07-03-2021, 06:00 PM | #1 |
223
Rep 304
RW carbon center bumper panel trim and lip spoiler replacement
07-03-2021, 07:23 PM | #3 |
223
Rep 304
Nice. Need the eyebrows to finish the front end there.
Klienfeld303287.00 |
07-03-2021, 08:06 PM | #5 | |
456
Rep 350
👄 Just saying- not to shabby to me!
2016 BMW X5M F85 | 2019 - Present
2015 BMW X5 F15 5.0i m-sport | 2016-2019 2001 BMW X5 3.0i Sport | 2005 - 2008 |
07-03-2021, 08:50 PM | #6 |
Rep 417
They are kinda cute. Let me see how they look on a panda.
ACID.
07-04-2021, 01:03 PM | #7 |
199
Rep 363
Where are you getting the wrap for the bar between the fog lights, assuming you’re not having it professionally done?
2017 X5 ///M
2019 X3 XDrive 30i 2003 Porsche C4S |
07-04-2021, 01:32 PM | #8 |
Rep 417
That's a carbon piece. I had mine wrapped a few months back then I slapped the carbon piece on. Looks much better with the carbon grilles.
ACID.
07-04-2021, 02:08 PM | #9 |
199
Rep 363
Does it just snap on?
2017 X5 ///M
07-04-2021, 02:44 PM | #10 |
Rep 417
3m tape.
ACID.
07-04-2021, 02:46 PM | #11 |
Rep 417
ACID.
07-04-2021, 04:31 PM | #12 |
223
Rep 304
07-05-2021, 08:19 AM | #13 |
199
Rep 363
I did now. I was on my phone earlier.
The only thing I don’t like is that there’s no hole for the tow hook access. I run my front plate with a mount there.
2017 X5 ///M
07-05-2021, 01:34 PM | #14 |
223
Rep 304
I made a new plate mount for lower on the grill.
Klienfeld303287.00 m3fuz199.00 |
07-05-2021, 01:47 PM | #15 |
Rep 417
Toggle bolts? It looks clean man. Thankfully I don't need a front plate here. If they are in fact toggle bolts make sure they are stainless steel! I used a bunch in my boat once and they were impossible to remove.
ACID.
07-05-2021, 01:57 PM | #16 |
223
Rep 304
Not toggle bolts , but that would have been an easier go. I cut some 2.5" x 1" x 3mm Delrin plates on the bandsaw from a chunk I had in the shop. Then I drill and pressed in a nut insert. I used the plates from behind and threaded in the #10 machine screws. Not stainless, but can't see the need to remove the bracket any time. The actual plate mounting screws are black anodized, so should come out when needed. I also made some Delrin wedge spacers to angle the plate correctly to sit vertical, as the lower grill slopes inward. We have front plate mandate, and I got pinched for no front plate too many times to bother running without it anymore. Don't need the hassle from popo.
m3fuz199.00 Klienfeld303287.00 |
