11-30-2022, 10:46 AM | #45 | |
Rep 37
Seems like faulty logic, either the board isn't receiving/interpreting the unlock signal correctly, or it is and its not sending the shutdown command correctly (given it turns on just fine, I don't think this would be the issue). On my initial call to them, he did mention this is a "very new product" so seems like I am a beta tester. |
11-30-2022, 10:48 AM | #46 |
Rep 37
Support got back to me, said jumpers are fine. I quickly look at the PCB I think the relays go to the key harness, possibly for a different key.....I am curious as to what they functionality of those jumpers are so I'll do some continuity testing to see if they are being sent to the car or keyfob later.
11-30-2022, 12:20 PM | #47 |
Rep 37
11-30-2022, 07:15 PM | #48 |
150
Rep 349
11-30-2022, 10:58 PM | #51 |
Rep 37
12-01-2022, 09:16 AM | #52 |
Rep 37
Support is sending me a replacement. Definitely annoying, assuming it is a defective unit, the important thing for me is how well they have handled the situation thus far. Replies within 2 hours (most within 15min), very frictionless to get to this point. It's impossible to have 100 % QC, how support handles cases like this is far more important to me.
This assumes, it is a defective module lol. Will update when new one comes Last edited by Fus10nv2; 12-01-2022 at 09:23 AM.. |
12-02-2022, 04:42 PM | #54 |
150
Rep 349
12-02-2022, 05:23 PM | #55 | |
Rep 37
I basically watched the video, found the pages in the PDF corresponding to the current spot in the video and followed both for the first two connectors. It really just rinses & repeat. Once I got the hang of it, I just followed the PDF. I would say watch the video before install, and then follow the PDF during installation (PDF has the colors of the wires which helps with identifying pins). Following the grounding position from the video, I pulled the airbag out from under the glove box and didn't find the bracket the PDF refers to, grounding it to the screw they say in the video works fine (I confirmed continuity to ground lead). One connector is a pain in the ass though. It's the last one in the video, to the left of the fuses it's tight with the carpet in place. I took a white bracket holding the carpet in place out so I can bend the carpet a little better to get to it...apart from that it's pretty easy. Just take your time and double-check everything. Also, you will want foam squares or a yoga mat to kneel on. As well as a headlamp found that way easier to work with than setting up a light. Oh and take pics of the orientation of the connectors inside the housing so you know which goes on which side when sliding them back in. |
12-02-2022, 05:32 PM | #56 | |
150
Rep 349
I was asking out of concern that the wire pin numbers or colors may have been a mismatch between the video and the pdf? |
12-02-2022, 05:34 PM | #57 |
Rep 37
ohhh Yes, basically completely different. Follow wire colors from PDF for sure that one threw me off when I started.
12-02-2022, 05:35 PM | #58 | |
150
Rep 349
https://www.youtube.com/watch?v=P2Iul6CIJ-c |
12-02-2022, 05:36 PM | #59 | |
Rep 37
You doing your install soon? They shipped my replacement today, assuming fedex doesn't lose it I'll have it on Tuesday. |
12-02-2022, 05:37 PM | #60 |
150
Rep 349
..waiting on a key fob, myself.
You'll know in a few minutes whether you got a bad part - just needing to replace the module & snapping in the connectors. I am on the edge of my seat waiting to hear how you resolve it! Last edited by Tomcat_F15_STL; 12-02-2022 at 07:33 PM.. |
12-03-2022, 12:19 PM | #61 | ||
Rep 178
Thanks |
12-07-2022, 12:51 PM | #62 |
Rep 708
Drives: BMW 2018 X3 GO1
I’ve also recently ordered a kit and spare fob for my 2018 X3 . The key fob has been shipped but the remote kit hasn’t. I ordered it a week ago and they emailed me the install information. Going over it I noticed a mistake on wire color and informed them of it . They have corrected it in a new email, I just hope the rest of the information is correct. You’re playing around with the BDC , it’s not a toy . I was just wondering on how long it took to get the kit , I see the fob was shipped from Poland no sure where the kit is coming from. Support didn’t really seem to think the mistake of the wire color was a big deal ? I asked them if I was the first to do a install on a GOi and I’m not . Just not sure why the mistake wasn’t corrected previously . Scary part is that they didn’t seem to have a sense of urgency about the instruction mistake .
12-07-2022, 04:13 PM | #63 | |
150
Rep 349
my remote kit took four days to arrive from DHL Hong Kong to St. Louis. Please share the connector and wire color problem you identified with us. I wonder if it applies only to X3s? How did you locate the error? |
12-07-2022, 06:16 PM | #64 | |
Rep 178
12-07-2022, 08:36 PM | #65 |
Rep 708
The mistake was on pages 18 & 19 , they were telling me to insert a green with a white tracer into the BimmerTech connector and it never mentions that wire being removed. You would think that it would have been corrected being they told me I wasn’t the first to notice it .
Present:
Jet Black 2018 X3 30i Previous: Sapphire Black 2013 X3 28i , Jet Black 2007 X3 3.0 Liter |
12-07-2022, 08:39 PM | #66 |
Rep 708
I ordered mine 6 days ago and it still hasn’t shipped
Present:
