09-29-2018, 08:42 AM | #1 |
Rep 182
My oil report analysis-diesel
This is using Mobil’s esp 5w30. The first oil in the report is BMWs oil which appears to not be as good as the mobile.
09-29-2018, 07:43 PM | #2 |
88
Rep 366
Thanks for sharing.
I do believe that the oil analysis is a good thing. A lot of companies do this that run large diesel engines, such as large trucks, and heavy equipment.
2014 X5 35d X-drive. Space Gray Metallic. Mocha Dakota Leather.
09-29-2018, 09:12 PM | #3 |
480
Rep 317
I’m suprised at the lack of molybdenum in Bmw oil, The metals (ie iron aluminum copper chromium) were higher with Bmw oil however taking in consideration
with a lower mile engine I suspect tolerance were tighter and was in the end of breaking in” phase so slightly higher metal level is expected. Mobil 1 oil holding up well, but the TBN slightly lower but still strong with good service, I don’t see anything wrong going 10k miles, but for i I probably stick with 7500 miles. FYI you might get more in-depth feed back on bobistheoilguy forum (the oil enthusiast site) I’ll see if I can find some VOA for both oils Update BMW LL-04 5w-30 (Shell) Last edited by Mr.47; 09-29-2018 at 10:46 PM.. |
