01-27-2015, 07:04 PM | #1 |
Rep 710
Finally used my pre-heat function this morning
It was below freezing this morning and the car was outside (hey, it's Georgia - that's cold) so I decided to use the pre-heat function on the 35d. I didn't notice anything different - but maybe it did fire a bit quicker. It was on for only a second or two. My pickup glow plugs stay on for about 5 - 6 seconds.
Do you guys in colder climates need it and use it?
01-28-2015, 05:33 AM | #3 |
Rep 420
Yes i have used It a couple of times but only the "activate instantly mode" not the "time set mode" and it worked fine accept the seat heating that is to suppose get active as well, haven't felt any heat in the seat non of the times I used it. Just to check, eu spec 30d have the settings for pre-heat in: idrive-settings-klimatecontroll-pre-heater and the you have three options: activate heat instantly when car is of---activate by start time----settings for seat heater whit pre-heat
01-28-2015, 05:42 AM | #4 | |
Rep 1,368
Assuming you don't have Auxiliary Heating app lets you set departure time and will ventilate or heat car depending upon the temperature. |
01-28-2015, 08:32 AM | #5 |
Rep 198
Pre-heating appears when temps outside are really low. and usually takes a couple of seconds and then you can start the engine. As far as I know, it prepares the engine for this cold start. I noticed that it appears when you press the start button without pressing the break pedal. After the sign 'Pre heating' is gone, then you can step on the break and press the button again and the car should start.
Auxiliary heating warms up the passenger cabin. I am pretty sure it does not do anything to the engine. Can anyone confirm? It has two timers for preset time of departure + an 'activate now' option. You can also set those three via the remote of the auxiliary heating. Works great for me and heats up the cabin really nice. Btw, auxiliary heating comes with auxiliary ventilation that should be able to cool your car in the summer before you get in. Yet to be tested... |
01-28-2015, 08:58 AM | #6 | |
Rep 1,368
01-28-2015, 09:43 AM | #8 | |
Rep 1,368
Would make sense; if you need it anywhere its in the land of Molson, Back Bacon and Tooks |
01-28-2015, 09:48 AM | #9 |
Rep 710
The pre-heat system I am talking about is the diesel glow plugs for the engine.
To activate it, keep your foot off the brake, then press the start button. You should see an indication lamp stating "Pre-heating - Please Wait" (these are the engine glow plugs). It shows in the lower left side of the dash and will go out rather quickly. The temps here in Atlanta are in the 30's so it's not critical to pre-heat the engine and the cycle time is short. If it gets below freezing, I would always use the pre-heat (diesel engine glow plugs) to take stress off the starter. I did not get the option that allows me to plug in the block heater like my diesel pickup. This pre-heats the oil as well and is mandatory below 25 degrees - this engine needs oil for lubrication and firing the injectors.
01-28-2015, 05:31 PM | #10 | |
Rep 420
The best car ever: E34 M5 3.8l daytonaviolettmetallic hos Mälardalens Ventilationsceneter
01-28-2015, 07:07 PM | #11 |
Rep 710
I wasn't very clear - no problem. I used the terminology that shows on my dash. Normally I would just say "the glow-plugs" since it's diesel.
