02-02-2022, 11:26 PM | #1409 |
Rep 8,364
I have never seen any coding for audible warning. Maybe someone else can chime in if they know otherwise.
03-26-2022, 06:01 AM | #1410 | |
Rep 270
Almaretto2376.00 |
03-26-2022, 06:33 PM | #1411 |
Rep 29
Hi,
Does anybody can help how to activate TPMS with Bimmercode (or e-sys if bimmercode doesn't work). My car didn't come with the tire sensors, bought and fitted all 4 but car don't see them. Made some reasearch and activate some options through bimmercode, now i can see the preassure and temperature on screen, but all blank and it showing me a RPA/RDC error. When i try to reset on iDrive it keeps telling me that the reset will do with vehicle in motion, but already drove some kms and nothing happens. Does anybody have exactly what needs to be coded ? shawnsheridan maybe ? Thank you very much. |
03-26-2022, 09:16 PM | #1412 | |
Rep 41,221
03-27-2022, 01:32 AM | #1413 | ||
Rep 7,588
Coding iDrive to display tire pressure & temp has been done…but the RDC control module isn’t installed which is what the TPM system uses in conjunction with the sensors installed in the tires. The sensors send a signal to the RDC module…if there’s no RDC sensor…how does the data get to the iDrive screen to be displayed? Changing the coding from FTM/RPA to TPM/RDC without having all the components of the latter system is probably the reason for the errors being thrown. BMW tire monitoring systems:
03-27-2022, 09:10 AM | #1414 | |
Rep 41,221
03-27-2022, 09:08 PM | #1415 |
Rep 29
03-27-2022, 09:11 PM | #1416 |
Rep 41,221
No idea. I don't use Bimmercode.
03-28-2022, 08:32 AM | #1417 |
Rep 818
Drives: BMW X5 XDrive35i
I can't for the life of me get the ambient lighting to stick to purple on my 17 X5 using BimmerCode.
Followed a couple different coding threads to try and change the RGB values. Would someone be willing to assist?
03-28-2022, 09:15 AM | #1418 |
Rep 29
Shawn,
Just got E-Sys working, can you tell me which functions values need to coded after add 2VB on FA ? The coding of BDC, HU_NBT, DSC and Kombi modules are FDL coding and need to be done, right ? Or after add 2VB on FA all FDL functions will be coded itself since i've changed the VO of the car ? Thanks. |
03-28-2022, 10:07 AM | #1419 |
Rep 7,588
…thanks…learned something new.
03-28-2022, 10:09 AM | #1420 | |
Rep 41,221
04-04-2022, 07:30 PM | #1421 | |
Rep 2,719
Drives: M3
Garage List 2016 BMW X5M [0.00]
08 BMW M3 [0.00] 14 BMW X5 50i - sold [0.00] 09 BMW 335i - Sold [0.00] 09 BMW 328i - Sold [0.00] 07 BMW 328i - Sold [0.00] |
Variante Alta95.50 |
04-08-2022, 04:46 AM | #1422 |
Rep 8
Hi Almaretto
Can you advise me on how to start downloading the installer for E-SYS and other related files for me to start coding my F15. Appreciate your kind attention. Many thanks. |
04-08-2022, 10:46 AM | #1423 |
Rep 41,221
Your Receive PM function is disabled. PM me when working.
04-08-2022, 11:07 PM | #1424 | |
Rep 8,364
h@nsX50.00 |
04-08-2022, 11:11 PM | #1425 | |||
Rep 8
Appreciate the prompt reply. |
05-04-2022, 03:34 AM | #1426 |
Rep 5
Hi, thank you for answering this question, I am having the same issue and it's doing my head in. Can you tell me where I do this in the Bimmercode app? Thanks
05-04-2022, 11:05 AM | #1428 |
Rep 7,588
According to the Bimmercode website...this coding parameter is found in the BDC:
12-30-2022, 06:12 AM | #1429 |
Rep 42
Drives: 545i,2017XC90,2018F15 X5 35iM
Not so anymore
Probably taken over by events(time), as I am running it on Android now…..
2004 545i and then 2017 XC90 and now 2018 F15 X35i Msport
01-16-2023, 02:57 AM | #1430 |
Rep 1
Hello all, anybody know how to disable the auto start/stop for 40E(hybrid), i google for weeks but i cannot find a correct way to do that, setting without expert mode won't works.
