07-08-2015, 11:54 AM | #1 |
Rep 3,834
Wheel Spacers Available?
Hello guys. Anyone know what the center bore of our hub is front and rear? I can't find anyone carrying wheel spacers for the F85. The front and rear need to stick out 12-15mm to look better.
07-08-2015, 03:43 PM | #3 |
Rep 3,834
Thank you so much. So they're exactly the same as the F15.
Last gen X5 has different bore front compared to rear. Pretty goofy.
11-23-2015, 10:44 AM | #4 |
Rep 1,552
has anyone added spacers to the stock wheels yet? Just eyeing it, I was thinking a 10 in front, and a 15 in the rear, but would I searched and couldn't really find any pictures.
2020 M2 CS, 2018 M3 CS, 2016 M4 GTS, 2013 M3 LRP, 2011 1M, 2011 M3 GTRS3, 2004 M3, 2002 M3, 2000 M Coupe, 2002 M5, 1997 M3, 1988 M3, 2022 STO, 2020 Urus, 2022 TRX, 2022 392, 2021 SVJ, 2018 Performante, 2013 Gallardo 550-2, 2012 Gallardo STS, 2018 R8 RWS, 2012 R8, 2017 G550 4X4^2, 2015 GT3, 2015 Continental GT3R, 1971 Bronco
11-23-2015, 10:29 PM | #5 |
Rep 3,834
My set of BC Forged is essentially 10-12mm more aggressive than stock. It's perfect.
11-24-2015, 06:59 AM | #7 | |
Rep 1,552
Jnsol, I agree, love the look of your wheels' offset. I think I may try 12 front, 15 rear. |
11-24-2015, 09:23 AM | #8 |
Rep 18,627
Do check the hub height before you install the spacer.
Based on my test on the F15/F16 xDrives, the 15mm is not deep enough to clear the hub. So 10mm or 12mm for sure will not fit.
11-24-2015, 09:30 AM | #9 |
Rep 1,552
ok thank you. was it not deep enough for both front and rear?
11-24-2015, 09:30 AM | #10 |
Rep 18,627
The rear clears on 15mm. I don't think 12mm will clear.
11-24-2015, 09:50 AM | #12 |
Rep 18,627
Which hub? The front or the rear?
11-25-2015, 10:34 AM | #14 |
Rep 1,552
ok thanks guys...so it sounds like if I do h&r spacers like I normally do, my choices are 15 square or 15 front, 20 rear. im worried 15s all around may not look staggered enough b/c the rear wheels seem so sunken in on my stock 20" wheels, but might be worth starting there as a 20mm sure seems aggressive compared to the widths I normally use on vehicles.
thanks rm
11-25-2015, 11:29 AM | #15 | |
Rep 18,627
Why don't you take off the wheel and measure the hub length first.
I don't think the F85/F86 is much different than the F15/F16. It is sharing most of its component. Quote:
But, as I have tested, the 15mm is not deep enough to have the spacer to sit properly on the hub. The width and offset on the F85 X5M wheels is similar to the F15 X5 wheels. Today I will be testing 5/15mm and 5/20mm combo on F15 X5. I will post the result here and F15 forums by the end of today, IF the customer shows up.
11-25-2015, 12:09 PM | #16 |
Rep 263
11-25-2015, 01:29 PM | #17 | |
Rep 1,552
11-25-2015, 01:59 PM | #18 |
Rep 18,627
Here is the link of spacers that I've done on my sDrive35i.
The rear is 20mm. http://f15.bimmerpost.com/forums/sho....php?t=1189485
11-25-2015, 02:53 PM | #19 |
#dubspec
6317
Rep 5,200
12.5mm spacers fit. ecs tuning caries them.
running them in the rear and had them on the front before with 20mm rears and 22's with 12.5mm rears only
LCI ///F80 M3 Individual Atlantis Metallic / Black Full / Carbon Cermics / 6MT
MPE / M Performance & Carbon package / KW v3 / 20" HRE R101LW / 20" HRE 527s / Michelin PSS / 20% tint / 3d Design / Streckenn splitters / OEM GTS hood / EAS Carbon seatbacks / Carbon RKP sideskirt / Bootmod3 / M Performance Tri color alcantara / AWE S Flow instagram: @ dubsesd |
11-25-2015, 06:28 PM | #20 | |
Rep 1,552
is the stance I'm looking for...thx!
12-24-2015, 01:15 AM | #21 |
Rep 2,342
I bought a set of 15mm all around and the rear fit fine. But the front didn't. The bore cleared, but the front flange is larger than the rear and the spacer would not seat against the hub.
Looks like ECS also makes 15mm 74.1mm spacers. Will these clear the flange and seat on the hub? |
12-31-2015, 09:41 AM | #22 |
Rep 2,342
The ECS 15mm spacers did not clear the flange. It looks like your would need 18mm to clear the front wheel hub and seat flat.
The spacer would need to be milled another 2-3mm or someone needs to make a spacer that does not taper in the bore. |
Tags |
center bore, f85, wheel spacer, x5m |
