      10-24-2016, 12:07 PM   #1
DG Sooner
Drives: 2022 X5 40i xDrive M Sport
Paint touch-up
Does anyone have experience in touching up some small paint chips on their X5? I have black sapphire metallic and have acquired a couple small chips that are driving me crazy. I bought the OEM paint and clear coat touch up kit (link at bottom). It sounds easy if you have a steady hand and the chips are tiny, but I thought I would solicit any comments or advice prior to attempting.
https://www.amazon.com/BMW-touch-up-...touch+up+paint
      10-24-2016, 01:35 PM   #2
Kzang
Kzang's Avatar
3239
Drives: 2015 X5 35i Msport SG
Toothpick and Qtip. Dab it here and there let it dry then apply couple of more coats as needed. If you mess up, just wipe it off and re-apply.
hanman194.50
      10-24-2016, 01:52 PM   #3
double_j
85
Drives: 2008 JB/B E90 M3
If you're talking normal small chips on the hood, you might want to check out Dr. Colorchip products (not affiliated, have just heard really good feedback about using it on multiple small chips over a larger area).
If something more significant, then be ready to accept the fact that you won't get it perfect. Best you can do is to use a toothpick to dab the paint into the chip until the paint comes to the edges. Let it sit and dry for a bit and then reapply as the paint contracts to keep the chip filled with paint.
Unfortunately, blending well is nigh impossible. It'll never survive a close-up examination but you'll be able to make it unnoticeable from more than a couple of feet out.
Also, don't even bother with the clear on a rock chip. You're not trying (or able to) make it perfect. You're really just trying to make the chip invisible from a distance.
Kzang3238.50
      10-25-2016, 08:22 AM   #4
Broadsword
Sustinendum Victoriam
80
Drives: '13 335i
I second Dr Colorchip. Very easy to use and clean up.
I have both a BSM F30 and SGM F15 the color matching of metallic paint is hit or miss unfortunately.
      10-25-2016, 09:27 AM   #5
JonM
Drives: E90 M3 Sedan
Third vote for Dr. Colorchip. In my experiences, the Dr. Colorchip paint colors match the stock paint better than the BMW touch up sticks. And, you can smooth out the blob effect with their stuff.
Jon Maddux
coupenut.blogspot.com
x5nut.blogspot.com
16 X5d | 08 M3 Sedan | 06 M Coupe | 01 M coupe | 99 M coupe
      10-25-2016, 10:18 AM   #6
alphaod
alphaod's Avatar
I use the BMW touch up paint but I use use a hard sponge. Not the absorbent kind, the kind women use to put on makeup. Its easy to flatten and you don't end up with the brush strokes.
      10-27-2016, 09:45 PM   #7
Andre13
Andre13's Avatar
Drives: 2014 F15 X5 xDrive35i
2014 BMW X5  [0.00]
2011 Audi A5  [0.00]
I've used Dr Colorchip and it works well. Just don't expect perfections as they disappear when you are far away but get noticeable when you're close to the spot. Check this out as it may help you.
      10-30-2016, 06:51 PM   #8
Stinkyxy
Drives: X5
I have patience for the first part of the video - up to the toothpick application.
Once it got to the sanding, you lose me. I have never wet sanded a car and I don't think I am about to try now.
