      07-23-2014, 08:50 AM   #1
SpeedN8
Slower traffic keep right.
SpeedN8's Avatar
Drives: '14 X5 35d & '18 M4 Coupe ZCP
Adding ACC Cruise
Hi guys, one of the only options I didn't get when purchasing my x5 was the ACC Stop and Go. I think I have all of the other options required to more easily add that but not sure what all would be involved and what parts I need to order. Here's a pic of my build. Also, when I looked up my X5 being built on the bmw website, it actually showed that I have ACC/Stop and Go. I thought I had chosen it but it clearly isn't shown on my window sticker nor is the button on my steering wheel.
Thanks!
Current: 2022 Tesla Model Y Performance (my daily driver) - 2014 X5 35d M-Sport in Carbon Black Metallic (for towing) - 2018 M4 ZCP (track fun) - 2006 Z4 M Roadster (topless fun)
Past: 2021 Tesla Model Y Long Range - 2011 X5 50i Sport - 2006 750Li Sport - 2003 M3 Convertible - 2001 X5 4.4i Sport - 1999 Z3 Roadster 2.8
      07-23-2014, 09:11 AM   #2
barcelona
barcelona's Avatar
Drives: X
Pretty sure acc is either part of driver assist pkg or driver assist plus.
      07-23-2014, 09:30 AM   #3
DavidTSG
Drives: 2015 X5 35d
In the US, you can get ACC either as part of Driver Assistance Plus or as a standalone. Even in the DAP pkg, it's another option that has to be checked. It's not by default. In either case, though, there's an add'l charge specific to ACC, which I would expect to show on the sticker.
To OP, if the BMW build showed it, but you don't have the button, then there's a disconnect somewhere. Did you check the build paperwork that you signed when you placed the original order w/ the dealer? Not sure if every dealer does it, but my dealer printed out my order and I had to sign the printout stating that it's exactly what I wanted. If it's on the order that they agreed to, then they should do something to make it right.
      07-23-2014, 09:42 AM   #4
Buckerine
Drives: X5
It's part of driver assistance plus, but you have to specifically choose it as part of driver assistance plus, otherwise you get what OP shows in his photo.
      07-23-2014, 10:03 AM   #5
SpeedN8
SpeedN8's Avatar
I was back and forth on it. I think they are correct since the price shown on the sticker is the number in the deal. Not that I paid that price, I did a "trade assist" from a buggy 2012 x5 50i.
I'd really like to know if anyone knows the part numbers required to add this myself and if it's very involved. I'm hoping it's not super involved since I have prerequisite options already added.
Thanks!
      07-23-2014, 10:23 AM   #6
Socal2025
Drives: 2018 540i
At the bare minimum you will need the ACC sensor (part # 66316865789) that costs about $1,944.75 and steering wheels buttons, leading possibly to a replacement of some large part of the wheel. Wiring will probably be needed as well. Re-coding will also be needed for sure.
I believe you already have the KaFas camera (part #66519281717) and the ECU for Camera Base Support (part # 66519338298). Expect hours and hours of labor.
      07-23-2014, 10:32 AM   #7
SpeedN8
SpeedN8's Avatar
If I already have the collision avoidance w/ ability for the car to stop itself, as well as the camera that tells the speed limit signs, would the only thing be the sensor and wheel buttons?
      07-23-2014, 10:48 AM   #8
DavidTSG
Drives: 2015 X5 35d
It's still likely that you'll need wiring and recoding. The collision avoidance you have (and I have soon ) is actually the basic "Collision Avoidance with City Braking" that's referenced in the owner's manual. It's a different behavior than the collision avoidance and braking that comes with the radar sensor and full ACC. I'd imagine that would require some changes to the computers.
But, from a parts perspective, you should only need the sensor and wheel buttons (and whatever wiring harness/cabling that is required to put those in place).
2015 X5 xDrive 35d Luxury Line
2012 X5 xDrive 35i Premium - Retired
      07-23-2014, 11:03 AM   #9
SpeedN8
SpeedN8's Avatar
I wonder if there's a way to tell where the radar sensor is so I can just physically check? I do have this odd thing up front and no clue what it is.
      07-23-2014, 11:13 AM   #10
SpeedN8
SpeedN8's Avatar
...also if I log into the mybmw.com website, it shows the following under the production for my build. *sorry for so many pictures.
      07-23-2014, 11:59 AM   #11
Overtaxed
Drives: RR Diesel, F450
That's it (what you show on the build sheet). You should have Stop/Go.
      07-23-2014, 12:19 PM   #12
SpeedN8
SpeedN8's Avatar
Yeah but it doesn't say anything about cruise. What does yours show?
      07-23-2014, 05:06 PM   #13
Gilly1964
Drives: F15 30d MSport
ACC is Active Cruise Control. It's pretty obvious if you have it as there is a 300mm by 100mm (ish) black rectangular radar emitter / sensor in the 'mouth' of the front bumper. And the button on the steering wheel.
      07-23-2014, 06:10 PM   #14
Overtaxed
Same thing.
ACC = Active cruise control
You've got it, if it's not activating, then either it's messed up, or they forgot to install it. Either way, it's their problem, not yours!
      07-23-2014, 07:08 PM   #15
barcelona
barcelona's Avatar
Drives: X
OP, you should have ACC. You appear to have the Radar sensor as seen in your pic.
In Canada, ACC with stop& go is "5AT Driving Assistant Plus" $1900, agrees to your window sticker.
The buttons above & below the thumbwheel incr/decr the distance that you set, there are 3 bars each representing the safe distance that you select.
Missed OP's comment: buttons are not on steering wheel.
So no buttons implies NO ACC however; there appears to be an emitter in the bumper. From the owners manual the emitter appears to be in a different location, centred. So is that an emitter?
Last edited by barcelona; 07-24-2014 at 04:51 AM.. Reason: car is parked with wheel turned, 180 degrees
      07-23-2014, 09:15 PM   #16
Mathme
Drives: 2014 X530d
If it's not there and you ordered it, then you essentially have two choices:
1). Accept the car the way it is (and get your dealer to give you a discount), or
2). Tell your dealer to order another and you don't want to pay any increase as it'll likely be a '15. The dealer should make this up to you.
If you already took delivery of the car, then unfortunately you own it.
      07-24-2014, 12:34 AM   #17
rawskyb
Drives: G05 45e, Porsche Macan GTS
I don't think OP has ACC. There was a known defect in the mybmw website where it listed some of the OPTIONAL features under Driver Assistance Plus even if you didn't order them. My build on that website looked just like the OP's, but I only ordered DA and DAP, not ACC (which was an additional $1200 option on top of the other two - it is 5AT which includes ACC and Active Driving Assistant 5AS, which is a standard part of DAP). The window sticker the OP showed is correct - it does not have ACC.
      07-24-2014, 02:59 AM   #18
Gilly1964
If you look at the front-on picture of @greentrbo95gst vehicle in his thread "X5d with pics" you will see the radar emitter - you can't miss it!
      07-24-2014, 10:43 AM   #19
SpeedN8
SpeedN8's Avatar
I see what you mean. The very center of his lower grill has a black space where mine does not. I do have the one to the side as shown in my earlier pictures. Thanks for pointing this out to me. I'm thinking it's probably not going to be worth retrofitting this option. I'd love to figure out the cost though... Go figure I'd want to have one of the only options I didn't select. I'll get over it.
Thank you all very much for your responses!
