04-05-2018, 04:09 AM | #45 |
Rep 1,915
04-05-2018, 07:06 AM | #46 | |
Rep 428
Drives: 2015 X5 35d
I'm wondering how much this whole transformation is costing you and how much the equivalent job would cost for me in Canada, seems like everything is so much pricier where I live. |
04-05-2018, 10:13 AM | #47 |
Rep 1,915
I am in the middle of nowhere....it's as cheap as it gets, but it is USA, so not free!
04-05-2018, 10:30 AM | #48 |
Rep 1,915
Collecting opinions on "whiting out" fender black vents.
They're bolted on from inside and did not want to remove fender just to remove them! |
04-06-2018, 09:07 AM | #49 |
Rep 18,716
What fender black vents?
04-06-2018, 09:38 AM | #50 |
Rep 1,915
04-06-2018, 09:45 AM | #51 |
Rep 18,716
04-06-2018, 09:50 AM | #52 | |
Rep 1,915
04-06-2018, 09:55 AM | #53 | ||
Rep 18,716
On X5M it is plastic welded from inside, but most ended up just using 3M double sided tape. So, on the regular F15 X5, just use the 3M double sided tape. I just got my new shipment on gloss black without badge indentation yesterday.
04-06-2018, 09:57 AM | #54 | |
Rep 1,915
04-06-2018, 09:59 AM | #55 | ||
Rep 18,716
04-06-2018, 10:03 AM | #56 |
Rep 1,915
04-06-2018, 10:08 AM | #57 | |
Rep 18,716
So, pretty much there is no point for you to change the fender since they are the same. Even between M Sport and non M Sport F15 X5.
04-06-2018, 10:11 AM | #58 | |
Rep 1,915
Just wanted to remove those vents, but I was told they were bolted from inside, so it's too much work to remove them. Then I wondered whether I should white them out. |
04-06-2018, 10:29 AM | #59 | ||
Rep 18,716
I don't think anyone will spend enough time and effort to take off the fender and put screws from behind.
04-06-2018, 10:37 AM | #60 |
Rep 1,915
04-06-2018, 11:52 AM | #61 |
Rep 18,716
Post a picture of your fender, let me see which one that you have. Do a close up picture too, I should be able to tell the difference.
Also, maybe try heating it up with heat gun before prying it off.
04-06-2018, 12:37 PM | #62 |
Rep 1,915
04-06-2018, 01:16 PM | #64 | |
326
Rep 303
Also, your whip is coming together nicely...thanks for sharing your project with the rest of us! |
menelaos1226.00 |
04-06-2018, 02:48 PM | #65 |
Rep 1,180
fitment on the replica front lip looks pretty good. If I destroy my OEM I might have to pick up whichever replica that is.
Best of luck on the exhaust tips. I've seen posts where people cut off their oem tips to powdercoat and weren't able to get them lined back up again. I'm assuming it will be just as difficult, if not more difficult to get those cayenne tips to line up correctly.
2018 X5 35i M-Sport
04-06-2018, 02:50 PM | #66 | |
Rep 1,915
Currently at mechanic, lots of challenges, with welding and angling pipes. Added a couple of pictures from one that's done |
