11-07-2015, 06:38 AM | #1872 |
Rep 37
11-07-2015, 06:55 AM | #1873 |
Rep 37
Can you please pm me for the latest coding software package? I did the ambient light color coding but now totally lost all ambient light, I used to have orange blue and white. Want to add other colors but now do not have anything, I did the decoding but still the same, any advice will be really appreciated. |
11-07-2015, 07:53 AM | #1874 |
Rep 136
Thanks for the help I changed the E-sys Data path and have been able to connect and code. Was a bit overwhelming to start with but I can see how it works now, will post any further problems or findings, thanks again.
11-07-2015, 07:58 AM | #1875 | |
Rep 41,143
Newer PSdZData though is only needed if you can't read ECU or you plan to update firmware of ECU. It is not going to code any differently than you current working PSdZData. Leave car off for 1 hour. Ambient lighting should return on its own.
11-07-2015, 08:18 AM | #1876 |
Rep 48
Drives: BMW X5(G05) 2019
Anyone?
without toggle, Is it possible to display icons , such as the photo ? I 've done add 5AC. And Vo Code BDC_Body,HU_NBT,KAFAS2. BDC BODY 3068FLA_AKTIVIERUNG→set to: LDS_in_A_oder_2 HU_NBT 3000HIGH_BEAM_ASSISTANT→set to: aktiv KAFAS2 3050FLA_ON_OFF set to:ON What could be missing ? Steering column control unit? |
11-07-2015, 08:48 AM | #1877 |
Rep 5,483
Is there someone in the GTA (Toronto) area who can help me code my incoming X5?
Current:
2019 BMW X5 40i - Carbon Black/Tartufo Individual Leather 2020 Range Rover HSE - Black/Black 2020 Audi R8 V10 Performance Spyder 6MT - Ascari Blue/Black |
11-07-2015, 02:53 PM | #1878 | |
Rep 37
Hi Alan,
I have tried to code this, but I do not have DSC folder, only DSC2 , are they the same? When I right click the code button, at the end of coding section, it pop up with negative response, general global response failed, code failed. But SBRE is already under HO-Wort folder. During the coding period, my X5 also pop up message on screen shows Attention ABS Warning, please try to avoid emergency brake, contact your nearest local BMW service centre. Do you know anything about this? Many thanks Quote:
11-07-2015, 08:36 PM | #1879 | |
Rep 1
Could you please pm me for the latest coding software package? Thanks! |
11-07-2015, 09:21 PM | #1880 | |
Rep 8,835
Does your brakes feel firmer after coding? Alan |
11-07-2015, 09:22 PM | #1881 |
Rep 41,143
PM sent.
11-08-2015, 05:15 AM | #1882 | |
Rep 37
Charles |
11-09-2015, 08:21 PM | #1884 |
Rep 1,015
Any way to turn off the temperature warning that occurs at 37 degress?
2025 X7 40i -- (previous-2024 X5 50e -- 2024 X7 M60i -- 2021 X7 40i -- 2019 X7 40i -- 2017 X5 50i -- 2015 X5 35i)
11-09-2015, 08:25 PM | #1885 |
Rep 41,143
You can try coding Kombi => CC_TEMPERATUR WARNUNG = nicht aktiv, but it may be hard coded.
11-09-2015, 10:30 PM | #1886 |
Rep 1,015
Thank you, I'll give it a try.
11-10-2015, 12:14 AM | #1887 | |
Rep 18,777
11-10-2015, 10:15 PM | #1888 |
Rep 13
Dealer Up grade during service
I am going to have my 2015 x5 coded this weekend. New to this forum I have read that after you code your veh, if you bring it in for service.There is a chance your service adviser might update your software which if I understand would erase all your codes. Is this true If so is it possible to copy them to (poss usb). How often does BMW come up with these up dates. Being a senior citizen I am not computer savoy. Any info regarding my concerns would be greatly appreciated.
11-10-2015, 11:07 PM | #1889 | |
Rep 18,777
You can always tell the service advisor that you don't want any software update. Unless if it is going to fix some issue that you have been having.
11-11-2015, 05:20 PM | #1891 | |
Rep 37
yes it does feel the car's brake more firmer.
11-14-2015, 08:23 AM | #1892 |
Rep 577
I checked the Google doc and didn't see it but I wanted to ask.
Can you code a digital speedometer where the selectable instrument cluster information is? |
