was wondering if I could get some thoughts on this one. Currently driving an X35i x drive with 3rd row and M sport package. I seem to have vibration predominantly in the 2nd row seats from essentially all speeds. Even Sub 15 miles an hour. It's is more noticeable over rougher roads even as low speeds 10-15 mph. Typical vibration experience is a very quick jolt type vibration which is correlated with road surface. Additional context below
-Stock wheels -Correct tire size -Balanced wheel's tires -Front axle joint has negligible play -Guidbo and center support bearing good condition. -Transfer case bushing in good condition. -3rd row doesn't feel it. Only second row. -Engine mounts are good -Air suspension bags are good -Rear subframe bushings look suspect but could be normal. Will post pictures here in a minute. I'm not sure if these photos are normal or not of if subframe bushings could even cause an issue like this. Anyone here familiar with this type of configuraiton? I'm hoping it's something that someone has encountered before. First two photos are of the left side subframe bushing and last two are of the right side bushing? Anyone generous enough to check to see if theirs are similar to mine? I haven't found images online of hows these come from factory. In my humble opinion; they look suspect. Last edited by bigfwop; 09-23-2021 at 12:21 AM.. Reason: Spelling/grammar |
09-26-2021, 08:57 PM | #1070 | |
51
Rep 322
oh man I have this problem too, it feels like the rear suspension is bottoming out right?
the front suspension feels fine tho my car is a 2018 3.5 cpo with only 24K miles Quote:
09-26-2021, 10:39 PM | #1071 |
Rep 12
I asked a fellow X5 35i owner and he said his bushings look exactly the same on both sides (not like mine) it’s definitely a quick shimmy type feeling. I’m guessing behavior vary’s depending on how bad it is. What do your bushings look like? I’m contemplating replacing it this week but I’m not sure what kits will work so far but I’m convinced it’s clapped out for some reason. 100k is my mileage. I wouldn’t say this is typical wear but maybe others have reported this somewhere?
09-30-2021, 03:01 PM | #1072 |
Rep 2
Hi everyone has an X5 2018 model Where the driver's door whizzes and rumbles (whistles) especially at higher speeds .. have realized it can be a known problem .. still 2 year new car warranty on it .. sounds like air leakage / noise, is really annoying ..
What to do? someone who has run into the same problem ....? Another thing I have read about is that one must ask the dealer to open a PUMA case against BMW to get help from BMW on such a case, for example? I think rubber seals etc must be replaced by BMW on warranty ... |
09-30-2021, 03:25 PM | #1073 | |
51
Rep 322
09-30-2021, 04:11 PM | #1074 |
Rep 3
Welcome lights main beams code
Hey guys this has me buggered have a 2016 x5m f85 with led headlights can I ( and if can how do I ) code the main beam and or high beam to turn on with welcome lights I got the fog lights to which I don't really like but want the other beams to come on instead, I don't want to start messing with expert mode on bimmercode without knowing what to code can someone please help out
10-05-2021, 09:36 AM | #1075 |
Rep 109
Sometimes on a hot start, I feel some shakiness for about 3-5 seconds then it goes away. The same thing was happening to my previous F10, the same N55 engine was told it's a turbo wastegate. Anyone else with the same behavior? I have only 35k miles.
10-06-2021, 01:32 PM | #1076 |
Rep 19
I have 2016 X5 50i, and have some concerns I'm unsure about and was hoping to get some help. I'm stage 2 Bootmod,with downpipes.
i don't push the car, I pretty much drive like a grandpa to work and back. - at cold starts, car seems to be rough idleing. You can feel the car vibrating/shaking. once in a while when i don't have time to warm up the car and i just drive. the car seems like its about to stall/hesitates to take off. - ive noticed that after driving lets say on the highway or a long road, white smoke comes from the rear. even if the car is warm or cold it still happens. enough smoke for it to travel to the front and be visible to me and the passenger. - I do oil changes every 4-6k miles, but in between oil changes i have to add 2-3 quarts of oil . what is your opinion on what could be causing this? (spark plugs were replaced maybe 15k miles ago. (+ lower control arms, links,) ) |
10-07-2021, 02:30 PM | #1077 | |
Rep 630
The smoking issue sounds like valve stem seals. Especially if you are adding oil at that pace. What oil do you use? Try adding some AT-205 to your oil to recondition the seals. On your next oil change you can add some Lucas Oil Stabilizer as well. That's how I keep the oil consumption (and smoking issue) in check on my N62 V8 powered X5. |
10-07-2021, 03:31 PM | #1078 |
Rep 8
Installsplus465.50 |
