02-16-2023, 02:44 PM | #133 | |
Rep 2,666
1. They came packaged in what looks like an OEM box. But has both front and rear sills, although the box says front two only. 2. Quality is exactly the same as OEM! 3. I had to buy the batteries separately and put them in. The two rear ones were a little tricky since I had no idea where to install them. But seller helped! 4. Unlike the OEM packaging, there are no instructions and there isn’t a plastic film to peel off. So these are clearly not ‘officially’ OEM, but are as good in every way. Here is how the rear looks… It was a little tricky to find where to stick the magnets in the rear. I can see why BMW does not sell the rears as an accessory since the magnet sticks out a bit (not noticeable unless you are looking for it, it’s in one of my photos below). The front door the magnets are hidden under the door. I used 3M VHB tape, the ones that come both here and OEM won’t stick on the plastic. Overall, a nice upgrade. For me I also replaced the front ones since they were scratched up. The original magnets aligned exactly! I noticed, if you want just the fronts you can get them for around $80 on Aliexpress and for the X6 you can get front and rear a for around $100 shipped. But I have not found anywhere where you can get front and rear for the X5. Also, those don’t come with the OEM box and till today, I have never found anything on Aliexpress that was OEM quality. These early are. They are easy to scratch. So be careful. That is true for the OEM plates as well. Installation took me 15 minutes. Put the batteries in the sills, use a pry tool to prey the ones in the car. Put these in. Find where the magnets need to go and stick them. My front magnets were already installed by the dealer. For the rears I had to find the right spot where the lights turn on when you open the door and turn off when you close etc. |
jmack1231302.00 |
02-16-2023, 04:37 PM | #135 | |
Rep 2,666
Here is a bad picture of front and rear both lit up |
02-22-2023, 11:07 PM | #137 | |
Rep 1,353
We re very few who owns the OEM rear sills!
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit |
MartindaleX5111.50 |
