      01-19-2015, 10:42 AM   #89
42pilot
42pilot's Avatar
593
Drives: 2014 X5 35d MSport
Originally Posted by JensM View Post
Regarding the 'burnt plastic smell', I am pretty sure this is coming from the diesel particle filter cleaning circle. When it cleans, it smells a bit like an overheated engine and you will hear a lot of 'ticking' sounds. Do not believe this is related to the RC chip nor settings. All diesels do this
JensM
Good info - thanks
      01-19-2015, 10:52 AM   #90
42pilot
42pilot's Avatar
593
Originally Posted by Trojanlaw View Post
Have you seen any significant change in you mpg going from E to F?
Yes, because I am driving differently. I went from 28+mpg avg (calculated, not from the dash) to high 26's.
Remember, the chip only works in a certain RPM range and only when you call for it - acceleration. Otherwise, at cruise, start, decelleration, it has no affect.
      01-19-2015, 11:01 AM   #91
Trojanlaw
Trojanlaw's Avatar
Drives: 2019 X5 40i M
2019 BMW X5  [0.00]
Just out of curiosity what does your dash say that you were averaging?
      01-19-2015, 01:28 PM   #92
CERS 1
Drives: 2015 x5 50i
1. Same way as the others. Put in Sports + mode. Put in drive and place shifter to left in S1 mode. Push hard on the brake all the way down. Push the accelerator all the way down and the Launch control flag should appear. Release the brake within 3 seconds and the car will take off.
2. Not sure. It launches upon the release of the brake but it is fairly high.
3. Not sure unless it shifts the transmission to M line characterisitics. Still waiting to confirm.
4. This is for US models. Comes standard in M Line and possibly included with DHP as well.
Thanks for the reply. Does this mean that for a US M sport that Launch control is already coded? I have Sport and Sport+.
      01-19-2015, 01:43 PM   #93
rosenbergendo
119
Drives: 2016 Porsche GT3RS, F80 M3,997
My US M-sport has launch control coded yes.
      01-19-2015, 01:53 PM   #94
opasha
opasha's Avatar
1331
Drives: 2014 BMW X5 50i
Trojanlaw, thanks for the helpful responses and tests . I also looked at the Sport Auto and Launch control codes yesterday on gatordent's cousin's car. All of those codes are as follows:
Enable Launch Control: requires Sport Auto Transmission coding below
1) EGS / LC / nicht_aktiv to aktiv
Enable Sport Auto Transmission:
1) EGS / Sportschalter / nicht_aktiv to aktiv (Part 1)
2) EGS / Sportschalter_alt / nicht_aktiv to aktiv (Part 2)
I will add them to the cheat sheet later today .
Yes, you should have Launch Control activated by default.
      01-19-2015, 07:06 PM   #95
42pilot
42pilot's Avatar
593
Since I've had it, it's always about 1 1/2 to 2 mpg too high.
      01-20-2015, 02:40 AM   #96
JensM
Germany
68
Drives: BMW X4 M40D 2019
Originally Posted by paicapo View Post
I have read about this as well but I don't think that's it because the dpf is on the opposite side of the high pressure pump and the smell and heat was definitely from the right side of the engine standing facing the engine bay, also the fuel rail was hot hot hot but I could be wrong smell and stuff travels in a engine bay were it sometimes can be difficult to determine the source
Paicapo,
I think it is difficult defining exactly where a smell/sound like this are coming from. I experienced it first time on a Toyota 2.2 DCat Diesel, could not isolate where smell came and noise came from - went to Toyota and he confirmed it was the particle filter cleaning. Two other Toy Diesels, my F25 and now E70 smells/ticks regular. Can off course not say that your sound is 100% related to this. Maybe check with BMW?
      01-20-2015, 05:48 AM   #97
paicapo
paicapo's Avatar
265
The self-cleaning of the DPF surely seems to be the likely when think about all the symptoms, strange smell, little bit of rattling etc, was just a strange coincidence me trying new setting on RC but if it happens again I will detune and set a time whit bmw, I'm allways very dubious when it comes to coincidences thanks for the help!
      01-20-2015, 11:41 AM   #98
42pilot
42pilot's Avatar
593
I spoke to two different dealers I work with in Atlanta, and both said this is not the case. The US diesels do not re-gen as pickup truck diesels do. I don't like the engine rattling noises, so I will back off until I learn more from BMW shop notes...
      01-20-2015, 11:57 AM   #99
JensM
Germany
68
42pilot, I am pretty sure the EU 30D and the US35D is identical and cleaning should be identical- just Bmw marketing ( however read somewhere that the U.S. version might have the same cooler as standard as EU get when buying the Bmw mpp box). The particle filter cleaning cycle should be identical. What can change how often and for how long the clean takes is individual as it is related to driving style. Here in EU diesel are dominating even though many would do better with a petrol as they do not drive enough km - the engine does not get warm enough. This is why so many clock up the engine with carbon. In those situations the particle filter will happen more often and take longer. But you say rattling noise - the Dpf clean noise is like small ticks not rattling. This may be something else but not sure what
      01-20-2015, 12:04 PM   #100
Trojanlaw
Trojanlaw's Avatar
2019 BMW X5  [0.00]
42 Pilot -
So would you recommend E3 or F2? I have been pretty satisfied with E3 but have not tried F yet to feel the difference. Which is giving you more kick? E3 or F2?
2019 X5 X40iM
      01-20-2015, 12:50 PM   #101
paicapo
paicapo's Avatar
265
The 35d actually has a different dpf than the 30d but the dpf have to regenerate regardless or
it will cloag up but facts in this mather would be good, have been searching for this on the m57d30o1 whit no luck so far, seems to be regeneration in different cycles but that pretty obvious.
      01-20-2015, 12:58 PM   #102
Trojanlaw
Trojanlaw's Avatar
2019 BMW X5  [0.00]
Racechip Update
According to the new manual, on page 9 of the newly printed manual, Racechip is now officially reporting the following for the 35d chip:
Base: E0
Performance Level 1: E2
Performance Level 2: F3
This is the first time I have seen Racechip actually provide an opinion. Based upon this, I am going to stick with F3.
It also suggests that the E3 setting may not get enough fuel to be as efficient as it needs to be. Thoughts?
2019 X5 X40iM
      01-20-2015, 01:17 PM   #103
opasha
opasha's Avatar
1331
Base: E0
That could very well be true. I wonder if the forums caused them to update those settings and revise their manuals since many people were complaining about both not being given by RaceChip.
      01-20-2015, 01:40 PM   #104
JensM
Germany
68
Was not aware of this, but as you say - one way or another it has to regerate.
      01-20-2015, 02:34 PM   #105
42pilot
42pilot's Avatar
593
Wow - that's too much of a coincidence.
For your info, I am now at 03. After 35 miles, no rattling, strange smells, etc. Very nice throttle response, cruise, and very very nice roll-on power from 55mph to 80mph.
      01-20-2015, 02:39 PM   #106
opasha
opasha's Avatar
1331
Yeah, seems like it .
Very nice .
      01-20-2015, 02:43 PM   #107
42pilot
42pilot's Avatar
593
Yep - facts. Thanks for continuing to dig into this. Even after speaking to two dealers (BMW of South Atlanta and BMW of Gwinnett), I don't think they were speaking with all the facts. It has to regen if it has the same structure as our diesel pickups. On pickups, they regen between 500 and 1500 miles, depending on driving. In 08 model trucks, they even tell you when they are cleaning the filter. Maybe there is a message in the coding??
      01-20-2015, 04:55 PM   #108
paicapo
paicapo's Avatar
265
It shure is
      01-20-2015, 05:00 PM   #109
paicapo
paicapo's Avatar
265
Is the F setting impacting your MPG at all?
Is the jump from E to F noticeable?
Thanks for testing this for all of us!
No my MPG are the same as in E/3, as soon It dries up here I’m going to do a 0-60 run the car feels pretty fast
      01-20-2015, 05:11 PM   #110
paicapo
paicapo's Avatar
265
im thinking about changing the stock intercoller to this one:
http://www.kempower-motorsport.com/i...oduct_id=26046
I think it’s the Wagner intercooler you guys have in NA.
The 30d/35d seems to boost max 1.5 bar (21.7557 psi) so whit this intercooler everything over approximately 1 bar will give a HP gain and it should be especially good whit added fuel from RC, any thoughts?
