06-07-2018, 10:00 AM | #2 |
Rep 176
Drives: 17' X5M/91' 325i
Garage List 2017 X5M [0.00]
2014 X5 50i MSport [0.00] 2011 X5 35i SA [0.00] 2007 X3 3.0si [0.00] 2007 335i [0.00] 2003 330Ci [0.00] 1991 325ic [0.00] |
Would say that depends on which wheels you are running...
I have the standard 21" 612M's with 5mm spacers in front and 15mm rear. I like the look of the rears and should have taken Ben @r33_RGSport's advice on getting 15mm all around. There are tons of spacer threads on the forum as well.
17' X5M LBB
91' 325ic - Bril Red, Full Dinan Spec (past) 14' X5 50i MSport - Min White (past) 11' X5 35i SA - Black Saph (past) 07' X3 3.0si MSport |
6lacksheep90.50 |
06-07-2018, 10:07 AM | #3 | |
Rep 239
06-07-2018, 11:45 AM | #4 | |
Rep 15,818
IG:d.violet.m3
06-07-2018, 12:59 PM | #5 |
Rep 18,747
Yes, the new H&R spacer design allows 15mm on the front.
pk939494.00 |
06-07-2018, 01:14 PM | #7 |
Rep 18,747
15mm all around will be a little aggressive.
Probably about 1-2mm poking out. Nothing less than 15mm will fit on the front.
pk939494.00 |
06-07-2018, 01:52 PM | #8 |
Rep 239
06-07-2018, 02:02 PM | #9 |
Rep 18,747
06-07-2018, 06:59 PM | #10 |
Rep 176
I will when I have a chance to take one...
17' X5M LBB
pk939494.00 |
06-07-2018, 09:41 PM | #12 |
Rep 18,747
12mm won't fit on the front.
06-08-2018, 05:06 PM | #14 |
Rep 18,747
06-08-2018, 05:20 PM | #16 |
Rep 18,747
PM'ed
06-08-2018, 07:01 PM | #17 |
Rep 1,915
15/15 looks great!
Had reservations for front, even after I bought them from Ben, but they look great. I would not do 20 though, even on rear....especially with 11.5 width rear. |
r33_RGSport13036.50 |
06-10-2018, 01:59 PM | #19 |
Rep 1,915
Pics
Here are a few.
Front offset is 40, rear 38 Forgive nasty appearance from bugs! Last edited by menelaos; 06-10-2018 at 02:05 PM.. |
Bluesummer587.50 |
06-10-2018, 03:26 PM | #21 |
Rep 18,747
PM'ed
07-23-2018, 02:22 AM | #22 |
Rep 120
RGsport, in other threads, you always recommended 5/15 not 5/12 for F85. Also, what about 5 all around? Is it important to maintain same change in track width front and rear?? I have an F85 with stock 21in set.
