      07-24-2014, 12:24 AM   #1
bgreen4544
Drives: 2014 X5 F15, M4 F82
Issue with camera system
I got my f15 coded for euro high beam assist and when using it am getting the following:
Malfunction - camera visibility reduced, clean camera
I cleaned the camera twice and still getting this. Any ideas on what it could be? The high beam assist shuts off when this errors out. It sometimes works for about 5 minutes.
      07-24-2014, 10:24 AM   #2
stewy604
stewy604's Avatar
290
Have you cleaned both the front and the rear cameras? Perhaps its the rear camera that is throwing the code.
2007 Suzuki GSX-R 750
      07-24-2014, 11:14 AM   #3
NPickles
United Kingdom
71
Drives: F15 40D SE Space Grey/Terra
Rear camera? where's that?
I thought the KAFAS camera behind the mirror handled the HBA, or a dedicated HBA camera if you didn't have other items requiring KAFAS. That said don't all X5's now get the driver assist as standard so you'll have KAFAS anyway.
      07-24-2014, 11:23 AM   #4
xdriverx
Drives: 2017 BMW X5 35i Xdrive
The rear camera is on the trunk, on the lip just above the rear license plate.
View post on imgur.com
      07-24-2014, 11:25 AM   #5
Zipforia
Zipforia's Avatar
98
Drives: 2016 BMW i8
When it says "Camera," it could means one, two, or all the cameras on the car. You are connecting the two events because the coding was the lasting you did, but I think this is a completely separate issues. I think your headlights are working fine. And, simply, one or some of your cameras are just dirty.
Z.
      07-24-2014, 01:10 PM   #6
NPickles
United Kingdom
71
Oh that rear camera, its not involved in the HBA is it as the rear view camera isn't a standard item in the UK.
      07-24-2014, 01:44 PM   #7
bgreen4544
I cleaned both cameras. Is there a camera on the windshield that high Beam feature uses? Perhaps it's that?
      07-24-2014, 01:58 PM   #8
xdriverx
The HBA uses the sensor camera that's mounted in the rear view mirror console. From the outside of the vehicle, clean the windshield in the top center where the the rear view mirror console is located.
Edit: If anyone needs me to point something out on their vehicle, I'm your guy.
      07-24-2014, 04:59 PM   #9
bgreen4544
Windex should be fine ya?
      07-25-2014, 01:07 AM   #10
wdimagineer
wdimagineer's Avatar
Drives: 2015 X5 M
In my opinion it sounds like the vehicle might not have been coded properly. The camera has a pretty high degree of tolerance for dirt so unless your windshield is covered in mud, it likely can see just fine.
Past: Bimmerpost Featured 2014 X5 xDrive50i · 2014 Jeep SRT · 2013 Tesla Model S P85+ · Bimmerpost Featured 2013 F10 M5 · 2012 550 xDrive · 2011 M3 ZCP
      07-26-2014, 08:43 AM   #11
bgreen4544
Took off the coding and it's still throwing the alert when using high beam assist, will take it to the dealer
      07-26-2014, 07:56 PM   #12
opasha
opasha's Avatar
1329
Drives: 2014 BMW X5 50i
With ESYS, did you CLEAR ALL DTCs first using External Applications > External Application > Transmitter > Scrolling to the very last option CLEAR ALL DTCs?
      07-26-2014, 08:09 PM   #13
bgreen4544
I'll make sure tomorrow to do that. What will that accomplish? It's not a constant error unless you use it.
      07-26-2014, 08:25 PM   #14
opasha
opasha's Avatar
1329
What this does is clear all computer/service errors from the vehicle so they do not pop up again if everything is functioning correctly. If this does not work, then something bigger is occurring in your vehicle, which would require you to get it serviced by BMW.
