      07-18-2017, 09:49 AM   #177
Originally Posted by artem123 View Post
Everything else is working for me, but 5 blinks. My car just refuses to take it.
Same here, I have tried numerous times. No luck
      07-18-2017, 09:52 AM   #178
SCA
SCA's Avatar
Drives: Multiple BMWs
If I am not mistaken didn't this use to be changeable within iDrive?
      07-18-2017, 09:57 AM   #179
1coolF15D2017
Drives: 2020 X5 G05
Only two choices on iDrive under "My Vehicle" -> "Exterior Lighting". 1 and 3 blinks are the options.
Two things don't work for me on Bimmercode App, 5 blinks and video in motion. Tried every possible options and tried many times too but failed.
      07-18-2017, 10:03 AM   #180
SCA
SCA's Avatar
Has anyone contacted the App developer over either coding issue?
      07-18-2017, 10:42 AM   #181
1coolF15D2017
Drives: 2020 X5 G05
I did. and I posted it on page 7 of this topic.
"Developer said that the value of 02 is correct and with newer iSteps it works for some and not for others."
      07-18-2017, 01:41 PM   #182
mvigod
mvigod's Avatar
Drives: 2021 X5M
Originally Posted by eggyacid View Post
I use vgate3 and it works great, make sure slow communication is turn ON
I was going to buy the vgate2 just now but there seems to be two of them on amazon.
Does anyone know which of these two is the correct one? I think they might be the same but want to be sure. My wife's X5 coding was blown out at the dealer and I want to use this app to put back the things she lost.
http://amzn.to/2tcEpHW
http://amzn.to/2tDpDtf
Also is there any reason I should consider the vgate3? Any advantage?
Update: This is the correct one according to developer: http://amzn.to/2u73tTG
Last edited by mvigod; 07-18-2017 at 03:19 PM.. Reason: update to correct OBD link
      07-18-2017, 01:57 PM   #183
zinengineer
zinengineer's Avatar
207
Drives: 2016 Space Gray X5 M Sport
I bought the "2", it's the recommended version
2016 X5 35i Xdrive M Sport; Space Gray Metallic/Mocha Dakota
2014 535i Xdrive luxury line; Black Sapphire Metallic/Black Dakota
mvigod181.50
      07-18-2017, 02:15 PM   #184
mvigod
mvigod's Avatar
Drives: 2021 X5M
Ok thanks. of the two in the links above is one preferred? The title descriptions are somewhat different although both are vgate2 wifi obd. I'm thinking the slightly more expensive one with reviews and available in colors is the right one but want to be sure.
      07-18-2017, 03:15 PM   #185
SCA
SCA's Avatar
This is the one recommended by the app developer via the Bimmercode website: https://www.amazon.com/dp/B06XGFTZ5R..._5UMBzbJ4ST4QN
mvigod181.50
      07-18-2017, 03:56 PM   #186
mvigod
mvigod's Avatar
Drives: 2021 X5M
Thanks. It's on its way! Wife gonna be happy
      07-18-2017, 04:19 PM   #187
sigx5
Drives: X6
Hi Violator,
which Vgate version you have? version 2 or version 3?
I have version 3 and thinking to get version 2 ...maybe OBDII H/W causing the issue
      07-18-2017, 04:22 PM   #188
zinengineer
207
yep, that's the same one I purchased.
happy wife = happy life
      07-18-2017, 05:07 PM   #189
sigx5
Drives: X6
So you all are successfuliy using Vgate version 2 to code "number of blinks on lane to 5"?
      07-18-2017, 05:34 PM   #190
MysticBlue
Same here. I select 5, but it just doesn't work.
M3: Active Autowerke filter, Dinan underdrive pulley, Dinan full exhaust and software, 3.45 Differential, Springs, Brakes, Dinan/HRE wheels, 275/30-19 w/10mm spacer, 295/30-19 w/3mm spacer, painted front reflectors, 30% tint, Escort 8500i & Lidar Jammer, LUX H8 V5 halos, Euro rear foglights, 3M ClearBra.
artem123251.50
      07-18-2017, 06:29 PM   #191
sigx5
Drives: X6
Good to know ...
I have Vgate V3 version but failed to code it as 5 times; ordering another Vgate V2 version to see if OBDII H/W version difference is the root cause.
      07-18-2017, 09:03 PM   #192
zinengineer
207
Yes, maybe it's version 2 vs 3 ??
      07-18-2017, 09:14 PM   #193
Kr0m3assass1n
kr0m3assass1n
Kr0m3assass1n's Avatar
Drives: 22 X7 M50i
I used a 2 and was able to code successfully to 6 blinks.
      07-18-2017, 11:33 PM   #194
Hi Violator,
The 3, originally I purchased a 2 but it was a defective unit so I returned it for a 3.
      07-19-2017, 01:23 AM   #195
sigx5
Drives: X6
BimmerCode just releases new update ... version 2.0.11 ...
      07-19-2017, 11:43 AM   #196
wjdunn3
Drives: 2014 X5 xDrive35i
I have the Vgate 3 and have no problems coding with it. I even coded the blinker count to 5 with success on my MY2014. I don't know why some have problems with coding the blinker count... I suspect it has more to do with the I step or idrive version of the vehicle. I don't think it has anything to do with the Vgate version.
      07-19-2017, 11:59 AM   #197
1coolF15D2017
Drives: 2020 X5 G05
That is what the developer told me. It has something to do with the newer I Step since I have 2017 model
      07-19-2017, 12:02 PM   #198
Well mine is a 2016 and it won't take.
