03-06-2016, 08:55 AM | #2157 | |
Rep 7
Many Thx Shawn, re-coding everything by adding 2VB and found out below are the difference when changing FTMS to TPMS HU_NBT --> RDC --> nicht_aktiv [00] --> aktiv [01] HU_NBT --> RDC_DRUCK_TEMP --> nicht_aktiv [00] --> druck [01] HU_NBT --> RDC_FORTSCHRITTSANZEIGE --> nicht_aktiv [00] --> aktiv [01] HU_NBT --> REIFENUEBERWACHUNG_RDC_RPA --> rpa [01] --> rdc [02] HU_NBT --> RPA --> aktiv [01] --> nicht_aktiv [00] DKOMBI --> DSC_MIT_RPA --> mit_RPA [01] --> ohne_RPA [00] ICM --> QdmRdcDep --> noRDC [00] --> isRDC [01] DC2 --> Funktion_ReifenPannenerkennung_aktiv --> aktiv_RPA mit Koordinatorfunktion im DSC [02] --> aktiv_RDCi mit Koordinatorfunktion im DSC [03] BDC BODY --> RC_RDC_ENABLE --> nicht_aktiv [00] --> aktiv [01] |
03-06-2016, 12:35 PM | #2158 |
Rep 41,178
No, 58.0 is latest. PM sent.
03-06-2016, 02:11 PM | #2160 |
Rep 41,178
03-07-2016, 03:44 PM | #2161 |
Rep 75
Hi Shawn! After recent software update at BMW service I started coding from scratch.
Everything was well, but after I changed the values and get back to CAFD folder to Code FDL it gave a window with message: ABORT! ASYNCHRONE PROGRAMMING FAILED! [C049] TASK EXTENSION CONFIGURATION MISSING IN CONTAINER - MAYBE THE TEMPLATE IS TOO OLD [1906] and then click CLOSE and another message with PSdZ Error saying the same: ABORT! ASYNCHRONE PROGRAMMING FAILED! [C049] TASK EXTENSION CONFIGURATION MISSING IN CONTAINER - MAYBE THE TEMPLATE IS TOO OLD [1906] Any thoughts? What should I do? Thanks, |
03-07-2016, 05:10 PM | #2162 | |
Rep 41,178
03-07-2016, 06:38 PM | #2165 |
Rep 41,178
03-08-2016, 07:22 PM | #2166 |
Rep 75
Hey Shawn!
As always you're the best! After I downloaded v.58.0_PSdZData_Lite from your direction of link and updated E-sys to 3.27 everything went nice and smooth! I coded my "baby" successfully! Thanks a lot! I tried your version to change setting "Ignition and radio OFF after driver door open" but it doesn't work. I changed value to "aktiv" in CLI_DEFAULT_UNLOCK_AFTER_END_OF_DRIVING" in BDC_BODY 3041 Any advise? |
03-08-2016, 08:02 PM | #2167 |
Rep 41,178
I replied to your same PM. I do not know why it is not working.
03-09-2016, 12:33 PM | #2168 |
Rep 75
Hi guys!
What happened to "Unlock when STOP Engine" in BDC_BODY 3040 VAM_UNLOCK_KL15OFF_AFTER_PIA_AUTO_LOCK Such a convenient option but doesn't have "aktiv" option on 'EDIT' Does anybody figure yet? I tried CLI_DEFAULT_UNLOCK_AFTER_END_OF_DRIVING" in BDC_BODY 3041. It is not working... |
03-09-2016, 01:16 PM | #2169 | |
Rep 1,181
Regarding your other question about the radio turning off after engine stop, I coded "TCM_LOGIC_R_OFF_DOOR" under section 3020 vs the one you tried. Overall, some of these items are finicky in operation. For example, the radio will stay on if I had my foot on the brake pedal when I stopped the engine. Another example is with the folding mirrors. Regardless of whether I am using the fob or CA, the mirrors will not fold if the front passenger door is open. The rear doors can be open while you lock the car and the mirrors will fold. Not so with the front doors. Car will lock, but mirrors won't fold until you lock again after door was closed. Just nuances...
03-09-2016, 02:41 PM | #2170 | |
Rep 75
I'll differently try "TCM_LOGIC_R_OFF_DOOR" in 3020 Thanks! |
03-09-2016, 02:43 PM | #2171 | |
Rep 75
03-09-2016, 04:41 PM | #2172 | |
Rep 1,481
Coding error for all door unlock? Bad ECU code?
2015 Mineral Grey ///M4 6MT
03-10-2016, 04:39 PM | #2173 |
Rep 289
europe
anyone can recommend good coder in Europe?
want stuff like dvd play in motion and rear DRL on etc.... Last edited by pragueX5; 03-12-2016 at 03:27 PM.. |
03-12-2016, 04:12 PM | #2175 |
Rep 41,178
PM sent.
03-12-2016, 10:20 PM | #2176 |
Rep 48
Drives: BMW X5(G05) 2019
I've Question Traffic JAM Assist.
Hi
Hello I am interested in the traffic jam assistant. I was fitted with a parts and add code 5AR to VO Code and VO code the following ECUs: BDC_BODY, KAFAS, ICM and KOMBI. Touch sensor module Steering wheel wiring harness for Touch sensor module M Sport touch-enabled steering wheel When I start to when the vehicle is stopped it becomes as standby photo. But car will start running when the error. ”Traffic jam assist Abnormality" What are the things that do not have enough to me? ・calibration of module does not conduct.(Need Reingold?) ・My car doesn't have parking assist option Need it?(Auto handle control?) thanks Last edited by Hideada; 03-13-2016 at 07:42 AM.. |
03-13-2016, 08:23 AM | #2177 |
Rep 48
Hey Shaun,
Car just returned from service and I'm getting a can't find CADF error when trying to code BDC_BODY. I'm on PSD v57.3 and Esys 3.27.1 - Assume I need an update. Could you PM latest links pls. Thanks |
03-13-2016, 01:00 PM | #2178 |
Rep 41,178
PM sent.
