05-31-2018, 11:58 AM | #155 | |
Person
12
Rep 17
It is no where near an autopilot. The road must be wide enough, clearly marked, no major curves, and it must see the car in front of you. It takes the existing Adaptive Cruise Control and makes it a little better by steering in certain traffic conditions, but you must always be attentive. |
05-31-2018, 09:05 PM | #156 |
Rep 7,165
Ok. Sold! Haha just need to figure this coding thing out. Keep getting overwhelmed when I start reading everything on how to code. I wish the app could do this. I at least understand the expert mode. Haha
06-01-2018, 10:35 PM | #157 |
Rep 7,165
Ordered today!
06-03-2018, 01:20 PM | #158 |
Rep 984
Which ECU’s did you VO code? BDCBODY, KAFAS and KOMBI as stated earlier in thread? Any FDL coding needed?
06-04-2018, 10:49 AM | #159 | |
Rep 984
Well, its not working yet. I added 5AR to the FA (verified that it took), and VO coded BDC_BODY, KAFAS2, and KOMBI. Quidzel says to VO code the whole list of ECU's at once, but my travels in the coding thread say coding the DME ECU's is a no-no unless you like bricks. I will try also VO coding the ICM ECU tonight, as it is mentioned in the cheat sheet. Oh, and don't close your trunk lid after you disconnect the battery, it is a bit of a chore to get to the manual release... |
06-04-2018, 12:04 PM | #160 |
Rep 7,165
Mine comes in today. Hopefully you get the coding to work.
06-04-2018, 12:35 PM | #161 | |
Person
12
Rep 17
ECU Section Function default New Setting BDC_BODY 3003 ComAdapterPdu_31C_Anzeige_Fahrerassistenzsystem aktiv BDC_BODY 3140 HOD_Verbaut nicht aktiv aktiv BDC_BODY 3140 LIN_VARIANTE_MFL ACC_Sport_SLD (21) ACC_Sports_STA [22] ( With M Sport steering wheel ) BDC_BODY 3140 LIN_VARIANTE_SZL szl_us_HW_aic_4Band [1D] ( With M Sport steering wheel ) BDC_BODY 3420 PERSONEN_WARNUNG_STA aktiv KOMBI 3004 DISP_CC_DRASY_ALIVE aktiv KOMBI 3004 DISP_CC_DRASY_CRC aktiv KOMBI 3004 DISP_CC_DRASY_TIMEOUT aktiv KOMBI 3004 DISP_DRASY_ALIVE aktiv KOMBI 3004 DISP_DRASY_APPL aktiv KOMBI 3004 DISP_DRASY_CRC aktiv KOMBI 3004 DISP_DRASY_TIMEOUT aktiv KOMBI KL_PREDRIVE_F17_STA aktiv KOMBI STA_ENABLE aktiv ICM 3000 C_QalcgRel_v_Tacho_aktiv_mph Werte= 20 Werte= 3F OPTIONAL This will let you increase the speed limit for TJA (MPH) ICM 3000 C_QalcgRel_v_Tacho_aktiv_kmh Werte= 32 Werte= 63 OPTIONAL This will let you increase the speed limit for TJA (KMH) ICM 3000 C_STA_Einschraenkung Autobahn keine Einschreankung OPTIONAL This will let you enable the function on all roads ICM 3000 C_Stauerkennung_on 1 need to set! ICM 3000 C_Stauassistent_Vorhanden aktiv 63KMH is the highest you can set the speed. |
06-04-2018, 02:09 PM | #162 |
Rep 7,165
These look like all something I can do in the app?! So I assume these aren't any different than the cheat sheet. If that's the case the cheat sheet even says all the other coding that's needed. Sorry rusty on different between VO and FDL.
06-04-2018, 02:58 PM | #163 |
Rep 984
06-04-2018, 09:50 PM | #164 |
Rep 984
VO coding ICM did the trick! Also FDL coded to work on all roads and max speed 63mph.
Was able to do a limited test drive and get it to steer, but will be able to test more in depth tomorrow. ICM coding throws a bunch of chassis malfunction codes, so use the transmitter section of esys to clear them. I have a CEL now, we’ll see if it goes away on its own. |
06-04-2018, 11:21 PM | #165 | |
Rep 7,165
06-05-2018, 10:37 AM | #166 | |
Rep 984
I used TJA on my morning commute. VERY COOL! Last edited by spike5150; 06-05-2018 at 10:48 AM.. |
06-05-2018, 04:44 PM | #167 | ||
Rep 7,165
06-06-2018, 08:33 AM | #168 | |
Person
12
Rep 17
When you VO code an ECM module, the system looks at your list of installed options (such as 5AR) and sets all of the values within that ECM based on what it believes the vehicle was ordered with. So if you add 5AR and the VO code the modules, it will set the values needed to enable TJA Alternatively, you can just set the values yourself by FDL coding. It produces the same result. For example, adding 5AR and then VO coding the KOMBI module will make the following values "aktiv": KOMBI 3004 DISP_CC_DRASY_ALIVE KOMBI 3004 DISP_CC_DRASY_CRC KOMBI 3004 DISP_CC_DRASY_TIMEOUT KOMBI 3004 DISP_DRASY_ALIVE KOMBI 3004 DISP_DRASY_APPL KOMBI 3004 DISP_DRASY_CRC KOMBI 3004 DISP_DRASY_TIMEOUT KOMBI KL_PREDRIVE_F17_STA KOMBI STA_ENABLE Or you can use the FDL editor and change the values yourself. You don't need to do both. |
spike5150423.00 |
06-06-2018, 09:47 PM | #169 | ||
Rep 7,165
06-08-2018, 11:29 AM | #170 |
Rep 984
More impressions:
- It drove about 3/4 of the way home yesterday on the freeway (I25). Did a great job up to speeds of about 45 mph. Above that it gets a little squirrely making corrections that are a bit overzealous. - It definitely needs wider lanes or it will shut off. I also have about a 10 min drive down a 4 lane city street, but the lanes are narrow and it works about half the time. (not really necessary to use TJA, but just testing). - Overall it was well worth the investment. Great job Quidzel! |
06-08-2018, 12:00 PM | #172 |
Rep 7,165
The new steering wheel is for the hand sensor. There is no button. It's activated with ACC.
06-08-2018, 12:27 PM | #173 |
Rep 120
There is an actual TJA button as well if you look up pictures for it so perhaps one could get a new button group if desired. So is there no way to turn off TJA when ACC is active then?
06-08-2018, 12:49 PM | #175 |
Rep 7,165
Well from what those using the quid chip are saying they're not buying a new steering wheel. Sooooooooo take that how you will. Cuz that's what I'm referring too. Now on the bottom side of the steering wheel this is a touch module which is how it senses that you're touching the wheel itself. But hey all I've done is install the chip. Haven't coded yet to prove how it works.
06-08-2018, 03:38 PM | #176 | |
Rep 1,168
EDIT: per quidzel, "– As of 5/29/2018, Bimmercode doesn’t support the modules needed to enable this feature". Ugh, my coding laptop is apparently too old for VMware... Last edited by smyles; 06-08-2018 at 04:47 PM.. |
Tags |
driving assistant, traffic assistant |
