      02-20-2015, 07:54 AM   #1
X5Jouster
X5Jouster's Avatar
110
Drives: X5 xDrive50I Msport
Ignition switched Fuse
hello all!
Installed the Gthaus Exhaust!! very exciting and sounds great.
the valves and remote system that have been included in the construction need power. So i put a Fuse tap on the end, and attempted to find a switched fuse.
who knows what fuses in the rear right fuse panel are powered with the Key?
P.s i will have a review of the exhaust system shortly
      02-20-2015, 11:05 AM   #2
NPickles
United Kingdom
71
From one of the Dashcam threads http://f15.bimmerpost.com/forums/sho...&highlight=121 someone mentioned that they used fuse number 121 for switched accessory and fuse 162 for continuous battery power in the rear fuse box. So fuse 121 should do the trick for you. You using a piggyback fuse tap?
      02-20-2015, 11:21 AM   #3
X5Jouster
X5Jouster's Avatar
110
yes a piggyback fuse tap type connection
i will try 121!!
      02-20-2015, 12:42 PM   #4
NPickles
United Kingdom
71
i will try 121!!
Just make sure you get the piggyback tap the right way round so the accessory is fused correctly.
      02-24-2015, 12:06 PM   #5
X5Jouster
X5Jouster's Avatar
110
are you saying the fuse tap must be inserted the correct direction like a polar connection>???
      02-24-2015, 03:06 PM   #6
opasha
opasha's Avatar
1329
Drives: 2014 BMW X5 50i
The A with the circle around (#120) it is an ignition switched fuse. Turns on with the car, turns off with the car. We used it for the air suspension and it worked correctly.
      02-24-2015, 04:04 PM   #7
NPickles
United Kingdom
71
Just that you want the feed side of the tap on the feed side to the existing fuse so that the accessory is connected through the extra fuse that you are protecting it with, if you enter it the wrong way round you bypass the extra fuse.
      02-25-2015, 08:20 AM   #8
X5Jouster
X5Jouster's Avatar
110
got it! makes sense lol is there diagrams or symbols to represent feed side, as they go vertical and horizontal.... my guess is to use fuses correctly the tap would face to the right or to the top....
