06-29-2023, 10:37 PM | #155 | |
Rep 28
If it's a replacement radar from original car that already has ACC function its gonna be direct plug and play tho. Good luck with that bro ! Btw i do have an extra BE2 ACC radar that i used earlier on cos i thought i bought a broken module (which wasn't the case, of course) Let me know if u are interested ya. |
09-19-2023, 09:30 PM | #157 | |
Rep 189
SaNGRia996.50 |
04-26-2024, 10:19 AM | #158 |
Rep 651
Drives: 2018 F48 X1 xDrive 18D
Could somebody here provide me with a SVT.xml & the a .ncd of the ACC ECU?
Interested in retrofitting the radar sensor as the camera only is not optimal, but radar was never released for X1 F48 but if I have the coding files I might give it a try. |
04-27-2024, 02:31 PM | #159 |
Rep 1,353
Get a x6 ACC and do not flash. It will work without needing to calibrate. But you can default code it with your specs. I installed my radar from 750 , never calibrated or flashed and still works without any issue up to date
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit |
04-27-2024, 04:15 PM | #160 | |
Rep 651
Not sure if you or I don’t get it. F48 was never released with radar and it has an SAS ECU which is connected on S-can with KAFAS. Most of the DSC parameters(F15) are stored in SAS Ecu but not all. Either way I cannot calculate the VO because radar never existed on F48. So I have to manually FDL code all parameters, but first I need to know how to make it talk. If I can get the coding parameters sorted out, then I can see if I get an error because of missing radar. If you happen to have a list of FDL parameters between radar and non-radar that would also be very helpful. Yeah I was thinking to leave it instead of flashing once I get my hands on one. |
04-27-2024, 04:30 PM | #161 | |
Rep 1,353
As long as you have a parking assist you are good to go with SAS and DSC. If you can not add the 5AT and 5AR it will be hard to determine each parameter in each ecu. I do not have the non acc values anymore since i am on my new laptop with all new ESYS. But i can remote code the system for you if you are interested.
04-27-2024, 04:57 PM | #162 | |
Rep 651
I would like to upgrade to camera + radar based. I started mapping out the parameters here: https://docs.google.com/spreadsheets...kNFagMoek/edit |
05-15-2024, 03:25 PM | #163 |
Rep 21
SaNGRia
Thank you very much for all the info you posted, I was able to successfully to retrofit TJA and ACC to my F01 2015, I'm also doing guide on how to do it in the 7series forms but 2 questions for your, I have error in ISTA when enabling the speed to be higher than 35MPH and is there any additional setting to be added to the headunit other than NBT EVO : ACC_SGN --> aktiv and HU_NBT / HUD_DISTANCINFO--> aktiv? I don't want to reset my NBT-Evo headunit since I also retrofitted it to my car and I don't want to lose my setting. Thanks again |
05-15-2024, 05:11 PM | #164 | |
Rep 651
HUD_distanceinfo only works if you have enable it on the places as well: https://www.bimmerfest.com/threads/acc-ibrake-distance-in-hud-for-f30.969948/ |
05-15-2024, 05:13 PM | #165 | |
Rep 21
05-16-2024, 03:23 AM | #166 |
Rep 651
solidsnake2274.50 |
