07-22-2016, 06:20 PM | #2619 | ||
Rep 8
07-25-2016, 06:45 PM | #2620 |
Rep 8
new values after dealer recode?
So I took my 2015 35d in for an oil change and they did the "EGR coding". When I got it back all prior FDL coding was lost, but the VO coding remained. In addition, the werte values for the GFHB remained, but the VO values had been reset.
Anyhow, when I got to the VLD section of the cheat sheet, I went to set LUT_FLC_FORWARDLIGHTING_Y and the possible values are now: - F015Codierwert,F015Codierwert,F015Codierwert,F015C odierwert (yes, that's one value and it's the current one) - I001Codierwert ohne AFS - F015Codierwert So, no value of F015_mit_AFS - not sure how to change it. Any thoughts? I am using version 59.1 of psdzdata, and according to the i-step lookup 59.0 should be good enough. In addition, I tried to set the AC memory in IHKA2, but all function names are numeric. |
07-26-2016, 05:51 AM | #2622 |
Rep 40,884
PM sent.
07-26-2016, 12:28 PM | #2623 |
Rep 158
Hi Shawn I'm new in this coding, I just pay to code my 2015 F16 last month and few codes couldn't change. like DRL with fog lights same time. can you please help me with this and the latest PZD.I will appreciate.
2016 X6 M PACK/MPPK
RACECHIP BLACK GTS RACECHIP XLR |
07-26-2016, 08:37 PM | #2624 | ||
Rep 8,364
If you wrote FA changes to VCM, like me, they remained and were used to program vehicle. If not, you may need to re-VO code vehicle before making the various FDL changes. In general, just make sure to check all coding. And, for NGHB specifically, ensure the werte values are right, especially when various predetermined drop-down values referenced in guide are not available. Further, on my X5's most recent update, not all ECU modules were updated, which is normal because new software does not always come out for every ECU in each ISTA-P release. However, I found it interesting that some of the ECU's that were not updated still were reset to factory values while others retained my codings. Re AC Settings: Strangely, post update, hardware (HWEL) remained the same, but it was the first time I saw CAFD_ID's change. In my case, IHKA_CBF (CAFD_00000092) was switched to IHKA2 (CAFD_000047D6). The ladder is not mapped, however, I successfully can use the former as a guide to code AC memory. There are other instances like using DSC_CT02 (CAFD_0000121C) for unmapped DSC2 (CAFD_0000297A). For IHKA2, use 3000_5_5_16 nicht_aktiv → aktiv Quote:
07-26-2016, 08:58 PM | #2625 |
Rep 158
I mean having the regular DRL headlights(halo rign ON) With the Fog lights (that's already LED)at the same time .
2016 X6 M PACK/MPPK
07-29-2016, 12:29 PM | #2627 |
Rep 40,884
PM sent.
07-30-2016, 06:40 AM | #2628 |
Rep 74
Drives: '20 M550i '17 i3
Hi Shawn, could you also PM me the links for e-sys and pzd file?
Much appreciated!
2023 M550i in production, 2020 M550i
2017 i3, 2017 i3 REX *Retired* 2015 X5 50i *Retired* 2011 335is E93 *Retired* |
08-02-2016, 10:54 AM | #2629 |
Rep 648
Drives: 2016 F15, 2015 F83
Hi everyone.
I'm the new owner of a 2016 X5 50i M Sport. I can't wait to start coding and have already ordered my OBD2 cable and USB/Ethernet adapter. I've read through 35 of the 120 pages of this thread and don't know if I should be excited or scared! I'm planning on finishing all 120 pages then starting on the videos in the OP. I'm hoping to start with permanently coding VLD then moving on to other goodies. Thanks for all the hard work getting this information together in one place. Anyway, this is my first post so now I can PM. |
08-02-2016, 10:56 AM | #2630 |
Rep 40,884
PM sent.
08-02-2016, 12:20 PM | #2631 |
Rep 481
Can it be coded that I switch back from manual transmission to automatic (Drive) through the shifting paddles on the steering wheel? I've tried holding the right paddle, but it won't switch back to automatic (drive). Otherwise I have to pull the shifting lever to M/S and back to D. I get the feeling it should be much more easy somehow.
08-02-2016, 02:25 PM | #2632 |
Rep 188
If you have pulled a paddle to get it into manual then just leave it and it will revert to auto after a few seconds. If you moved the shift lever then you're going to have to move it back!
08-02-2016, 03:15 PM | #2633 |
Rep 481
Does that also work for the M50d? I've tried, but it stays in manual. I haven't touched the shift lever, just the paddles on the steering wheel.
08-02-2016, 04:47 PM | #2634 |
Rep 188
I can't say for certain (never having had the privilege of an M50d) but I want Utd be very surprised if the gear change logic was different between models.
Try a bit of patience and see if it works |
08-03-2016, 10:15 PM | #2635 |
Rep 3
Complete noob to coding here... But I did read the OP twice, searched this thread, looked at Tokenmaster's thread, and still couldn't find a definitive answer to my very basic question.
When getting the token through Launcher Premium, do I select F25 or F15 for my 2014 X5 35d? And as such, do I consistently select F25 for this entire process? Thanks for any wisdom you can offer! WF1 |
08-03-2016, 10:18 PM | #2636 | |
Rep 40,884
E-Sys Launcher Car Series = F015 E-Sys Connection Target = F025
08-05-2016, 11:56 AM | #2639 |
Rep 40,884
PM sent.
08-05-2016, 02:52 PM | #2640 |
Rep 12
Error reading JBBF
Hi Shawn,
My F11 530d got a software upgrade at the dealer (i-step F010-16-07-503) Reading and modifying HU_CIC, KOMBI and FRM were no problem When I tried to read the JBBF module I got an error: Transaktions-Report: Aktion: Codierdaten lesen JBBF [0] [C312151] readCPS o.k. CAFD_00000014_004_110_090 Fehler: File for "cafd_00000014-004_110_090" not found! [C012] I have got E-Sys 3.27.1 and v.57.1_PSdZData_Lite Any ideas? |
