07-26-2014, 07:16 PM | #89 |
Rep 1,417
Folks
If I may kindly interject. You all have a point of view with your own specific facts which may not be interpreted by the other party in the exact same way. So be it. We all have good intentions and to expect perfection is sought. All of you have and hopefully will continue to contribute here with your learned knowledge to share with others. You have all contributed often, I understand that: one has assisted on at least two occasions in amicable resolutions of difference of opines between differing parties , another has assisted in product procurement with big savings, and another has provided coding & cheat sheets and all have spent lots of time sharing advice and most kind compliments to fellow owners when their new F15 arrived. It took us all a long time to get the car, so our time should be spent enjoying it. |
07-26-2014, 07:52 PM | #90 | |
Rep 3,990
07-27-2014, 03:16 PM | #91 | |
Negotiator
15
Rep 196
Drives: E60 M5 (LCI), i3 BEV
Sorry to hear about your troubles with your F15, I've been running the same chip you have for 4 months now with no issues. I know 3 other owners that have been running this same chip with no problems. Do you think possibly it was a bad install at all though? I'm no marketing expert but it doesn't help you calling RaceChip garbage and then try to resell their RaceChips on here. |
07-27-2014, 03:41 PM | #92 | |
Rep 3,990
07-28-2014, 03:29 PM | #93 | |
Negotiator
15
Rep 196
07-28-2014, 04:55 PM | #94 | |
Rep 3,990
08-01-2014, 12:38 PM | #95 |
Rep 2,485
I'm late to the party here but have been running tunes on my turbo'd BMWs for years. Racechip is simply not a player in the N63 arena. The tune sounds like some kind of off the shelf one-fits-all module modified to fit the dual TMAPs on the N63. Nobody in the N54/N55 or N63 community runs this crap.
If you are throwing codes, you are risking losing your warranty should you have some kind of failure. There is no way a Stage 1 TMAP plug in should throw codes. I would run as far away as you can and consider instead a well researched and tested flash tune like Velos or BurgerTuning's piggy There is lots of good knowledge at www.n54tech.com
2006 E90 330i (retired)
2009 E90 335i (retired) 2012 E70 X5 50i M Sport (retired) 2016 F10 535i M Sport |
09-08-2014, 02:27 PM | #96 |
Rep 3,990
@greentrbo95gst, I'd like to formally apologize to you and to RaceChip. It turns out after reading @bluelodge400's recent install of his BMS tune, my mechanic did in fact incorrectly install my tune. He installed into the wrong sensors completely and that level of disassembly was completely unnecessary. However, RaceChip themselves did not negate the incorrect location of the MAF sensors in my pics and explanation, so this further left me confused as to why it did not work. The red wire that we used was in fact the correct wire, which is referred to as the 4720 plug on page 1 of this thread. So, I'm going to give it another go and follow @bluelodge400's instructions and see if the tune works.
A big thank you to @bluelodge400 for his write-up on his BMS Tune 5.0i here: http://f15.bimmerpost.com/forums/sho....php?t=1033033 Anyone that is considering any tune for the 5.0i, please follow @bluelodge400's guide to properly install. Thanks .
09-08-2014, 03:34 PM | #97 | |
Rep 3,990
I just finished installing it and it was a breeze. They pink wire harness plugged directly into the MAF sensors on each side and I have zero errors. There is no more throttle delay in Comfort mode or Eco-Pro mode. I didn't get to test on the high-way, but I put it into Sport mode briefly and it's like a monster now. Here are pics of the install. It's very straightforward. Just like @bluelodge400's BMS install, I just plugged in the driver MAF sensor in, then plugged in the car's MAF sensor wire into the RaceChip's module and did the same on the passenger side before plugging into the tune. Thank you @bluelodge400 . Last edited by opasha; 09-08-2014 at 04:29 PM.. |
09-08-2014, 07:11 PM | #98 |
Negotiator
15
Rep 196
09-08-2014, 08:36 PM | #99 |
Rep 3,990
Everything works great as it should. The car is MUCH more powerful. However, the CEL (check engine light is back). I opened up the hood and made sure the MAF sensor wires were all secure/connected and they were. Nothing loose anywhere. I then proceeded to use ESYS to "Clear ALL DTCs" and then it went away...I turned off my car...waited a few minutes...turned it back on...the CEL returned. I then did the single Clear DTC option and this cleared it...turned off the car...turned it back on...CEL still there.
Hopefully, this corrects itself because the chip is working as it should with the factory RaceChip tune settings S1=B S2=1. I wonder what could be causing this. The CEL did not come up when I drove the first 20 minutes I got it installed.
09-11-2014, 07:12 PM | #100 |
Rep 3,990
Ok, so I decided to completely take apart the engine area myself and install the RaceChip via the MAP sensors the way RaceChip designated this tune to be installed. Let me tell you...this is not an easy at all. However, turns out, my mechanic did in fact use the wrong plug (the 4720 - red plug). This plug absolutely does not work and I don't know why it was sent in the first place...I was surprised because there's no way it would have connected to the sensors - no wonder there was a Drivetrain malfucntion. The 8720 plug (pink plug that is shorter) is the right plug that plugs into BOTH the MAP and the MAF sensors. So, I plugged it in and did the whole install myself. I'm about to go drive my car right now and will report back what I find. I also set the RaceChip tune back to factory settings (I never touched S1=1, but I change S2=B back to B from A). Hopefully, this works without errors.
If not, I completely give up and will definitely be selling this chip on ebay for $400. Please excuse my frustrations and give me the benefit of the doubt. I did this install and guide for all of you. I hope it helps. If you are thinking about this chip...I don't recommend it if you want an easy install. Go with BMS for sure. The MAF sensors are so much easier to just plug into than having to remove things to get to the MAP sensors. I feel like I have a mechanic's strong forearms now....can't remember the last time I did a good forearm workout, lol. UPDATE: I just got back from driving in all 3 modes. The car is again much more powerful (S1=1 and S2=B RaceChip Ultimate TB factory settings) and there are no issues whatsoever. No CEL or any other alerts present. So, the install for RaceChip is definitely using the pink 8720 plug into the MAP sensors in front of the intercoolers. If anyone has any questions or needs any help, feel free to PM me.
09-11-2014, 07:55 PM | #101 |
Rep 18,793
@opasha, woohooo, finally!!!
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com Memorial Day SALE!! 05/24 - 06/03 • Coupon Code: "MEMORIAL" MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
09-11-2014, 09:44 PM | #103 |
Rep 800
Hi opasha, I just read your thread and boy am I glad you sorted things out. I'm planning on getting a race chip for my e70 diesel and am wondering which one to get. I think that the most expensive one is overkill.. What do you think?
09-11-2014, 09:55 PM | #104 | |
Rep 3,990
Yeah, I ended up getting the most expensive one ($769) for $604 including tax/shipping from DTMHaus but they don't give a refund nor will RaceChip if you order from any seller other than RaceChip. If you order and are not sure if you want to keep it, RaceChip website is the way to go. Paul is pretty helpful for the tune settings. I think I misunderstood a lot of things because I did not do the install myself the first time. However, after getting my hands dirty and doing it myself this time, I not only learned more but definitely appreciate what these tunes can do for our cars. I would read about the diesel in this section http://f15.bimmerpost.com/forums/sho...light=racechip. @greentrbo95gst and @42pilot are great members with information regarding the diesel chips. @42pilot has also tested all but 20 maps of the full 89 maps for his RaceChip. I would ask him which one is the best to buy because I am not at all familiar with the e70 diesel. I wish I could tell you more, but this is also my first time using a chip...it's my first BMW as well. However, I did some research for you and found these two links kind of helpful: http://www.bimmerfest.com/forums/sho...d.php?t=715884 http://f10.5post.com/forums/showthread.php?t=883719
09-11-2014, 10:14 PM | #105 |
Rep 4,121
wow, reading your post got me all excited. Finally works.
Now go out, find some e70 x5m's and whoop on them.
Current: 21 M5 Comp, 23 M3 6spd, 23 i4, 20 Tundra TRD PRO
09-11-2014, 10:15 PM | #106 |
Rep 3,990
Thank you, my friend. I really am quite happy and feel quite bad for all my negativity in the previous pages. Never again will I let anyone touch my car until I've read through and attempted to fix things myself. Turns out I'm actually really good with figuring things out myself . The members here are far more knowledgeable than BMW and most mechanics regarding our vehicles.
09-11-2014, 10:23 PM | #107 | |
Rep 4,121
09-11-2014, 10:34 PM | #108 | |
Rep 3,990
09-12-2014, 12:02 AM | #109 |
Negotiator
15
Rep 196
Great news I guess you can consider yourself the "go to guy" for RaceChip installs on F15 . Either way glad you got everything squared away and are enjoying the tune.
09-12-2014, 12:17 AM | #110 |
Rep 3,990
Thank you, buddy. I appreciate the comment, but I'm far from the go to guy for anything, lol. I read and learn from everyone's experiences and discuss with fellow members. Every time I thought about having to even touch or remove anything in my engine, I was quite afraid of screwing something up, lol. I'm glad I have a BMW though - never thought I would buy one - I always loved their suspensions but never their interiors - too bland; however, this F15 X5 and the newer BMWs are totally different/impressive. Also, it seems to be able to endure all the mistakes I make and still work great. This is surprising to me since German car maintenance is usually quite expensive/difficult. From the negative and positive experiences everyone in these forums experiences, I learn quite a bit. As funny as this may sound, you guys are a wealth of knowledge, so thank you.
