01-29-2022, 07:26 AM | #177 |
Rep 270
22' Shadow Cruiser with my 35d M Sport w/air suspension?works like a charm!
Stays beautifully flat on the road and behaves well with no WD equipment.
lht5059121.50 |
02-09-2022, 03:36 PM | #178 | |
Rep 157
Drives: F82
Controller and Wiring
So regarding your brake controller, it seems theres 2 connections being made. One to the vehicle and one to the trailer? Is this correct? I'm just trying to understand the missing piece which is the brake controller and how thats integrated. I have the stealth hitch and a trailex trailer with electronic brakes. |
02-10-2022, 11:41 AM | #179 | |
Reads books at a 4th grade level; I'm an enabler
78
Rep 116
Drives: X5 35d, 335i Msport, X3, 325iX
Garage List 1993 BMW 525iT [0.00]
1989 BMW 325iX [0.00] 2015 BMW 335i M-Sport [0.00] 2007 BMW X3 M-Sport [0.00] 2015 BMW X5 [0.00] |
Unfortunately it is super hard to find the correct wiring diagrams from BMW. The TIS shows the 13 pin European diagram, not the 7 pin US. While the US installation instructions shows A13 as the 4 pin connector in question, it still shows the incorrect wiring diagram for the US application. Long and short is that US spec trailer brake controllers function off four wires: Battery (12V+) - Black Brake Light (Signal) - Red Trailer Brake Power - Blue Ground (-) - White On the BMW harness at A13 this is: Battery (12V+) - Red Brake Light (Signal) - Black/Yellow (2 Wires) Trailer Brake Power - Yellow/Green Ground (-) - Brown The Battery Wire and Ground Wire are the power circuit FROM the F15 TO the Brake controller. This is simply analog 12V+ from Fuse F139 in the rear fuse panel, and Ground at Z10*14B. It should be noted that Fuse F139 also feeds power TO the 7-pin trailer connector at Pin 4. The Brake Light wire is a SIGNAL wire FROM the F15 TO the controller to let it know the brakes have been applied. AFAIK (again with no diagrams to support in front of me at the moment) the SIGNAL is generated by the AHM from the CANBUS signal produced when one applies the brakes. It is sent TO the controller as an analog 12V signal. The Trailer Brake Power Wire is an OUTPUT FROM the Brake Controller TO the 7-Pin Trailer Connector (via Pin 2). This is an analog voltage ranging from 0 to 12 volts based upon the settings of the brake controller itself. |
02-16-2022, 06:54 PM | #181 |
Rep 43
Beautiful Yamaha. Do you have air suspension? Any squat?
02-19-2022, 12:17 AM | #183 |
Rep 17
04-14-2022, 11:45 AM | #184 |
78
Rep 116
Tow pig, doing tow pig things. Why tow one trailer when you can run two at the same time. Yes, the tongue is little high.
04-30-2022, 08:42 PM | #185 |
Rep 5,025
Ok gang - Towing noob here looking for advice.
X5 details: - 2014 x35i w/ air suspension (fresh air bags) - Curt class 3 hitch https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 - Towing for about 7 hours - Currently, the OEM trailer integration harness is not fully plugged in and coded. I'm going to be renting a trailer from U-Haul and towing an E46 M3 vert. About 3,800 lbs + Trailer. Questions: - What ball mount should I get? - What height should the hitch be off the ground with it loaded? - I need to get the trailer towing harness plugged in and coded right? Otherwise, I won't have brake lights right? Please excuse my nOObness - very happy to join this thread and learn from you gurus. I've towed before, but not with this rig - only with U-haul moving trucks that are all set up already. Thanks! |
04-30-2022, 09:17 PM | #186 | |
Rep 60
From U-Haul: “ The optimal ball height for towing U-Haul trailers is 18½ to 18¾ inches.” And yes, from memory, you should get the harness installed and coded so that when the 4-pin connector from U-Haul is plugged in, your brakes and blinkers work. They won’t let you drive off if the lights don’t work. |
tlow982195.50 |
04-30-2022, 10:24 PM | #187 | |
Rep 5,025
Much appreciated. I'll take a stab at the wiring tonight. The rear OE exterior plug is already mounted and the wire harness is just hanging out in a coil in the rear of the car. I'll also stop by U-Haul and get a ball. I bet that will buy some brownie points too. Thank you much! |
10-06-2022, 01:17 PM | #189 |
131
Rep 305
11-01-2022, 10:47 AM | #191 |
131
Rep 305
X5 35i - tows pretty decent averaging 16mpg around 4Klbs, would not want to tow into the mountains but otherwise pretty solid. Using the Curt bluetooth brake controller is also quite nice.
11-01-2022, 11:02 AM | #192 |
Rep 5,025
I thought the same about the mountains, but I had to get over a couple large passes (2,500ft gain) and it did well, albeit just maintained a steady climb. Now, if I had to go over the Rockies at elevation I’d probably think about it differently…
11-05-2022, 10:24 PM | #193 |
Rep 2,975
Hey guys,
Looking at an X5d : WITHOUT rear air suspension. Has: S508 Park Distance Control (PDC) S522 Xenon Light S524 Adaptive Headlights S563 Light Package S575 Additional 12V Sockets S5A1 LED Fog Lights S5AG Lane Change Warning S5AT Driving Assistant Plus S5DL Surround View S8SL Trailer Coupling Preparation Plan to be towing right around 5000lbs long distances 5+ hours every month. How detrimental will this be, not having rear air suspension? Many thanks in advance |
11-10-2022, 02:52 PM | #194 | |
131
Rep 305
11-11-2022, 01:22 PM | #195 | |
Rep 5,025
I would think if you were doing regular towing and distributing the weight correctly you’d be better off than with air bc you’d know the weight was right and the air bags wear out fast enough, already. |
beattiecj130.50 |
02-07-2024, 11:58 PM | #196 |
Self Proclaimed Roundel Junkie
630
Rep 1,595
Excited that I get to share in this thread now. This was my first tow, learning as I go and starting to research trailers and potentially make a purchase.
2018 F15 X5d Carbon Black/Nutmeg Individual- Oil Burner Tow Rig
2013 E82 1M3 Carbon Black/Black- S65/DCT Track Toy 2013 F25 X3 35i Alpine White/Chestnut- German American Family Hauler Past: '11 E91 335is, '11 E90 M3, '10 X5M, '14 328d, '03 330i Dinan3 ZHP, '04 330i ZHP, '12 X3 35i |
Edwardsc1255.50 |
02-11-2024, 06:11 PM | #197 |
78
Rep 116
I spent the spring/summer with the 335 parked on the lift, and the 325iX underneath it whilst we remodeled the kitchen. And then a mere 9 months, and a quick 1450 mile trip later...we brought home my wifes new to her M240Xi. Be careful where you leave cars laid up folks.
74.5mph average from Detroit south to Toledo then most of the way across the the Ohio and PA turnpikes, 18.7 mpg. Probably could have done better if I didn't decide to set the cruise control and forget it coming home. |
beattiecj130.50 |
