04-15-2015, 02:12 PM | #1343 | |
Rep 115
04-17-2015, 05:35 PM | #1344 |
Rep 226
I coded the m splash screen, but it doesn't come on at every startup. Is there something else I have to code? I removed the disclaimers, and then re-added them as I thought that was the issue, but no go. Also I added the hud startup screen and that's not working correctly either.
Any help on this? |
04-17-2015, 07:30 PM | #1345 | |
Rep 424
so if you shut it down and start back up right away you not going to see it.
2015 535d Xdrive Sophisto Grey Metallic
-DUDMD Stage 1 -xHP Transmission Flash 2014 X5 50i Carbon Black/ M Sport -BM3 Stage 1 |
04-17-2015, 08:07 PM | #1346 |
Rep 18,791
Search and you shall find.
Believe it or not, I even have to search my own post. http://f15.bimmerpost.com/forums/sho...73&postcount=4
04-18-2015, 03:08 AM | #1348 |
Rep 193
04-18-2015, 03:10 AM | #1349 |
Rep 193
04-18-2015, 03:56 AM | #1350 |
Rep 1,377
Yes and no. Natively, no. However certain workarounds (such as rewriting CAFD files to include descriptive text) are starting to surface to make this possible.
04-26-2015, 07:36 PM | #1354 |
Rep 518
Drives: 2024 XM Label
Great stuff! I just added some initial basic coding to my F86 X6M (and our F56 Mini Cooper S). Will find out if the euro-style headlamp adaptive works when I get to drive at night next
Shoutouts to opasha and shawnsheridan for their support. |
04-27-2015, 08:22 AM | #1356 |
Rep 205
I've finally got around to installing the SW and am going to have a run at VO coding the LED's for anti-dazzle tonight, plus the Bluetooth. I think the SW is installed correctly though I haven't cabled to the car as of yet. The token generation was very smooth.
One question - I extracted the PSdZData .rar's but I don't know what to do with them or where to put the directory. What to I do with this data? Do I move it to a subdir of E-sys? Thanks for the help. |
04-27-2015, 08:29 AM | #1357 | |
Rep 41,196
After opening and extracting part1.rar, you should have a single psdzdata folder, which gets copied into the E-Sys data folder, e.g.: C:\Data\psdzdata
04-27-2015, 10:34 AM | #1358 |
Rep 205
One question on VLD - the OP says one only needs to VO code yet the cheat sheet has some additional VLD parameters LUT_FLC_FORWARDLIGHTING_Y & C_AFS_ENA listed for this function.
What do these codes do - are they needed to make VLD work or do they adjust how it functions? The cheat sheet isn't clear on this. |
04-27-2015, 11:23 AM | #1359 |
Rep 29
Parking lights on unlock only during dark conditions
I noticed with my E70 that unlocking the doors with the remote turned on the parking lights both during the day and at night. The new F15 has a light sensor that controls this option. It shuts off the lights during the day when you unock the car. Is there a code for setting this to always turn the parking lights on when I unlock?
I'll be coding my F15 for the Execuhitch soon. |
04-28-2015, 08:57 AM | #1360 |
Rep 518
I'd like to code the anti-dazzle headlights on my F86. Before I start, I'm a little confused by the OP instructions.
It tells me I need to remove a couple of codes from my FA (straightforward enough). It then tells me to right-click code each ECU. However, in the FDL coding section, it tells me to *never* right click code a whole folder as it'd set default F25 values for my car. (Note that it doesn't say "Default Code", but "Code"). Am I reading the instructions wrong? |
05-05-2015, 08:36 PM | #1362 |
Rep 41,196
PM sent.
05-05-2015, 08:49 PM | #1363 |
Rep 2,160
Does the F15 have rear fog lights that can be coded active?
If it can be coded=active, will it require buying a euro light switch or can the method of modifying the blank button under the fog light also work? |
